YACS::HMI::SubjectOutputPort Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectOutputPort:
Collaboration diagram for YACS::HMI::SubjectOutputPort:
 SubjectOutputPort (YACS::ENGINE::OutputPort *port, Subject *parent)
virtual ~SubjectOutputPort ()
virtual bool setValue (std::string value)
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectDataPort
 SubjectDataPort (YACS::ENGINE::DataPort *port, Subject *parent)
virtual ~SubjectDataPort ()
virtual YACS::ENGINE::DataPort * getPort ()
void addSubjectLink (SubjectLink *subject)
void removeSubjectLink (SubjectLink *subject)
std::list< SubjectLink * > getListOfSubjectLink ()
void setExecValue (std::string value)
std::string getExecValue ()
void registerUndoDestroy ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::OutputPort * _outputPort
- Protected Attributes inherited from YACS::HMI::SubjectDataPort
YACS::ENGINE::DataPort * _dataPort
std::string _execValue
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectDataPort
static bool tryCreateLink (SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
Definition at line 240 of file guiObservers.hxx.
◆ SubjectOutputPort()
SubjectOutputPort::SubjectOutputPort ( YACS::ENGINE::OutputPort *  port,
Subject *  parent
Definition at line 3805 of file guiObservers.cxx.
3806 : SubjectDataPort(port, parent), _outputPort(port)
3807{
3808 if (DynParaLoop* dynloop = dynamic_cast<DynParaLoop*>(_outputPort->getNode()))
3809 {
3810 if (_outputPort == dynloop->edGetSamplePort()) _destructible = false;
3811 }
3812}
Base class for dynamically (fully or semifully) built graphs.
Definition: DynParaLoop.hxx:41
Node * getNode() const
Definition: Port.hxx:46
SubjectDataPort(YACS::ENGINE::DataPort *port, Subject *parent)
References YACS::HMI::Subject::_destructible, _outputPort, and YACS::ENGINE::Port::getNode().
◆ ~SubjectOutputPort()
SubjectOutputPort::~SubjectOutputPort ( )
Definition at line 3814 of file guiObservers.cxx.
3815{
3816 DEBTRACE("SubjectOutputPort::~SubjectOutputPort " << getName());
3817}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectDataPort::getName().
◆ clean()
void SubjectOutputPort::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectDataPort.
Definition at line 3819 of file guiObservers.cxx.
3820{
3821 if (_askRegisterUndo)
3822 {
3823 _askRegisterUndo = false;
3825 }
3826 localclean(command);
3827 SubjectDataPort::clean(command);
3828}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectDataPort::clean(), localclean(), and YACS::HMI::SubjectDataPort::registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectOutputPort::getType ( )
Definition at line 248 of file guiObservers.hxx.
248{return OUTPUTPORT;}
References YACS::HMI::OUTPUTPORT.
◆ localclean()
void SubjectOutputPort::localclean ( Command *  command = 0)
Definition at line 3830 of file guiObservers.cxx.
3831{
3832 DEBTRACE("SubjectOutputPort::localClean ");
3833 if (_parent)
3834 {
3835 SubjectElementaryNode* elem = dynamic_cast<SubjectElementaryNode*>(_parent);
3836 if (elem) elem->removePort(this);
3837 }
3838}
virtual void removePort(SubjectDataPort *port)
References YACS::HMI::Subject::_parent, DEBTRACE, and YACS::HMI::SubjectElementaryNode::removePort().
Referenced by clean().
◆ setValue()
bool SubjectOutputPort::setValue ( std::string  value)
Generic method do nothing. Implementation in SubjectInputPort and SubjectOutputPort.
Definition at line 3840 of file guiObservers.cxx.
3841{
3842 DEBTRACE("SubjectOutputPort::setValue " << value);
3843 Proc *proc = GuiContext::getCurrent()->getProc();
3844 CommandSetOutPortValue *command =
3845 new CommandSetOutPortValue(proc->getChildName(getPort()->getNode()), getName(), value);
3846 if (command->execute())
3847 {
3848 GuiContext::getCurrent()->getInvoc()->add(command);
3849 return true;
3850 }
3851 else delete command;
3852 return false;
3853}
Definition: Proc.hxx:44
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
virtual YACS::ENGINE::DataPort * getPort()
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectDataPort::getPort(), and YACS::HMI::GuiContext::getProc().
◆ _outputPort
YACS::ENGINE::OutputPort* YACS::HMI::SubjectOutputPort::_outputPort
Definition at line 250 of file guiObservers.hxx.
Referenced by SubjectOutputPort().
