YACS::HMI::CommandAddIDSPortFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddIDSPortFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddIDSPortFromCatalog:
 CommandAddIDSPortFromCatalog (YACS::ENGINE::Catalog *catalog, std::string type, std::string node, std::string name)
YACS::ENGINE::InputDataStreamPort * getIDSPort ()
SubjectInputDataStreamPort * getSubjectIDSPort ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
std::string _typePort
std::string _node
YACS::ENGINE::InputDataStreamPort * _IDSPort
SubjectInputDataStreamPort * _sip
bool _normalReverse
Definition at line 303 of file commandsProc.hxx.
◆ CommandAddIDSPortFromCatalog()
CommandAddIDSPortFromCatalog::CommandAddIDSPortFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  type,
std::string  node,
std::string  name
Definition at line 1399 of file commandsProc.cxx.
1403 : Command(), _catalog(catalog), _typePort(type), _node(node), _name(name)
1404{
1405 _IDSPort = 0;
1406 _sip = 0;
1407}
References _IDSPort, and _sip.
◆ dump()
std::string CommandAddIDSPortFromCatalog::dump ( )
Definition at line 1409 of file commandsProc.cxx.
1410{
1411 string ret ="CommandAddIDSPortFromCatalog " + _typePort + " " + _node + " " + _name;
1412 return ret;
1413}
References _name, _node, and _typePort.
◆ getIDSPort()
YACS::ENGINE::InputDataStreamPort * CommandAddIDSPortFromCatalog::getIDSPort ( )
Definition at line 1415 of file commandsProc.cxx.
1416{
1417 DEBTRACE("CommandAddIDSPortFromCatalog");
1418 return _IDSPort;
1419}
References _IDSPort, and DEBTRACE.
◆ getSubjectIDSPort()
SubjectInputDataStreamPort * CommandAddIDSPortFromCatalog::getSubjectIDSPort ( )
Definition at line 1421 of file commandsProc.cxx.
1422{
1423 return _sip;
1424}
References _sip.
Referenced by YACS::HMI::SubjectElementaryNode::addIDSPort().
◆ localExecute()
bool CommandAddIDSPortFromCatalog::localExecute ( )
Definition at line 1426 of file commandsProc.cxx.
1427{
1428 DEBTRACE("CommandAddIDSPortFromCatalog::localExecute");
1429 InputDataStreamPort *son = 0;
1430 try
1431 {
1432 Proc* proc = GuiContext::getCurrent()->getProc();
1433 Node* node = proc->getChildByName(_node);
1434 ElementaryNode* father =dynamic_cast<ElementaryNode*> (node);
1435 if (father)
1436 {
1437 if (_catalog->_typeMap.count(_typePort))
1439 else
1440 {
1441 DEBTRACE(_typePort << " not found in catalog");
1442 GuiContext::getCurrent()->_lastErrorMessage = _typePort + " not found in catalog";
1443 }
1444 }
1445 _IDSPort = son;
1446 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1448 _sip = snode->addSubjectIDSPort(son, _name);
1449 }
1450 catch (Exception& ex)
1451 {
1452 DEBTRACE("CommandAddIDSPortFromCatalog::localExecute() : " << ex.what());
1453 setErrorMsg(ex);
1454 if (son) delete son;
1455 _IDSPort = 0;
1456 }
1457 return (_IDSPort != 0);
1458}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
virtual InputDataStreamPort * edAddInputDataStreamPort(const std::string &inputPortDSName, TypeCode *type)
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual SubjectInputDataStreamPort * addSubjectIDSPort(YACS::ENGINE::InputDataStreamPort *port, std::string name="")
References _catalog, _IDSPort, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _name, _node, _sip, YACS::ENGINE::Catalog::_typeMap, _typePort, YACS::HMI::SubjectNode::addSubjectIDSPort(), DEBTRACE, YACS::ENGINE::ElementaryNode::edAddInputDataStreamPort(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), and YASSERT.
◆ localReverse()
bool CommandAddIDSPortFromCatalog::localReverse ( )
Definition at line 1460 of file commandsProc.cxx.
1461{
1462 DEBTRACE("CommandAddIDSPortFromCatalog::localReverse");
1463 try
1464 {
1465 Proc* proc = GuiContext::getCurrent()->getProc();
1466 Node *node = proc->getChildByName(_node);
1467 ElementaryNode* enode = dynamic_cast<ElementaryNode*>(node);
1468 YASSERT(enode);
1471 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(_IDSPort));
1473 YASSERT(_sip);
1474
1475 Subject *father=_sip->getParent();
1477 _IDSPort =0;
1478 _sip = 0;
1479 if (father)
1480 {
1481 DEBTRACE("REMOVE");
1482 father->select(true);
1483 father->update(REMOVE,0,0);
1484 }
1485 return true;
1486 }
1487 catch (Exception& ex)
1488 {
1489 DEBTRACE("CommandAddIDSPortFromCatalog::localReverse(): " << ex.what());
1490 setErrorMsg(ex);
1491 return false;
1492 }
1493}
InputDataStreamPort * getInputDataStreamPort(const std::string &name) const
Definition: guiContext.hxx:71
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References _IDSPort, YACS::HMI::GuiContext::_mapOfSubjectDataPort, _name, _node, _sip, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ElementaryNode::getInputDataStreamPort(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddIDSPortFromCatalog::_catalog
Definition at line 316 of file commandsProc.hxx.
Referenced by localExecute().
◆ _IDSPort
YACS::ENGINE::InputDataStreamPort* YACS::HMI::CommandAddIDSPortFromCatalog::_IDSPort
◆ _name
std::string YACS::HMI::CommandAddIDSPortFromCatalog::_name
Definition at line 319 of file commandsProc.hxx.
◆ _node
std::string YACS::HMI::CommandAddIDSPortFromCatalog::_node
Definition at line 318 of file commandsProc.hxx.
◆ _sip
SubjectInputDataStreamPort* YACS::HMI::CommandAddIDSPortFromCatalog::_sip
◆ _typePort
std::string YACS::HMI::CommandAddIDSPortFromCatalog::_typePort
Definition at line 317 of file commandsProc.hxx.
