YACS::ENGINE::OutputPresetPort Class Reference
Class for PRESET output Ports. More...
#include <PresetPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputPresetPort:
Collaboration diagram for YACS::ENGINE::OutputPresetPort:
 OutputPresetPort (const std::string &name, Node *node, TypeCode *type)
 OutputPresetPort (const OutputPresetPort &other, Node *newHelder)
OutputPort * clone (Node *newHelder) const
void setData (std::string data)
std::string getData ()
 Check validity of output port. Nothing on base class. More...
virtual std::string dump ()
virtual PyObject * getPyObj ()
- Public Member Functions inherited from YACS::ENGINE::OutputXmlPort
 OutputXmlPort (const std::string &name, Node *node, TypeCode *type)
 OutputXmlPort (const OutputXmlPort &other, Node *newHelder)
void put (const char *data)
virtual const char * get () const
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
std::string _storeData
- Protected Attributes inherited from YACS::ENGINE::OutputXmlPort
std::string _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
PresetNode
Definition at line 32 of file PresetPorts.hxx.
◆ OutputPresetPort() [1/2]
OutputPresetPort::OutputPresetPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 40 of file PresetPorts.cxx.
41 : OutputXmlPort(name, node, type),
42 DataPort(name, node, type),
43 Port(node)
44{
45}
Definition: DataPort.cxx:41
OutputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:122
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ OutputPresetPort() [2/2]
OutputPresetPort::OutputPresetPort ( const OutputPresetPort &  other,
Node *  newHelder
Definition at line 47 of file PresetPorts.cxx.
48 : OutputXmlPort(other,newHelder),
49 DataPort(other,newHelder),
50 Port(other,newHelder),_storeData(other._storeData)
51{
52}
◆ checkBasicConsistency()
void OutputPresetPort::checkBasicConsistency ( ) const
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 66 of file PresetPorts.cxx.
67{
68 DEBTRACE("OutputPresetPort::checkBasicConsistency " << _storeData);
69 if (_storeData.empty())
70 {
71 std::string what("OutputPresetPort: ");
72 what += getName();
73 what += " is not initialised";
74 throw Exception(what);
75 }
76}
std::string getName() const
Definition: DataPort.hxx:55
References _storeData, DEBTRACE, and YACS::ENGINE::DataPort::getName().
Referenced by YACS::ENGINE::PresetNode::checkBasicConsistency().
◆ clone()
OutputPort * OutputPresetPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 54 of file PresetPorts.cxx.
55{
56 return new OutputPresetPort(*this,newHelder);
57}
OutputPresetPort(const std::string &name, Node *node, TypeCode *type)
Definition: PresetPorts.cxx:40
References OutputPresetPort().
◆ dump()
std::string OutputPresetPort::dump ( )
Reimplemented from YACS::ENGINE::OutputXmlPort.
Definition at line 119 of file PresetPorts.cxx.
120{
121 return getData();
122}
References getData().
◆ getAsString()
std::string OutputPresetPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 136 of file PresetPorts.cxx.
137{
139 PyObject* ob=getPyObj();
140 DEBTRACE(PyObject_Str(ob));
141 std::string s=convertPyObjectToString(ob);
142 DEBTRACE(s);
143 Py_DECREF(ob);
144 return s;
145}
virtual PyObject * getPyObj()
std::string convertPyObjectToString(PyObject *ob)
References YACS::ENGINE::convertPyObjectToString(), DEBTRACE, and getPyObj().
Referenced by YACS::HMI::CommandSetOutPortValue::localExecute(), and YACS::HMI::CommandSetOutPortValue::localReverse().
◆ getData()
std::string OutputPresetPort::getData ( )
Definition at line 78 of file PresetPorts.cxx.
79{
80 DEBTRACE("OutputPresetPort::getData " << _storeData);
81 if(_storeData.substr(0,7) == "<value>")
82 {
83 return _storeData;
84 }
85 else
86 {
87 std::string value;
88 switch(edGetType()->kind())
89 {
90 case Double:
91 value="<value><double>"+_storeData+"</double></value>";
92 break;
93 case Int:
94 value="<value><int>"+_storeData+"</int></value>";
95 break;
96 case String:
97 value="<value><string>"+_storeData+"</string></value>";
98 break;
99 case Bool:
100 value="<value><boolean>"+_storeData+"</boolean></value>";
101 break;
102 case Objref:
103 value="<value><objref>"+_storeData+"</objref></value>";
104 break;
105 case Sequence:
106 case Array:
107 value="<value><array><data>"+_storeData+"</data></array></value>";
108 break;
109 case Struct:
110 value="<value><struct><data>"+_storeData+"</data></struct></value>";
111 break;
112 default:
113 break;
114 }
115 return value;
116 }
117}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
References _storeData, YACS::ENGINE::Array, YACS::ENGINE::Bool, DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Int, YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
Referenced by dump(), YACS::ENGINE::PresetNode::execute(), getPyObj(), and YACS::ENGINE::VisitorSaveSalomeSchema::writeDataNodeParameters().
◆ getPyObj()
PyObject * OutputPresetPort::getPyObj ( )
Definition at line 124 of file PresetPorts.cxx.
125{
126 DEBTRACE(getData());
127 if(_storeData=="")
128 {
129 Py_INCREF(Py_None);
130 return Py_None;
131 }
132 else
134}
PyObject * convertXmlStrPyObject(const TypeCode *t, std::string data)
References _storeData, YACS::ENGINE::convertXmlStrPyObject(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and getData().
Referenced by getAsString().
◆ setData()
void OutputPresetPort::setData ( std::string  data)
Definition at line 59 of file PresetPorts.cxx.
60{
61 _storeData = data;
62 DEBTRACE( "OutputPresetPort::setData " << _storeData );
63 modified();
64}
void modified()
Definition: Port.cxx:53
References _storeData, DEBTRACE, and YACS::ENGINE::Port::modified().
Referenced by YACS::ENGINE::PresetNode::setData().
◆ typeName()
virtual std::string YACS::ENGINE::OutputPresetPort::typeName ( )
Definition at line 44 of file PresetPorts.hxx.
44{return "YACS__ENGINE__OutputPresetPort";}
◆ _storeData
std::string YACS::ENGINE::OutputPresetPort::_storeData
Definition at line 46 of file PresetPorts.hxx.
Referenced by checkBasicConsistency(), getData(), getPyObj(), and setData().
