YACS::HMI::SubjectSplitterNode Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectSplitterNode:
Collaboration diagram for YACS::HMI::SubjectSplitterNode:
 SubjectSplitterNode (YACS::ENGINE::SplitterNode *splitterNode, Subject *parent)
virtual ~SubjectSplitterNode ()
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectElementaryNode
 SubjectElementaryNode (YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual ~SubjectElementaryNode ()
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual SubjectDataPort * addInputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addOutputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addODSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual bool OrderDataPorts (SubjectDataPort *portToMove, int isUp)
virtual void removePort (SubjectDataPort *port)
virtual void loadChildren ()
virtual void saveLinks ()
virtual void restoreLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void removeExternalControlLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::SplitterNode * _splitterNode
- Protected Attributes inherited from YACS::HMI::SubjectElementaryNode
YACS::ENGINE::ElementaryNode * _elementaryNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 817 of file guiObservers.hxx.
◆ SubjectSplitterNode()
SubjectSplitterNode::SubjectSplitterNode ( YACS::ENGINE::SplitterNode *  splitterNode,
Subject *  parent
Definition at line 2727 of file guiObservers.cxx.
2728 : SubjectElementaryNode(splitterNode, parent), _splitterNode(splitterNode)
2729{
2730 _destructible = false;
2731}
SubjectElementaryNode(YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
References YACS::HMI::Subject::_destructible.
◆ ~SubjectSplitterNode()
SubjectSplitterNode::~SubjectSplitterNode ( )
Definition at line 2733 of file guiObservers.cxx.
2734{
2735 DEBTRACE("SubjectSplitterNode::~SubjectSplitterNode " << getName());
2736}
virtual std::string getName()
References DEBTRACE, and getName().
◆ clean()
void SubjectSplitterNode::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectElementaryNode.
Definition at line 2738 of file guiObservers.cxx.
2739{
2740 if (_askRegisterUndo)
2741 {
2742 _askRegisterUndo = false;
2744 }
2745 localclean(command);
2747}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectElementaryNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ getName()
std::string SubjectSplitterNode::getName ( )
Reimplemented from YACS::HMI::SubjectNode.
Definition at line 2755 of file guiObservers.cxx.
2756{
2757 return "splitter";
2758}
Referenced by ~SubjectSplitterNode().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectSplitterNode::getType ( )
Definition at line 825 of file guiObservers.hxx.
825{return SPLITTERNODE;}
References YACS::HMI::SPLITTERNODE.
◆ localclean()
void SubjectSplitterNode::localclean ( Command *  command = 0)
Definition at line 2749 of file guiObservers.cxx.
2750{
2751 DEBTRACE("SubjectSplitterNode::localClean ");
2752}
References DEBTRACE.
Referenced by clean().
◆ _splitterNode
YACS::ENGINE::SplitterNode* YACS::HMI::SubjectSplitterNode::_splitterNode
Definition at line 827 of file guiObservers.hxx.
