YACS::HMI::EditionSwitch Class Reference
#include <EditionSwitch.hxx>
Inheritance diagram for YACS::HMI::EditionSwitch:
Collaboration diagram for YACS::HMI::EditionSwitch:
Public Slots
virtual void onModifySelect (const QString &text)
virtual void onCommitData (QWidget *editor)
virtual void onApply ()
virtual void onCancel ()
 EditionSwitch (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionSwitch ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionBloc
 EditionBloc (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionBloc ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
TableSwitch * _tvSwitch
ValueDelegate * _valueDelegate
- Protected Attributes inherited from YACS::HMI::EditionBloc
PropertyEditor * _propeditor
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 34 of file EditionSwitch.hxx.
◆ EditionSwitch()
EditionSwitch::EditionSwitch ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 38 of file EditionSwitch.cxx.
41 : EditionBloc(subject, parent, name)
42{
43 _tvSwitch = new TableSwitch(this);
44 _wid->gridLayout1->addWidget(_tvSwitch);
46 _tvSwitch->tv_nodes->setModel(model);
47 _tvSwitch->sb_select->setMinimum(INT_MIN);
48 _tvSwitch->sb_select->setMaximum(INT_MAX);
49 connect(_tvSwitch->sb_select, SIGNAL(valueChanged(const QString &)),
50 this, SLOT(onModifySelect(const QString &)));
51
52 _valueDelegate = new ValueDelegate(parent);
53 _tvSwitch->tv_nodes->setItemDelegateForColumn(YValue, _valueDelegate);
55 if (!QtGuiContext::getQtCurrent()->isEdition())
56 _tvSwitch->setEnabled (false);
57
58 connect(_valueDelegate, SIGNAL(commitData(QWidget*)),
59 this, SLOT(onCommitData(QWidget*)));
60}
WidEditItem * _wid
EditionBloc(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionBloc.cxx:31
virtual void onModifySelect(const QString &text)
virtual void onCommitData(QWidget *editor)
virtual void setEditableCase(bool isEditable)
Definition: TableSwitch.cxx:45
References _tvSwitch, _valueDelegate, FormEditItem::_wid, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), onCommitData(), onModifySelect(), YACS::HMI::TableSwitch::setEditableCase(), and YACS::HMI::YValue.
◆ ~EditionSwitch()
EditionSwitch::~EditionSwitch ( )
Definition at line 62 of file EditionSwitch.cxx.
63{
64}
◆ onCommitData
void EditionSwitch::onCommitData ( QWidget *  editor)
virtualslot
Definition at line 122 of file EditionSwitch.cxx.
123{
124 DEBTRACE("EditionSwitch::onCommitData " << editor);
125 GenericEditor* gedit = dynamic_cast<GenericEditor*>(editor);
126 YASSERT(gedit);
127 QString val = gedit->GetStrValue();
128 DEBTRACE(val.toStdString());
129 Subject *sub = gedit->getSubject();
130 YASSERT(sub);
131 SubjectNode *snode = dynamic_cast<SubjectNode*>(sub);
132 YASSERT(snode);
133 sub = snode->getParent();
134 SubjectSwitch *sswitch = dynamic_cast<SubjectSwitch*>(sub);
135 YASSERT(sswitch);
136 bool isOk = sswitch->setCase(val.toStdString(), snode);
137 if (_valueDelegate)
138 _valueDelegate->setResultEditing(editor, isOk);
139
140}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual Subject * getSubject()
virtual QString GetStrValue()
virtual bool setCase(std::string caseId, SubjectNode *snode)
virtual Subject * getParent()
virtual void setResultEditing(QWidget *editor, bool isOk)
References _valueDelegate, DEBTRACE, YACS::HMI::Subject::getParent(), YACS::HMI::GenericEditor::GetStrValue(), YACS::HMI::GenericEditor::getSubject(), YACS::HMI::SubjectSwitch::setCase(), YACS::HMI::ValueDelegate::setResultEditing(), and YASSERT.
Referenced by EditionSwitch().
◆ onModifySelect
void EditionSwitch::onModifySelect ( const QString &  text)
virtualslot
Definition at line 91 of file EditionSwitch.cxx.
92{
93 DEBTRACE("EditionSwitch::onModifySelect " << text.toStdString());
94 SubjectSwitch *sswitch = dynamic_cast<SubjectSwitch*>(_subject);
95 YASSERT(sswitch);
96 sswitch->setSelect(text.toStdString());
97}
virtual bool setSelect(std::string select)
References YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::SubjectSwitch::setSelect(), and YASSERT.
◆ synchronize()
void EditionSwitch::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 66 of file EditionSwitch.cxx.
67{
68 DEBTRACE("EditionSwitch::synchronize");
71 if (schemaItem)
72 {
73 QModelIndex parentIndex = schemaItem->modelIndex();
74 _tvSwitch->tv_nodes->setRootIndex(parentIndex);
75 int numRows = model->rowCount(parentIndex);
76 for (int row = 0; row < numRows; ++row)
77 {
78 QModelIndex index = model->index(row, 0, parentIndex);
79 SchemaItem *childItem = static_cast<SchemaItem*>(index.internalPointer());
80 bool hidden = true;
81 if (Subject *sub = childItem->getSubject())
82 if (dynamic_cast<SubjectNode*>(sub))
83 hidden = false;
84 _tvSwitch->tv_nodes->setRowHidden(row, hidden);
85 }
86 }
89}
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
Definition: SchemaItem.cxx:169
Definition: SchemaItem.cxx:253
virtual QModelIndex index(int row, int column, const QModelIndex &parent=QModelIndex()) const
Definition: SchemaModel.cxx:60
virtual int rowCount(const QModelIndex &parent=QModelIndex()) const
Definition: SchemaModel.cxx:92
virtual void adjustColumns()
Definition: TableSwitch.cxx:57
References YACS::HMI::QtGuiContext::_mapOfSchemaItem, YACS::HMI::ItemEditionBase::_subject, _tvSwitch, YACS::HMI::TableSwitch::adjustColumns(), DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::SchemaModel::index(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::SchemaModel::rowCount(), YACS::HMI::SETSELECT, and YACS::HMI::Subject::update().
◆ update()
void EditionSwitch::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionBloc.
Definition at line 99 of file EditionSwitch.cxx.
100{
101 DEBTRACE("EditionSwitch::update " <<eventName(event) << " " << type);
102 switch (event)
103 {
104
105 case SETSELECT:
106 {
107 SubjectComposedNode *scn = dynamic_cast<SubjectComposedNode*>(_subject);
108 string val = scn->getValue();
109 istringstream ss(val);
110 DEBTRACE(val);
111 int i = 0;
112 ss >> i;
113 DEBTRACE(i);
114 _tvSwitch->sb_select->setValue(i);
115 }
116 break;
117 default:
118 EditionBloc::update(event, type, son);
119 }
120}
Definition: EditionBloc.cxx:44
virtual std::string getValue()
References YACS::HMI::ItemEditionBase::_subject, _tvSwitch, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::SubjectComposedNode::getValue(), yacsorb.CORBAEngineTest::i, YACS::HMI::SETSELECT, and YACS::HMI::EditionBloc::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _tvSwitch
TableSwitch* YACS::HMI::EditionSwitch::_tvSwitch
Definition at line 51 of file EditionSwitch.hxx.
Referenced by EditionSwitch(), synchronize(), and update().
◆ _valueDelegate
ValueDelegate* YACS::HMI::EditionSwitch::_valueDelegate
Definition at line 52 of file EditionSwitch.hxx.
Referenced by EditionSwitch(), and onCommitData().
