#include <commandsProc.hxx>
| CommandSetOutPortValue (std::string node, std::string port, std::string value) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _node |
| std::string | _port |
| std::string | _value |
| std::string | _oldValue |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 395 of file commandsProc.hxx.
| CommandSetOutPortValue::CommandSetOutPortValue | ( | std::string | node, |
| std::string | port, | ||
| std::string | value | ||
Definition at line 2230 of file commandsProc.cxx.
protectedvirtual |
Definition at line 2239 of file commandsProc.cxx.
protectedvirtual |
Definition at line 2245 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectDataPort, _node, _oldValue, _port, _value, YACS::ENGINE::convertPyObjectXml(), YACS::ENGINE::RuntimeSALOME::convertStringToPyObject(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), testCppPluginInvokation::ex, YACS::ENGINE::OutputPresetPort::getAsString(), YACS::ENGINE::OutputStudyPort::getAsString(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getOutputPort(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::getSALOMERuntime(), YACS::ENGINE::TypeCode::isA(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::DataNode::setData(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::ENGINE::String, YACS::HMI::Subject::update(), and YASSERT.
protectedvirtual |
Definition at line 2338 of file commandsProc.cxx.
protected |
Definition at line 405 of file commandsProc.hxx.
protected |
Definition at line 408 of file commandsProc.hxx.
Referenced by CommandSetOutPortValue(), localExecute(), and localReverse().
protected |
Definition at line 406 of file commandsProc.hxx.
protected |
Definition at line 407 of file commandsProc.hxx.
