YACS::HMI::SubjectStudyOutNode Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectStudyOutNode:
Collaboration diagram for YACS::HMI::SubjectStudyOutNode:
 SubjectStudyOutNode (YACS::ENGINE::StudyOutNode *studyOutNode, Subject *parent)
virtual ~SubjectStudyOutNode ()
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectDataNode
 SubjectDataNode (YACS::ENGINE::DataNode *dataNode, Subject *parent)
virtual ~SubjectDataNode ()
- Public Member Functions inherited from YACS::HMI::SubjectElementaryNode
 SubjectElementaryNode (YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual ~SubjectElementaryNode ()
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual SubjectDataPort * addInputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addOutputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addODSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual bool OrderDataPorts (SubjectDataPort *portToMove, int isUp)
virtual void removePort (SubjectDataPort *port)
virtual void loadChildren ()
virtual void saveLinks ()
virtual void restoreLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void removeExternalControlLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::StudyOutNode * _studyOutNode
- Protected Attributes inherited from YACS::HMI::SubjectDataNode
YACS::ENGINE::DataNode * _dataNode
- Protected Attributes inherited from YACS::HMI::SubjectElementaryNode
YACS::ENGINE::ElementaryNode * _elementaryNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 877 of file guiObservers.hxx.
◆ SubjectStudyOutNode()
SubjectStudyOutNode::SubjectStudyOutNode ( YACS::ENGINE::StudyOutNode *  studyOutNode,
Subject *  parent
Definition at line 2878 of file guiObservers.cxx.
2879 : SubjectDataNode(studyOutNode, parent), _studyOutNode(studyOutNode)
2880{
2881 _destructible = true;
2882}
SubjectDataNode(YACS::ENGINE::DataNode *dataNode, Subject *parent)
References YACS::HMI::Subject::_destructible.
◆ ~SubjectStudyOutNode()
SubjectStudyOutNode::~SubjectStudyOutNode ( )
Definition at line 2884 of file guiObservers.cxx.
2885{
2886 DEBTRACE("SubjectStudyOutNode::~SubjectStudyOutNode " << getName());
2887}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectNode::getName().
◆ clean()
void SubjectStudyOutNode::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectDataNode.
Definition at line 2889 of file guiObservers.cxx.
2890{
2891 if (_askRegisterUndo)
2892 {
2893 _askRegisterUndo = false;
2895 }
2896 localclean(command);
2897 SubjectDataNode::clean(command);
2898}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectDataNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectStudyOutNode::getType ( )
Definition at line 884 of file guiObservers.hxx.
884{return STUDYOUTNODE;}
References YACS::HMI::STUDYOUTNODE.
◆ localclean()
void SubjectStudyOutNode::localclean ( Command *  command = 0)
Definition at line 2900 of file guiObservers.cxx.
2901{
2902 DEBTRACE("SubjectStudyOutNode::localClean ");
2903}
References DEBTRACE.
Referenced by clean().
◆ _studyOutNode
YACS::ENGINE::StudyOutNode* YACS::HMI::SubjectStudyOutNode::_studyOutNode
Definition at line 886 of file guiObservers.hxx.
