YACS::HMI::SubjectElementaryNode Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectElementaryNode:
Collaboration diagram for YACS::HMI::SubjectElementaryNode:
 SubjectElementaryNode (YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual ~SubjectElementaryNode ()
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual SubjectDataPort * addInputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addOutputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addODSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual bool OrderDataPorts (SubjectDataPort *portToMove, int isUp)
virtual void removePort (SubjectDataPort *port)
virtual void loadChildren ()
virtual void saveLinks ()
virtual void restoreLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void removeExternalControlLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadLinks ()
bool isDestructible ()
virtual TypeOfElem getType ()
virtual ~Observer ()
YACS::ENGINE::ElementaryNode * _elementaryNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 671 of file guiObservers.hxx.
◆ SubjectElementaryNode()
SubjectElementaryNode::SubjectElementaryNode ( YACS::ENGINE::ElementaryNode *  elementaryNode,
Subject *  parent
Definition at line 2058 of file guiObservers.cxx.
2060 : SubjectNode(elementaryNode, parent), _elementaryNode(elementaryNode)
2061{
2062}
SubjectNode(YACS::ENGINE::Node *node, Subject *parent)
◆ ~SubjectElementaryNode()
SubjectElementaryNode::~SubjectElementaryNode ( )
all generic destruction is done in generic class SubjectNode
Definition at line 2067 of file guiObservers.cxx.
2068{
2069 DEBTRACE("SubjectElementaryNode::~SubjectElementaryNode " << getName());
2070}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectNode::getName().
◆ addIDSPort()
SubjectDataPort * SubjectElementaryNode::addIDSPort ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  name
Definition at line 2135 of file guiObservers.cxx.
2136{
2137 DEBTRACE("SubjectElementaryNode::addIDSPort( " << catalog << ", " << type << ", " << name << " )");
2138 Proc *proc = GuiContext::getCurrent()->getProc();
2139 string position = "";
2140 if (proc != dynamic_cast<Proc*>(_node)) position = proc->getChildName(_node);
2141 else YASSERT(0);
2143 type,
2144 position,
2145 name);
2146 if (command->execute())
2147 {
2148 GuiContext::getCurrent()->getInvoc()->add(command);
2150 return son;
2151 }
2152 else delete command;
2153 return 0;
2154}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: Proc.hxx:44
SubjectInputDataStreamPort * getSubjectIDSPort()
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
friend class CommandAddIDSPortFromCatalog
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), YACS::HMI::SubjectNode::CommandAddIDSPortFromCatalog, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::GuiContext::getProc(), YACS::HMI::CommandAddIDSPortFromCatalog::getSubjectIDSPort(), and YASSERT.
◆ addInputPort()
SubjectDataPort * SubjectElementaryNode::addInputPort ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  name
Definition at line 2093 of file guiObservers.cxx.
2094{
2095 DEBTRACE("SubjectElementaryNode::addInputPort( " << catalog << ", " << type << ", " << name << " )");
2096 Proc *proc = GuiContext::getCurrent()->getProc();
2097 string position = "";
2098 if (proc != dynamic_cast<Proc*>(_node)) position = proc->getChildName(_node);
2099 else YASSERT(0);
2101 type,
2102 position,
2103 name);
2104 if (command->execute())
2105 {
2106 GuiContext::getCurrent()->getInvoc()->add(command);
2107 SubjectInputPort *son = command->getSubjectInputPort();
2108 return son;
2109 }
2110 else delete command;
2111 return 0;
2112}
friend class CommandAddInputPortFromCatalog
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), YACS::HMI::SubjectNode::CommandAddInputPortFromCatalog, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::GuiContext::getProc(), YACS::HMI::CommandAddInputPortFromCatalog::getSubjectInputPort(), and YASSERT.
Referenced by YACS::HMI::GuiEditor::CreateInputPort().
◆ addODSPort()
SubjectDataPort * SubjectElementaryNode::addODSPort ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  name
Definition at line 2156 of file guiObservers.cxx.
2157{
2158 DEBTRACE("SubjectElementaryNode::addODSPort( " << catalog << ", " << type << ", " << name << " )");
2159 Proc *proc = GuiContext::getCurrent()->getProc();
2160 string position = "";
2161 if (proc != dynamic_cast<Proc*>(_node)) position = proc->getChildName(_node);
2162 else YASSERT(0);
2164 type,
2165 position,
2166 name);
2167 if (command->execute())
2168 {
2169 GuiContext::getCurrent()->getInvoc()->add(command);
2171 return son;
2172 }
2173 else delete command;
2174 return 0;
2175}
SubjectOutputDataStreamPort * getSubjectODSPort()
friend class CommandAddODSPortFromCatalog
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), YACS::HMI::SubjectNode::CommandAddODSPortFromCatalog, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::GuiContext::getProc(), YACS::HMI::CommandAddODSPortFromCatalog::getSubjectODSPort(), and YASSERT.
