YACS::HMI::SubjectPythonNode Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectPythonNode:
Collaboration diagram for YACS::HMI::SubjectPythonNode:
 SubjectPythonNode (YACS::ENGINE::PythonNode *pythonNode, Subject *parent)
virtual ~SubjectPythonNode ()
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectInlineNode
 SubjectInlineNode (YACS::ENGINE::InlineNode *inlineNode, Subject *parent)
virtual ~SubjectInlineNode ()
virtual bool setScript (std::string script)
virtual std::string getScript ()
virtual bool setContainer (SubjectContainerBase *scont)
virtual bool setExecutionMode (const std::string &mode)
- Public Member Functions inherited from YACS::HMI::SubjectElementaryNode
 SubjectElementaryNode (YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual ~SubjectElementaryNode ()
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual SubjectDataPort * addInputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addOutputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addODSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual bool OrderDataPorts (SubjectDataPort *portToMove, int isUp)
virtual void removePort (SubjectDataPort *port)
virtual void loadChildren ()
virtual void saveLinks ()
virtual void restoreLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void removeExternalControlLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::PythonNode * _pythonNode
- Protected Attributes inherited from YACS::HMI::SubjectInlineNode
YACS::ENGINE::InlineNode * _inlineNode
- Protected Attributes inherited from YACS::HMI::SubjectElementaryNode
YACS::ENGINE::ElementaryNode * _elementaryNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 707 of file guiObservers.hxx.
◆ SubjectPythonNode()
SubjectPythonNode::SubjectPythonNode ( YACS::ENGINE::PythonNode *  pythonNode,
Subject *  parent
Definition at line 2510 of file guiObservers.cxx.
2511 : SubjectInlineNode(pythonNode, parent), _pythonNode(pythonNode)
2512{
2513}
SubjectInlineNode(YACS::ENGINE::InlineNode *inlineNode, Subject *parent)
◆ ~SubjectPythonNode()
SubjectPythonNode::~SubjectPythonNode ( )
Definition at line 2515 of file guiObservers.cxx.
2516{
2517 DEBTRACE("SubjectPythonNode::~SubjectPythonNode " << getName());
2518}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectNode::getName().
◆ clean()
void SubjectPythonNode::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectInlineNode.
Definition at line 2520 of file guiObservers.cxx.
2521{
2522 if (_askRegisterUndo)
2523 {
2524 _askRegisterUndo = false;
2526 }
2527 localclean(command);
2528 SubjectInlineNode::clean(command);
2529}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectInlineNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectPythonNode::getType ( )
Definition at line 714 of file guiObservers.hxx.
714{return PYTHONNODE;}
References YACS::HMI::PYTHONNODE.
◆ localclean()
void SubjectPythonNode::localclean ( Command *  command = 0)
Definition at line 2531 of file guiObservers.cxx.
2532{
2533 DEBTRACE("SubjectPythonNode::localClean ");
2534}
References DEBTRACE.
Referenced by clean().
◆ _pythonNode
YACS::ENGINE::PythonNode* YACS::HMI::SubjectPythonNode::_pythonNode
Definition at line 716 of file guiObservers.hxx.
