YACS::HMI::CommandAddODSPortFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddODSPortFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddODSPortFromCatalog:
 CommandAddODSPortFromCatalog (YACS::ENGINE::Catalog *catalog, std::string type, std::string node, std::string name)
YACS::ENGINE::OutputDataStreamPort * getODSPort ()
SubjectOutputDataStreamPort * getSubjectODSPort ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
std::string _typePort
std::string _node
YACS::ENGINE::OutputDataStreamPort * _ODSPort
SubjectOutputDataStreamPort * _sop
bool _normalReverse
Definition at line 324 of file commandsProc.hxx.
◆ CommandAddODSPortFromCatalog()
CommandAddODSPortFromCatalog::CommandAddODSPortFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  node,
std::string  name
Definition at line 1497 of file commandsProc.cxx.
1501 : Command(), _catalog(catalog), _typePort(type), _node(node), _name(name)
1502{
1503 DEBTRACE("CommandAddODSPortFromCatalog");
1504 _ODSPort = 0;
1505 _sop = 0;
1506}
References _ODSPort, _sop, and DEBTRACE.
◆ dump()
std::string CommandAddODSPortFromCatalog::dump ( )
Definition at line 1508 of file commandsProc.cxx.
1509{
1510 string ret ="CommandAddODSPortFromCatalog " + _typePort + " " + _node + " " + _name;
1511 return ret;
1512}
References _name, _node, and _typePort.
◆ getODSPort()
YACS::ENGINE::OutputDataStreamPort * CommandAddODSPortFromCatalog::getODSPort ( )
Definition at line 1514 of file commandsProc.cxx.
1515{
1516 return _ODSPort;
1517}
References _ODSPort.
◆ getSubjectODSPort()
SubjectOutputDataStreamPort * CommandAddODSPortFromCatalog::getSubjectODSPort ( )
Definition at line 1519 of file commandsProc.cxx.
1520{
1521 return _sop;
1522}
References _sop.
Referenced by YACS::HMI::SubjectElementaryNode::addODSPort().
◆ localExecute()
bool CommandAddODSPortFromCatalog::localExecute ( )
Definition at line 1524 of file commandsProc.cxx.
1525{
1526 DEBTRACE("CommandAddODSPortFromCatalog::localExecute");
1527 OutputDataStreamPort *son = 0;
1528 try
1529 {
1530 Proc* proc = GuiContext::getCurrent()->getProc();
1531 Node* node = proc->getChildByName(_node);
1532 ElementaryNode* father =dynamic_cast<ElementaryNode*> (node);
1533 if (father)
1534 {
1535 if (_catalog->_typeMap.count(_typePort))
1537 else
1538 {
1539 DEBTRACE(_typePort << " not found in catalog");
1540 GuiContext::getCurrent()->_lastErrorMessage = _typePort + " not found in catalog";
1541 }
1542 }
1543 _ODSPort = son;
1544 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1546 _sop = snode->addSubjectODSPort(son, _name);
1547 }
1548 catch (Exception& ex)
1549 {
1550 DEBTRACE("CommandAddODSPortFromCatalog::localExecute() : " << ex.what());
1551 setErrorMsg(ex);
1552 if (son) delete son;
1553 _ODSPort = 0;
1554 }
1555 return (_ODSPort != 0);
1556}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
virtual OutputDataStreamPort * edAddOutputDataStreamPort(const std::string &outputPortDSName, TypeCode *type)
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual SubjectOutputDataStreamPort * addSubjectODSPort(YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
References _catalog, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _node, _ODSPort, _sop, YACS::ENGINE::Catalog::_typeMap, _typePort, YACS::HMI::SubjectNode::addSubjectODSPort(), DEBTRACE, YACS::ENGINE::ElementaryNode::edAddOutputDataStreamPort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), and YASSERT.
◆ localReverse()
bool CommandAddODSPortFromCatalog::localReverse ( )
Definition at line 1558 of file commandsProc.cxx.
1559{
1560 DEBTRACE("CommandAddODSPortFromCatalog::localReverse");
1561 try
1562 {
1563 Proc* proc = GuiContext::getCurrent()->getProc();
1564 Node *node = proc->getChildByName(_node);
1565 ElementaryNode* enode = dynamic_cast<ElementaryNode*>(node);
1566 YASSERT(enode);
1569 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(_ODSPort));
1571 YASSERT(_sop);
1572
1573 Subject *father=_sop->getParent();
1575 _sop = 0;
1576 _ODSPort = 0;
1577 if (father)
1578 {
1579 DEBTRACE("REMOVE");
1580 father->select(true);
1581 father->update(REMOVE,0,0);
1582 }
1583 return true;
1584 }
1585 catch (Exception& ex)
1586 {
1587 DEBTRACE("CommandAddODSPortFromCatalog::localReverse(): " << ex.what());
1588 setErrorMsg(ex);
1589 return false;
1590 }
1591}
OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const
Definition: guiContext.hxx:71
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References YACS::HMI::GuiContext::_mapOfSubjectDataPort, _name, _node, _ODSPort, _sop, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ElementaryNode::getOutputDataStreamPort(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddODSPortFromCatalog::_catalog
Definition at line 337 of file commandsProc.hxx.
Referenced by localExecute().
◆ _name
std::string YACS::HMI::CommandAddODSPortFromCatalog::_name
Definition at line 340 of file commandsProc.hxx.
◆ _node
std::string YACS::HMI::CommandAddODSPortFromCatalog::_node
Definition at line 339 of file commandsProc.hxx.
◆ _ODSPort
YACS::ENGINE::OutputDataStreamPort* YACS::HMI::CommandAddODSPortFromCatalog::_ODSPort
◆ _sop
SubjectOutputDataStreamPort* YACS::HMI::CommandAddODSPortFromCatalog::_sop
◆ _typePort
std::string YACS::HMI::CommandAddODSPortFromCatalog::_typePort
Definition at line 338 of file commandsProc.hxx.
