YACS::ENGINE::PresetNode Class Reference
Class for data in node. More...
#include <PresetNode.hxx>
Inheritance diagram for YACS::ENGINE::PresetNode:
Collaboration diagram for YACS::ENGINE::PresetNode:
 PresetNode (const std::string &name)
 PresetNode (const PresetNode &other, ComposedNode *father)
virtual void execute ()
virtual void setData (OutputPort *port, const std::string &data)
- Public Member Functions inherited from YACS::ENGINE::DataNode
virtual void setData (InputPort *port, const std::string &data)
virtual void setRef (const std::string &ref)
virtual std::string getRef ()
virtual ~DataNode ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="XML"
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::DataNode
 DataNode (const DataNode &other, ComposedNode *father)
 DataNode (const std::string &name)
template<class PORT >
YACS::Colour _colour
- Protected Attributes inherited from YACS::ENGINE::DataNode
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 30 of file PresetNode.hxx.
◆ PresetNode() [1/2]
PresetNode::PresetNode ( const std::string &  name)
Definition at line 42 of file PresetNode.cxx.
43 : DataNode(name)
44{
46}
DataNode(const DataNode &other, ComposedNode *father)
Definition: DataNode.hxx:40
Definition: Node.hxx:97
static const char IMPL_NAME[]
Definition: PresetNode.hxx:44
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
Referenced by simpleClone().
◆ PresetNode() [2/2]
PresetNode::PresetNode ( const PresetNode &  other,
ComposedNode *  father
Definition at line 48 of file PresetNode.cxx.
49 : DataNode(other, father)
50{
51}
◆ accept()
void PresetNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 73 of file PresetNode.cxx.
74{
75 visitor->visitPresetNode(this);
76}
virtual void visitPresetNode(DataNode *node)=0
References YACS::ENGINE::Visitor::visitPresetNode().
◆ checkBasicConsistency()
void PresetNode::checkBasicConsistency ( ) const
Definition at line 84 of file PresetNode.cxx.
85{
86 DEBTRACE("PresetNode::checkBasicConsistency");
87 if (! _setOfInputPort.empty())
88 {
89 string what = "PresetNode ";
90 what += getName();
91 what += " only accepts OutputPresetPorts, no InputPorts";
92 throw Exception(what);
93 }
94
95 list<OutputPort *>::const_iterator iter;
96 for(iter=_setOfOutputPort.begin();iter!=_setOfOutputPort.end();iter++)
97 {
98 OutputPresetPort *preset = dynamic_cast<OutputPresetPort*>(*iter);
99 if (!preset)
100 {
101 string what("Output port: ");
102 what += (*iter)->getName();
103 what += " is not an OutputPresetPort. PresetNode ";
104 what += getName();
105 what += "only accepts OutputPresetPorts";
106 throw Exception(what);
107 }
108 preset->checkBasicConsistency();
109 }
110}
Definition: Node.hxx:125
Class for PRESET output Ports.
Definition: PresetPorts.hxx:33
Check validity of output port. Nothing on base class.
Definition: PresetPorts.cxx:66
References YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::OutputPresetPort::checkBasicConsistency(), DEBTRACE, and YACS::ENGINE::Node::getName().
◆ createOutputPort()
OutputPort * PresetNode::createOutputPort ( const std::string &  outputPortName,
TypeCode *  type
Definition at line 53 of file PresetNode.cxx.
54{
55 return new OutputPresetPort(outputPortName, this, type);
56}
◆ execute()
void PresetNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 58 of file PresetNode.cxx.
59{
60 DEBTRACE("+++++++ PresetNode::execute +++++++++++");
61 list<OutputPort *>::const_iterator iter;
62 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
63 {
64 OutputPresetPort *outp = dynamic_cast<OutputPresetPort *>(*iter);
65 YASSERT(outp);
66 string data = outp->getData();
67 DEBTRACE("data: " << data );
68 outp->put(data.c_str());
69 }
70 DEBTRACE("+++++++ end PresetNode::execute +++++++++++" );
71}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: XMLPorts.cxx:137
References YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::OutputPresetPort::getData(), YACS::ENGINE::OutputXmlPort::put(), and YASSERT.
◆ setData()
void PresetNode::setData ( OutputPort *  port,
const std::string &  data
Reimplemented from YACS::ENGINE::DataNode.
Definition at line 78 of file PresetNode.cxx.
79{
80 OutputPresetPort *outp = dynamic_cast<OutputPresetPort *>(port);
81 outp->setData(data);
82}
void setData(std::string data)
Definition: PresetPorts.cxx:59
References YACS::ENGINE::OutputPresetPort::setData().
◆ simpleClone()
Node * PresetNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 112 of file PresetNode.cxx.
113{
114 return new PresetNode(*this,father);
115}
PresetNode(const std::string &name)
Definition: PresetNode.cxx:42
References PresetNode().
◆ typeName()
virtual std::string YACS::ENGINE::PresetNode::typeName ( )
Definition at line 42 of file PresetNode.hxx.
42{return "YACS__ENGINE__PresetNode";}
◆ IMPL_NAME
const char PresetNode::IMPL_NAME ="XML"
Definition at line 44 of file PresetNode.hxx.
Referenced by PresetNode().
