YACS::HMI::SubjectOutputDataStreamPort Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectOutputDataStreamPort:
Collaboration diagram for YACS::HMI::SubjectOutputDataStreamPort:
 SubjectOutputDataStreamPort (YACS::ENGINE::OutputDataStreamPort *port, Subject *parent)
virtual ~SubjectOutputDataStreamPort ()
virtual TypeOfElem getType ()
void registerUndoDestroy ()
- Public Member Functions inherited from YACS::HMI::SubjectDataPort
 SubjectDataPort (YACS::ENGINE::DataPort *port, Subject *parent)
virtual ~SubjectDataPort ()
virtual YACS::ENGINE::DataPort * getPort ()
void addSubjectLink (SubjectLink *subject)
void removeSubjectLink (SubjectLink *subject)
std::list< SubjectLink * > getListOfSubjectLink ()
virtual bool setValue (std::string value)
void setExecValue (std::string value)
std::string getExecValue ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::OutputDataStreamPort * _outputDataStreamPort
- Protected Attributes inherited from YACS::HMI::SubjectDataPort
YACS::ENGINE::DataPort * _dataPort
std::string _execValue
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectDataPort
static bool tryCreateLink (SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
Definition at line 269 of file guiObservers.hxx.
◆ SubjectOutputDataStreamPort()
SubjectOutputDataStreamPort::SubjectOutputDataStreamPort ( YACS::ENGINE::OutputDataStreamPort *  port,
Subject *  parent
Definition at line 3935 of file guiObservers.cxx.
3937 : SubjectDataPort(port, parent), _outputDataStreamPort(port)
3938{
3939}
SubjectDataPort(YACS::ENGINE::DataPort *port, Subject *parent)
◆ ~SubjectOutputDataStreamPort()
SubjectOutputDataStreamPort::~SubjectOutputDataStreamPort ( )
Definition at line 3941 of file guiObservers.cxx.
3942{
3943 DEBTRACE("SubjectOutputDataStreamPort::~SubjectOutputDataStreamPort " << getName());
3944}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectDataPort::getName().
◆ clean()
void SubjectOutputDataStreamPort::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectDataPort.
Definition at line 3965 of file guiObservers.cxx.
3966{
3967 if (_askRegisterUndo)
3968 {
3969 _askRegisterUndo = false;
3971 }
3972 localclean(command);
3973 SubjectDataPort::clean(command);
3974}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectDataPort::clean(), localclean(), and registerUndoDestroy().
◆ getProperties()
std::map< std::string, std::string > SubjectOutputDataStreamPort::getProperties ( )
Definition at line 3946 of file guiObservers.cxx.
3947{
3949}
std::map< std::string, std::string > getProperties() const
References _outputDataStreamPort, and YACS::ENGINE::DataStreamPort::getProperties().
Referenced by registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectOutputDataStreamPort::getType ( )
Definition at line 278 of file guiObservers.hxx.
278{return OUTPUTDATASTREAMPORT;}
@ OUTPUTDATASTREAMPORT
References YACS::HMI::OUTPUTDATASTREAMPORT.
◆ localclean()
void SubjectOutputDataStreamPort::localclean ( Command *  command = 0)
Definition at line 3976 of file guiObservers.cxx.
3977{
3978 DEBTRACE("SubjectOutputDataStreamPort::localClean ");
3979}
References DEBTRACE.
Referenced by clean().
◆ registerUndoDestroy()
void SubjectOutputDataStreamPort::registerUndoDestroy ( )
Definition at line 3981 of file guiObservers.cxx.
3982{
3983 DEBTRACE("SubjectOutputDataStreamPort::registerUndoDestroy");
3985 map<string,string> properties = getProperties();
3986 if (properties.empty())
3987 return;
3988 Proc *proc = GuiContext::getCurrent()->getProc();
3989 SubjectNode *sno = dynamic_cast<SubjectNode*>(getParent());
3990 YASSERT(sno);
3991 Node *node = sno->getNode();
3992 string nodeName = proc->getChildName(node);
3993 string portName = getName();
3994 Command *command = new CommandSetDSPortProperties(nodeName, portName, false, properties);
3995 GuiContext::getCurrent()->getInvoc()->add(command);
3996}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
virtual std::map< std::string, std::string > getProperties()
virtual Subject * getParent()
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), getProperties(), YACS::HMI::SubjectDataPort::registerUndoDestroy(), and YASSERT.
◆ setProperties()
bool SubjectOutputDataStreamPort::setProperties ( std::map< std::string, std::string >  properties)
Definition at line 3951 of file guiObservers.cxx.
3952{
3953 Proc *proc = GuiContext::getCurrent()->getProc();
3955 new CommandSetDSPortProperties(proc->getChildName(getPort()->getNode()), getName(), false, properties);
3956 if (command->execute())
3957 {
3958 GuiContext::getCurrent()->getInvoc()->add(command);
3959 return true;
3960 }
3961 else delete command;
3962 return false;
3963}
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
virtual YACS::ENGINE::DataPort * getPort()
References YACS::HMI::Invocator::add(), YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectDataPort::getPort(), and YACS::HMI::GuiContext::getProc().
◆ _outputDataStreamPort
YACS::ENGINE::OutputDataStreamPort* YACS::HMI::SubjectOutputDataStreamPort::_outputDataStreamPort
Definition at line 281 of file guiObservers.hxx.
Referenced by getProperties().