◆ addOutputPort()
SubjectDataPort * SubjectElementaryNode::addOutputPort ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  name
Definition at line 2114 of file guiObservers.cxx.
2115{
2116 DEBTRACE("SubjectElementaryNode::addOutputPort( " << catalog << ", " << type << ", " << name << " )");
2117 Proc *proc = GuiContext::getCurrent()->getProc();
2118 string position = "";
2119 if (proc != dynamic_cast<Proc*>(_node)) position = proc->getChildName(_node);
2120 else YASSERT(0);
2122 type,
2123 position,
2124 name);
2125 if (command->execute())
2126 {
2127 GuiContext::getCurrent()->getInvoc()->add(command);
2128 SubjectOutputPort *son = command->getSubjectOutputPort();
2129 return son;
2130 }
2131 else delete command;
2132 return 0;
2133}
friend class CommandAddOutputPortFromCatalog
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), YACS::HMI::SubjectNode::CommandAddOutputPortFromCatalog, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::GuiContext::getProc(), YACS::HMI::CommandAddOutputPortFromCatalog::getSubjectOutputPort(), and YASSERT.
Referenced by YACS::HMI::GuiEditor::CreateOutputPort().
◆ clean()
void SubjectElementaryNode::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectNode.
Reimplemented in YACS::HMI::SubjectInlineNode, YACS::HMI::SubjectPythonNode, YACS::HMI::SubjectPyFuncNode, YACS::HMI::SubjectServiceNode, YACS::HMI::SubjectCORBANode, YACS::HMI::SubjectCppNode, YACS::HMI::SubjectSalomeNode, YACS::HMI::SubjectSalomePythonNode, YACS::HMI::SubjectXmlNode, YACS::HMI::SubjectSplitterNode, YACS::HMI::SubjectDataNode, YACS::HMI::SubjectPresetNode, YACS::HMI::SubjectOutNode, YACS::HMI::SubjectStudyInNode, and YACS::HMI::SubjectStudyOutNode.
Definition at line 2072 of file guiObservers.cxx.
2073{
2074 if (_askRegisterUndo)
2075 {
2076 _askRegisterUndo = false;
2078 }
2079 localclean(command);
2080 SubjectNode::clean(command);
2081}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
Referenced by YACS::HMI::SubjectInlineNode::clean(), YACS::HMI::SubjectServiceNode::clean(), YACS::HMI::SubjectSplitterNode::clean(), and YACS::HMI::SubjectDataNode::clean().
◆ loadChildren()
void SubjectElementaryNode::loadChildren ( )
Definition at line 2228 of file guiObservers.cxx.
2229{
2230 list<InputPort*> listInputPorts = _elementaryNode->getLocalInputPorts();
2231 list<OutputPort*> listOutputPorts = _elementaryNode->getLocalOutputPorts();
2232 list<InputDataStreamPort*> listIDSPorts = _elementaryNode->getSetOfInputDataStreamPort();
2233 list<OutputDataStreamPort*> listODSPorts = _elementaryNode->getSetOfOutputDataStreamPort();
2234 if (SplitterNode *splitterNode = dynamic_cast<SplitterNode*>(_elementaryNode))
2235 listInputPorts.push_back(splitterNode->getFather()->getInputPort("SmplsCollection"));
2236 list<InputPort*>::const_iterator iti;
2237 for (iti = listInputPorts.begin(); iti != listInputPorts.end(); ++iti)
2238 addSubjectInputPort(*iti);
2239 list<OutputPort*>::const_iterator ito;
2240 for (ito = listOutputPorts.begin(); ito != listOutputPorts.end(); ++ito)
2242 list<InputDataStreamPort*>::const_iterator itids;
2243 for (itids = listIDSPorts.begin(); itids != listIDSPorts.end(); ++itids)
2244 addSubjectIDSPort(*itids);
2245 list<OutputDataStreamPort*>::const_iterator itods;
2246 for (itods = listODSPorts.begin(); itods != listODSPorts.end(); ++itods)
2247 addSubjectODSPort(*itods);
2248}
std::list< OutputPort * > getLocalOutputPorts() const
std::list< InputPort * > getLocalInputPorts() const
std::list< OutputDataStreamPort * > getSetOfOutputDataStreamPort() const
std::list< InputDataStreamPort * > getSetOfInputDataStreamPort() const
virtual SubjectInputDataStreamPort * addSubjectIDSPort(YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort(YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputPort * addSubjectInputPort(YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort(YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
References _elementaryNode, YACS::HMI::SubjectNode::addSubjectIDSPort(), YACS::HMI::SubjectNode::addSubjectInputPort(), YACS::HMI::SubjectNode::addSubjectODSPort(), YACS::HMI::SubjectNode::addSubjectOutputPort(), YACS::ENGINE::ElementaryNode::getLocalInputPorts(), YACS::ENGINE::ElementaryNode::getLocalOutputPorts(), YACS::ENGINE::ElementaryNode::getSetOfInputDataStreamPort(), and YACS::ENGINE::ElementaryNode::getSetOfOutputDataStreamPort().
