YACS::HMI::CommandAddOutputPortFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddOutputPortFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddOutputPortFromCatalog:
 CommandAddOutputPortFromCatalog (YACS::ENGINE::Catalog *catalog, std::string type, std::string node, std::string name)
YACS::ENGINE::OutputPort * getOutputPort ()
SubjectOutputPort * getSubjectOutputPort ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
std::string _typePort
std::string _node
YACS::ENGINE::OutputPort * _outputPort
SubjectOutputPort * _sop
bool _normalReverse
Definition at line 282 of file commandsProc.hxx.
◆ CommandAddOutputPortFromCatalog()
CommandAddOutputPortFromCatalog::CommandAddOutputPortFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  node,
std::string  name
Definition at line 1298 of file commandsProc.cxx.
References _outputPort, and _sop.
◆ dump()
std::string CommandAddOutputPortFromCatalog::dump ( )
Definition at line 1308 of file commandsProc.cxx.
1309{
1310 string ret ="CommandAddOutputPortFromCatalog " + _typePort + " " + _node + " " + _name;
1311 return ret;
1312}
References _name, _node, and _typePort.
◆ getOutputPort()
YACS::ENGINE::OutputPort * CommandAddOutputPortFromCatalog::getOutputPort ( )
Definition at line 1314 of file commandsProc.cxx.
1315{
1316 return _outputPort;
1317}
References _outputPort.
◆ getSubjectOutputPort()
SubjectOutputPort * CommandAddOutputPortFromCatalog::getSubjectOutputPort ( )
Definition at line 1319 of file commandsProc.cxx.
1320{
1321 return _sop;
1322}
References _sop.
Referenced by YACS::HMI::SubjectElementaryNode::addOutputPort().
◆ localExecute()
bool CommandAddOutputPortFromCatalog::localExecute ( )
Definition at line 1324 of file commandsProc.cxx.
1325{
1326 DEBTRACE("CommandAddOutputPortFromCatalog::localExecute");
1327 OutputPort *son = 0;
1328 try
1329 {
1330 Proc* proc = GuiContext::getCurrent()->getProc();
1331 Node* node = proc->getChildByName(_node);
1332 ElementaryNode* father =dynamic_cast<ElementaryNode*> (node);
1333 if (father)
1334 {
1335 //try proc types and then catalog if not in proc
1336 if(proc->typeMap.count(_typePort))
1337 son = father->edAddOutputPort(_name, proc->typeMap[_typePort]);
1338 else if (_catalog->_typeMap.count(_typePort))
1340 else
1341 {
1342 DEBTRACE(_typePort << " not found in catalog");
1343 GuiContext::getCurrent()->_lastErrorMessage = _typePort + " not found in catalog";
1344 }
1345 }
1346 _outputPort = son;
1347 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1349 _sop = snode->addSubjectOutputPort(son, _name);
1350 snode->update(SYNCHRO,0,0); // when input port tab in node edition is visible
1351 }
1352 catch (Exception& ex)
1353 {
1354 DEBTRACE("CommandAddOutputPortFromCatalog::localExecute() : " << ex.what());
1355 setErrorMsg(ex);
1356 if (son) delete son;
1357 _outputPort = 0;
1358 }
1359 return (_outputPort != 0);
1360}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
virtual OutputPort * edAddOutputPort(const std::string &outputPortName, TypeCode *type)
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: Proc.hxx:90
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual SubjectOutputPort * addSubjectOutputPort(YACS::ENGINE::OutputPort *port, std::string name="")
References _catalog, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _node, _outputPort, _sop, YACS::ENGINE::Catalog::_typeMap, _typePort, YACS::HMI::SubjectNode::addSubjectOutputPort(), DEBTRACE, YACS::ENGINE::ElementaryNode::edAddOutputPort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SYNCHRO, YACS::ENGINE::Proc::typeMap, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandAddOutputPortFromCatalog::localReverse ( )
Definition at line 1362 of file commandsProc.cxx.
1363{
1364 DEBTRACE("CommandAddOutputPortFromCatalog::localReverse");
1365 try
1366 {
1367 Proc* proc = GuiContext::getCurrent()->getProc();
1368 Node *node = proc->getChildByName(_node);
1369 ElementaryNode* enode = dynamic_cast<ElementaryNode*>(node);
1370 YASSERT(enode);
1373 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(_outputPort));
1375 YASSERT(_sop);
1376
1377 Subject *father=_sop->getParent();
1379 _sop = 0;
1380 _outputPort = 0;
1381 if (father)
1382 {
1383 DEBTRACE("REMOVE");
1384 father->select(true);
1385 father->update(REMOVE,0,0);
1386 }
1387 return true;
1388 }
1389 catch (Exception& ex)
1390 {
1391 DEBTRACE("CommandAddOutputPortFromCatalog::localReverse(): " << ex.what());
1392 setErrorMsg(ex);
1393 return false;
1394 }
1395}
OutputPort * getOutputPort(const std::string &name) const
Definition: guiContext.hxx:71
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References YACS::HMI::GuiContext::_mapOfSubjectDataPort, _name, _node, _outputPort, _sop, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ElementaryNode::getOutputPort(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddOutputPortFromCatalog::_catalog
Definition at line 295 of file commandsProc.hxx.
Referenced by localExecute().
◆ _name
std::string YACS::HMI::CommandAddOutputPortFromCatalog::_name
Definition at line 298 of file commandsProc.hxx.
◆ _node
std::string YACS::HMI::CommandAddOutputPortFromCatalog::_node
Definition at line 297 of file commandsProc.hxx.
◆ _outputPort
YACS::ENGINE::OutputPort* YACS::HMI::CommandAddOutputPortFromCatalog::_outputPort
◆ _sop
SubjectOutputPort* YACS::HMI::CommandAddOutputPortFromCatalog::_sop
◆ _typePort
std::string YACS::HMI::CommandAddOutputPortFromCatalog::_typePort
Definition at line 296 of file commandsProc.hxx.
