YACS::HMI::CommandOrderOutputPorts Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandOrderOutputPorts:
Collaboration diagram for YACS::HMI::CommandOrderOutputPorts:
 CommandOrderOutputPorts (std::string node, std::string port, int isUp)
int getRank ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _node
std::string _port
int _isUp
int _rank
bool _normalReverse
Definition at line 362 of file commandsProc.hxx.
◆ CommandOrderOutputPorts()
CommandOrderOutputPorts::CommandOrderOutputPorts ( std::string  node,
std::string  port,
int  isUp
move up or down a port in the list of ports of a node. if isUp = 0, move down one step, if isUp = n>0, move up n steps.
Definition at line 1756 of file commandsProc.cxx.
1759 : Command(), _node(node), _port(port), _isUp(isUp), _rank(-1)
1760{
1761 DEBTRACE("CommandOrderOutputPorts");
1762}
References DEBTRACE.
◆ dump()
std::string CommandOrderOutputPorts::dump ( )
Definition at line 1764 of file commandsProc.cxx.
1765{
1766 ostringstream s;
1767 s << _isUp;
1768 string ret ="CommandOrderOutputPorts " + _node + " " + _port + " " + s.str();
1769 return ret;
1770}
References _isUp, _node, and _port.
◆ getRank()
int YACS::HMI::CommandOrderOutputPorts::getRank ( )
Definition at line 368 of file commandsProc.hxx.
368{return _rank; };
References _rank.
◆ localExecute()
bool CommandOrderOutputPorts::localExecute ( )
Definition at line 1772 of file commandsProc.cxx.
1773{
1774 DEBTRACE("CommandOrderOutputPorts::localExecute " << _node << " " << _port << " " << _isUp);
1775 ElementaryNode* father = 0;
1776 try
1777 {
1778 Proc* proc = GuiContext::getCurrent()->getProc();
1779 Node* node = proc->getChildByName(_node);
1780 father = dynamic_cast<ElementaryNode*> (node);
1781 if (!father) return false;
1782 OutputPort *portToMove = father->getOutputPort(_port);
1783 DEBTRACE(portToMove->getName());
1784
1785 list<OutputPort*> plist = father->getSetOfOutputPort();
1786 list<OutputPort*>::iterator pos = find(plist.begin(), plist.end(), portToMove);
1787
1788 int isUp = _isUp;
1789 if (isUp)
1790 {
1791 if(pos == plist.begin())
1792 pos=plist.end(); // --- cycle
1793 else
1794 do { pos--; isUp--; } while (isUp);
1795 }
1796 else
1797 {
1798 pos++;
1799 if (pos == plist.end())
1800 pos = plist.begin(); // --- cycle
1801 else
1802 pos++; // --- insert before the 2nd next port
1803 }
1804
1805 OutputPort *portBefore = 0;
1806 if (pos != plist.end())
1807 portBefore = (*pos);
1808
1809 plist.remove(portToMove);
1810 if (portBefore)
1811 {
1812 DEBTRACE(portBefore->getName());
1813 pos = find(plist.begin(), plist.end(), portBefore);
1814 _rank = 0;
1815 for (list<OutputPort*>::iterator it = plist.begin(); it != pos; ++it)
1816 _rank++;
1817 plist.insert(pos, portToMove);
1818 }
1819 else
1820 {
1821 _rank = plist.size();
1822 plist.push_back(portToMove);
1823 }
1824 father->edOrderOutputPorts(plist);
1825 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1828 snode->update(ORDER, false, sport);
1829 snode->update(SYNCHRO, false, sport); // --- synchronise edition and scene
1830 }
1831 catch (Exception& ex)
1832 {
1833 DEBTRACE("CommandOrderOutputPorts::localExecute() : " << ex.what());
1834 setErrorMsg(ex);
1835 father = 0;
1836 }
1837 return (father != 0);
1838}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::string getName() const
Definition: DataPort.hxx:55
std::list< OutputPort * > getSetOfOutputPort() const
OutputPort * getOutputPort(const std::string &name) const
virtual void edOrderOutputPorts(const std::list< OutputPort * > &ports)
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:71
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
References _isUp, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _node, _port, _rank, DEBTRACE, YACS::ENGINE::ElementaryNode::edOrderOutputPorts(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::ElementaryNode::getOutputPort(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::HMI::ORDER, setErrorMsg(), YACS::HMI::SYNCHRO, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandOrderOutputPorts::localReverse ( )
Definition at line 1840 of file commandsProc.cxx.
1841{
1842 DEBTRACE("CommandOrderOutputPorts::localReverse " << _node << " " << _port << " " << _isUp);
1843 ElementaryNode* father = 0;
1844 try
1845 {
1846 int isUpRev = -_isUp;
1847 if (isUpRev == 0) isUpRev =1;
1848 Proc* proc = GuiContext::getCurrent()->getProc();
1849 Node* node = proc->getChildByName(_node);
1850 father = dynamic_cast<ElementaryNode*> (node);
1851 if (!father) return false;
1852 OutputPort *portToMove = father->getOutputPort(_port);
1853 DEBTRACE(portToMove->getName());
1854
1855 list<OutputPort*> plist = father->getSetOfOutputPort();
1856 list<OutputPort*>::iterator pos = find(plist.begin(), plist.end(), portToMove);
1857
1858 if (isUpRev>0)
1859 {
1860 if(pos == plist.begin())
1861 pos=plist.end(); // --- cycle
1862 else
1863 do { pos--; isUpRev--; } while (isUpRev);
1864 }
1865 else
1866 {
1867 pos++;
1868 if (pos == plist.end())
1869 pos = plist.begin(); // --- cycle
1870 else
1871 do { pos++; isUpRev++; } while (isUpRev<0);// --- insert before the 2nd next port
1872 }
1873
1874 OutputPort *portBefore = 0;
1875 if (pos != plist.end())
1876 portBefore = (*pos);
1877
1878 plist.remove(portToMove);
1879 if (portBefore)
1880 {
1881 DEBTRACE(portBefore->getName());
1882 pos = find(plist.begin(), plist.end(), portBefore);
1883 _rank = 0;
1884 for (list<OutputPort*>::iterator it = plist.begin(); it != pos; ++it)
1885 _rank++;
1886 plist.insert(pos, portToMove);
1887 }
1888 else
1889 {
1890 _rank = plist.size();
1891 plist.push_back(portToMove);
1892 }
1893 father->edOrderOutputPorts(plist);
1894 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
1897 snode->update(ORDER, false, sport);
1898 snode->update(SYNCHRO, false, sport); // --- synchronise edition and scene
1899 }
1900 catch (Exception& ex)
1901 {
1902 DEBTRACE("CommandOrderOutputPorts::localExecute() : " << ex.what());
1903 setErrorMsg(ex);
1904 father = 0;
1905 }
1906 return (father != 0);
1907}
◆ _isUp
int YACS::HMI::CommandOrderOutputPorts::_isUp
Definition at line 375 of file commandsProc.hxx.
◆ _node
std::string YACS::HMI::CommandOrderOutputPorts::_node
Definition at line 373 of file commandsProc.hxx.
◆ _port
std::string YACS::HMI::CommandOrderOutputPorts::_port
Definition at line 374 of file commandsProc.hxx.
◆ _rank
int YACS::HMI::CommandOrderOutputPorts::_rank
Definition at line 376 of file commandsProc.hxx.
Referenced by getRank(), localExecute(), and localReverse().
