YACS::HMI::EditionOptimizerLoop Class Reference
#include <EditionOptimizerLoop.hxx>
Inheritance diagram for YACS::HMI::EditionOptimizerLoop:
Collaboration diagram for YACS::HMI::EditionOptimizerLoop:
Public Slots
virtual void onModifyInitFile ()
virtual void onModifyEntry ()
virtual void onModifyLib ()
virtual void onNbBranchesEdited ()
virtual void onApply ()
virtual void onCancel ()
 EditionOptimizerLoop (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionOptimizerLoop ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
FormOptimizerLoop * _formOptimizerLoop
int _nbBranches
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 31 of file EditionOptimizerLoop.hxx.
◆ EditionOptimizerLoop()
EditionOptimizerLoop::EditionOptimizerLoop ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 39 of file EditionOptimizerLoop.cxx.
42 : EditionNode(subject, parent, name)
43{
45 _nbBranches = 1;
46 _wid->gridLayout1->addWidget(_formOptimizerLoop);
47 _formOptimizerLoop->sb_nbranch->setMinimum(1);
48 _formOptimizerLoop->sb_nbranch->setMaximum(INT_MAX);
49
50 connect(_formOptimizerLoop->sb_nbranch, SIGNAL(editingFinished()),
51 this, SLOT(onNbBranchesEdited()));
52 connect(_formOptimizerLoop->lineEdit_initValue, SIGNAL(editingFinished()),
53 this, SLOT(onModifyInitFile()));
54 connect(_formOptimizerLoop->lineEdit_entry, SIGNAL(editingFinished()),
55 this, SLOT(onModifyEntry()));
56 connect(_formOptimizerLoop->lineEdit_lib, SIGNAL(editingFinished()),
57 this, SLOT(onModifyLib()));
58}
WidEditItem * _wid
EditionNode(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionNode.cxx:35
References _formOptimizerLoop, _nbBranches, FormEditItem::_wid, onModifyEntry(), onModifyInitFile(), onModifyLib(), and onNbBranchesEdited().
◆ ~EditionOptimizerLoop()
EditionOptimizerLoop::~EditionOptimizerLoop ( )
Definition at line 60 of file EditionOptimizerLoop.cxx.
61{
62}
◆ onModifyEntry
void EditionOptimizerLoop::onModifyEntry ( )
virtualslot
Definition at line 75 of file EditionOptimizerLoop.cxx.
76{
77 DEBTRACE("EditionOptimizerLoop::onModifyEntry");
78 OptimizerLoop *oloop = dynamic_cast<OptimizerLoop*>(_subjectNode->getNode());
79 if (oloop->getSymbol() == _formOptimizerLoop->lineEdit_entry->text().toStdString()) return;
80
81 bool isOk = false;
83 isOk=ol->setAlgorithm(_formOptimizerLoop->lineEdit_lib->text().toStdString(),
84 _formOptimizerLoop->lineEdit_entry->text().toStdString());
85 if(!isOk)
86 Message mess;
87 DEBTRACE(isOk);
88}
virtual std::string getSymbol() const
Definition: EditionNode.hxx:48
virtual bool setAlgorithm(const std::string &alglib, const std::string &symbol)
References _formOptimizerLoop, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::HMI::SubjectNode::getNode(), YACS::ENGINE::OptimizerLoop::getSymbol(), and YACS::HMI::SubjectOptimizerLoop::setAlgorithm().
Referenced by EditionOptimizerLoop().
◆ onModifyInitFile
void EditionOptimizerLoop::onModifyInitFile ( )
virtualslot
Definition at line 64 of file EditionOptimizerLoop.cxx.
65{
66 bool isOk = false;
67 Node* node=_subjectNode->getNode();
68 OptimizerLoop *ol = dynamic_cast<OptimizerLoop*>(node);
69 InputPort * dp = ol->edGetAlgoInitPort();
71 isOk=sdp->setValue(_formOptimizerLoop->lineEdit_initValue->text().toStdString());
72 DEBTRACE(isOk);
73}
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Definition: guiContext.hxx:71
virtual bool setValue(std::string value)
References _formOptimizerLoop, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::ENGINE::OptimizerLoop::edGetAlgoInitPort(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::SubjectDataPort::setValue().
◆ onModifyLib
void EditionOptimizerLoop::onModifyLib ( )
virtualslot
Definition at line 90 of file EditionOptimizerLoop.cxx.
91{
92 DEBTRACE("EditionOptimizerLoop::onModifyLib");
93 OptimizerLoop *oloop = dynamic_cast<OptimizerLoop*>(_subjectNode->getNode());
94 if(oloop->getAlgLib() == _formOptimizerLoop->lineEdit_lib->text().toStdString()) return;
95
96 bool isOk = false;
98 isOk=ol->setAlgorithm(_formOptimizerLoop->lineEdit_lib->text().toStdString(),
99 _formOptimizerLoop->lineEdit_entry->text().toStdString());
100 if (!isOk && !_formOptimizerLoop->lineEdit_lib->text().isEmpty() &&
101 !_formOptimizerLoop->lineEdit_entry->text().isEmpty())
102 Message mess;
103 DEBTRACE(isOk);
104}
virtual std::string getAlgLib() const
Return the name of the algorithm library.