◆ localclean()
void SubjectElementaryNode::localclean ( Command *  command = 0)
Definition at line 2083 of file guiObservers.cxx.
2084{
2085 DEBTRACE("SubjectElementaryNode::localClean ");
2086}
References DEBTRACE.
Referenced by clean().
◆ OrderDataPorts()
bool SubjectElementaryNode::OrderDataPorts ( SubjectDataPort *  portToMove,
int  isUp
Definition at line 2177 of file guiObservers.cxx.
2178{
2179 DEBTRACE("SubjectElementaryNode::OrderDataPorts");
2180 Proc *proc = GuiContext::getCurrent()->getProc();
2181 string position = "";
2182 if (proc != dynamic_cast<Proc*>(_node)) position = proc->getChildName(_node);
2183 else YASSERT(0);
2184
2185 if (!portToMove) return false;
2186 string nameToMove = portToMove->getName();
2187
2188 Command *command = 0;
2189 bool isInput = dynamic_cast<SubjectInputPort*>(portToMove);
2190 if (isInput)
2191 command = new CommandOrderInputPorts(position, nameToMove, isUp);
2192 else
2193 command = new CommandOrderOutputPorts(position, nameToMove, isUp);
2194
2195 if (command->execute())
2196 {
2197 GuiContext::getCurrent()->getInvoc()->add(command);
2198 return true;
2199 }
2200 return false;
2201}
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::GuiContext::getProc(), and YASSERT.
Referenced by YACS::HMI::TablePortsEdition::oncb_insert_activated(), and YACS::HMI::TablePortsEdition::upOrDown().
◆ recursiveUpdate()
void SubjectElementaryNode::recursiveUpdate ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 2088 of file guiObservers.cxx.
2089{
2090 update(event, type, son);
2091}
References YACS::HMI::SubjectNode::update().
◆ removePort()
void SubjectElementaryNode::removePort ( SubjectDataPort *  port)
Definition at line 2203 of file guiObservers.cxx.
2204{
2205 DEBTRACE("SubjectElementaryNode::removePort " << port->getName());
2206 if (SubjectInputPort* inp = dynamic_cast<SubjectInputPort*>(port))
2207 {
2208 DEBTRACE("-");
2209 _listSubjectInputPort.remove(inp);
2210 }
2211 else if(SubjectOutputPort* outp = dynamic_cast<SubjectOutputPort*>(port))
2212 {
2213 DEBTRACE("--");
2214 _listSubjectOutputPort.remove(outp);
2215 }
2216 if (SubjectInputDataStreamPort* idsp = dynamic_cast<SubjectInputDataStreamPort*>(port))
2217 {
2218 DEBTRACE("---");
2219 _listSubjectIDSPort.remove(idsp);
2220 }
2221 else if(SubjectOutputDataStreamPort* odsp = dynamic_cast<SubjectOutputDataStreamPort*>(port))
2222 {
2223 DEBTRACE("----");
2224 _listSubjectODSPort.remove(odsp);
2225 }
2226}
References YACS::HMI::SubjectNode::_listSubjectIDSPort, YACS::HMI::SubjectNode::_listSubjectInputPort, YACS::HMI::SubjectNode::_listSubjectODSPort, YACS::HMI::SubjectNode::_listSubjectOutputPort, DEBTRACE, and YACS::HMI::SubjectDataPort::getName().
Referenced by YACS::HMI::SubjectInputPort::localclean(), and YACS::HMI::SubjectOutputPort::localclean().
◆ restoreLinks()
void SubjectElementaryNode::restoreLinks ( )
Definition at line 2255 of file guiObservers.cxx.
2256{
2258}
virtual void restoreLinks()
References YACS::HMI::SubjectNode::restoreLinks().
◆ saveLinks()
void SubjectElementaryNode::saveLinks ( )
Definition at line 2250 of file guiObservers.cxx.
2251{
2253}
virtual void saveLinks()
References YACS::HMI::SubjectNode::saveLinks().
◆ _elementaryNode
YACS::ENGINE::ElementaryNode* YACS::HMI::SubjectElementaryNode::_elementaryNode
Definition at line 689 of file guiObservers.hxx.
Referenced by loadChildren().
