YACS::HMI::CommandAddInputPortFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddInputPortFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddInputPortFromCatalog:
 CommandAddInputPortFromCatalog (YACS::ENGINE::Catalog *catalog, std::string type, std::string node, std::string name)
YACS::ENGINE::InputPort * getInputPort ()
SubjectInputPort * getSubjectInputPort ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
std::string _typePort
std::string _node
YACS::ENGINE::InputPort * _inputPort
SubjectInputPort * _sip
bool _normalReverse
Definition at line 261 of file commandsProc.hxx.
◆ CommandAddInputPortFromCatalog()
CommandAddInputPortFromCatalog::CommandAddInputPortFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  node,
std::string  name
Definition at line 1197 of file commandsProc.cxx.
References _inputPort, and _sip.
◆ dump()
std::string CommandAddInputPortFromCatalog::dump ( )
Definition at line 1207 of file commandsProc.cxx.
1208{
1209 string ret ="CommandAddInputPortFromCatalog " + _typePort + " " + _node + " " + _name;
1210 return ret;
1211}
References _name, _node, and _typePort.
◆ getInputPort()
YACS::ENGINE::InputPort * CommandAddInputPortFromCatalog::getInputPort ( )
Definition at line 1213 of file commandsProc.cxx.
1214{
1215 return _inputPort;
1216}
References _inputPort.
◆ getSubjectInputPort()
SubjectInputPort * CommandAddInputPortFromCatalog::getSubjectInputPort ( )
Definition at line 1218 of file commandsProc.cxx.
1219{
1220 return _sip;
1221}
References _sip.
Referenced by YACS::HMI::SubjectElementaryNode::addInputPort().
◆ localExecute()
bool CommandAddInputPortFromCatalog::localExecute ( )
Definition at line 1223 of file commandsProc.cxx.
1224{
1225 DEBTRACE("CommandAddInputPortFromCatalog::localExecute");
1226 InputPort *son = 0;
1227 try
1228 {
1229 Proc* proc = GuiContext::getCurrent()->getProc();
1230 Node* node = proc->getChildByName(_node);
1231 ElementaryNode* father = dynamic_cast<ElementaryNode*>(node);
1232 if (father)
1233 {
1234 //try proc types and then catalog if not in proc
1235 if(proc->typeMap.count(_typePort))
1236 son = father->edAddInputPort(_name, proc->typeMap[_typePort]);
1237 else if (_catalog->_typeMap.count(_typePort))
1239 else
1240 {
1241 DEBTRACE(_typePort << " not found in catalog " << _catalog);
1242 GuiContext::getCurrent()->_lastErrorMessage = _typePort + " not found in catalog";
1243 }
1244 }
1245 _inputPort = son;
1246 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1248 _sip = snode->addSubjectInputPort(son, _name);
1249 snode->update(SYNCHRO,0,0); // when output port tab in node edition is visible
1250 }
1251 catch (Exception& ex)
1252 {
1253 DEBTRACE("CommandAddInputPortFromCatalog::localExecute() : " << ex.what());
1254 setErrorMsg(ex);
1255 if (son) delete son;
1256 _inputPort = 0;
1257 }
1258 return (_inputPort != 0);
1259}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
virtual InputPort * edAddInputPort(const std::string &inputPortName, TypeCode *type)
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: Proc.hxx:90
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual SubjectInputPort * addSubjectInputPort(YACS::ENGINE::InputPort *port, std::string name="")
References _catalog, _inputPort, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _node, _sip, YACS::ENGINE::Catalog::_typeMap, _typePort, YACS::HMI::SubjectNode::addSubjectInputPort(), DEBTRACE, YACS::ENGINE::ElementaryNode::edAddInputPort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SYNCHRO, YACS::ENGINE::Proc::typeMap, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandAddInputPortFromCatalog::localReverse ( )
Definition at line 1261 of file commandsProc.cxx.
1262{
1263 DEBTRACE("CommandAddInputPortFromCatalog::localReverse");
1264 try
1265 {
1266 Proc* proc = GuiContext::getCurrent()->getProc();
1267 Node *node = proc->getChildByName(_node);
1268 ElementaryNode* enode = dynamic_cast<ElementaryNode*>(node);
1269 YASSERT(enode);
1270 _inputPort = enode->getInputPort(_name);
1272 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(_inputPort));
1274 YASSERT(_sip);
1275
1276 Subject *father=_sip->getParent();
1278 _sip = 0;
1279 _inputPort = 0;
1280 if (father)
1281 {
1282 DEBTRACE("REMOVE");
1283 father->select(true);
1284 father->update(REMOVE,0,0);
1285 }
1286 return true;
1287 }
1288 catch (Exception& ex)
1289 {
1290 DEBTRACE("CommandAddInputPortFromCatalog::localReverse(): " << ex.what());
1291 setErrorMsg(ex);
1292 return false;
1293 }
1294}
InputPort * getInputPort(const std::string &name) const
Definition: guiContext.hxx:71
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References _inputPort, YACS::HMI::GuiContext::_mapOfSubjectDataPort, _name, _node, _sip, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ElementaryNode::getInputPort(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddInputPortFromCatalog::_catalog
Definition at line 274 of file commandsProc.hxx.
Referenced by localExecute().
◆ _inputPort
YACS::ENGINE::InputPort* YACS::HMI::CommandAddInputPortFromCatalog::_inputPort
◆ _name
std::string YACS::HMI::CommandAddInputPortFromCatalog::_name
Definition at line 277 of file commandsProc.hxx.
◆ _node
std::string YACS::HMI::CommandAddInputPortFromCatalog::_node
Definition at line 276 of file commandsProc.hxx.
◆ _sip
SubjectInputPort* YACS::HMI::CommandAddInputPortFromCatalog::_sip
◆ _typePort
std::string YACS::HMI::CommandAddInputPortFromCatalog::_typePort
Definition at line 275 of file commandsProc.hxx.