References _formOptimizerLoop, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::ENGINE::OptimizerLoop::getAlgLib(), YACS::HMI::SubjectNode::getNode(), and YACS::HMI::SubjectOptimizerLoop::setAlgorithm().
◆ onNbBranchesEdited
void EditionOptimizerLoop::onNbBranchesEdited ( )
virtualslot
Definition at line 106 of file EditionOptimizerLoop.cxx.
107{
108 int newval = _formOptimizerLoop->sb_nbranch->value();
109 DEBTRACE("EditionOptimizerLoop::onNbBranchesEdited " << _nbBranches << " --> " << newval);
110 if (newval != _nbBranches)
111 {
113 YASSERT(sol);
114 QString text = _formOptimizerLoop->sb_nbranch->cleanText();
115 sol->setNbBranches(text.toStdString());
116 }
117}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual bool setNbBranches(std::string nbBranches)
References _formOptimizerLoop, _nbBranches, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::SubjectDynParaLoop::setNbBranches(), and YASSERT.
◆ synchronize()
void EditionOptimizerLoop::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 119 of file EditionOptimizerLoop.cxx.
120{
122}
References YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ update()
void EditionOptimizerLoop::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Definition at line 124 of file EditionOptimizerLoop.cxx.
125{
126 DEBTRACE("EditionOptimizerLoop::update " << eventName(event) << " " << type);
127 EditionNode::update(event, type, son);
128 switch (event)
129 {
130 case SETVALUE:
131 // Nb branches
132 SubjectComposedNode * scn = dynamic_cast<SubjectComposedNode*>(_subject);
133 string val = scn->getValue();
134 istringstream ss(val);
135 DEBTRACE( val);
136 int i = 0;
137 ss >> i;
138 DEBTRACE(i);
139 _formOptimizerLoop->sb_nbranch->setValue(i);
140 _nbBranches = i;
141
142 OptimizerLoop * ol = dynamic_cast<OptimizerLoop *>(_subjectNode->getNode());
143
144 // Algo init value
145 InputPort * dp = ol->edGetAlgoInitPort();
146 _formOptimizerLoop->lineEdit_initValue->setText(dp->getAsString().c_str());
147
148 // Algo library and entry
149 _formOptimizerLoop->lineEdit_entry->setText(QString::fromStdString(ol->getSymbol()));
150 _formOptimizerLoop->lineEdit_lib->setText(QString::fromStdString(ol->getAlgLib()));
151
152 // Type names
153 _formOptimizerLoop->label_evalSampleType->setText(ol->edGetSamplePort()->edGetType()->name());
154 _formOptimizerLoop->label_evalResultType->setText(ol->edGetPortForOutPool()->edGetType()->name());
155 _formOptimizerLoop->label_algoInitType->setText(ol->edGetAlgoInitPort()->edGetType()->name());
156 _formOptimizerLoop->label_algoResultType->setText(ol->edGetAlgoResultPort()->edGetType()->name());
157 break;
158 }
159}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.cxx:84
OutputPort * edGetSamplePort()
Definition: DynParaLoop.hxx:90
OutputPort * edGetAlgoResultPort()
Definition: TypeCode.cxx:72
Definition: EditionNode.cxx:64
virtual std::string getValue()
References _formOptimizerLoop, _nbBranches, YACS::HMI::ItemEditionBase::_subject, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::ENGINE::OptimizerLoop::edGetAlgoInitPort(), YACS::ENGINE::OptimizerLoop::edGetAlgoResultPort(), YACS::ENGINE::OptimizerLoop::edGetPortForOutPool(), YACS::ENGINE::DynParaLoop::edGetSamplePort(), YACS::ENGINE::DataPort::edGetType(), YACS::HMI::GuiObserver::eventName(), YACS::ENGINE::OptimizerLoop::getAlgLib(), YACS::ENGINE::DataPort::getAsString(), YACS::HMI::SubjectNode::getNode(), YACS::ENGINE::OptimizerLoop::getSymbol(), YACS::HMI::SubjectComposedNode::getValue(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::TypeCode::name(), YACS::HMI::SETVALUE, and YACS::HMI::EditionNode::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _formOptimizerLoop
FormOptimizerLoop* YACS::HMI::EditionOptimizerLoop::_formOptimizerLoop
◆ _nbBranches
int YACS::HMI::EditionOptimizerLoop::_nbBranches
Definition at line 51 of file EditionOptimizerLoop.hxx.
Referenced by EditionOptimizerLoop(), onNbBranchesEdited(), and update().
