YACS::HMI::SchemaModel Class Reference
#include <SchemaModel.hxx>
Inheritance diagram for YACS::HMI::SchemaModel:
Collaboration diagram for YACS::HMI::SchemaModel:
Public Slots
void updateSelection (const QItemSelection &selected, const QItemSelection &deselected)
Signals
void signalSelection (const QModelIndex &index)
 SchemaModel (YACS::HMI::Subject *context, QObject *parent=0)
virtual ~SchemaModel ()
virtual QModelIndex index (int row, int column, const QModelIndex &parent=QModelIndex()) const
virtual QModelIndex parent (const QModelIndex &index) const
virtual int rowCount (const QModelIndex &parent=QModelIndex()) const
virtual int columnCount (const QModelIndex &parent=QModelIndex()) const
virtual QVariant data (const QModelIndex &index, int role=Qt::DisplayRole) const
virtual QVariant headerData (int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const
virtual bool setData (const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
virtual Qt::ItemFlags flags (const QModelIndex &index) const
SchemaItem * getRootItem ()
bool isEdition ()
void setEdition (bool isEdition=true)
const QBrush & stdBackBrush ()
const QBrush & editedBackBrush ()
const QBrush & emphasizeBackBrush ()
virtual QMimeData * mimeData (const QModelIndexList &indexes) const
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action, int row, int column, const QModelIndex &parent)
virtual Qt::DropActions supportedDropActions () const
virtual QStringList mimeTypes () const
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
void setNewRoot (YACS::HMI::Subject *root)
Subject * _context
Subject * _root
SchemaItem * _rootItem
QBrush _stdBackBrush
QBrush _editedBackBrush
QBrush _emphasizeBackBrush
bool _isEdition
bool _destructible
Friends
class SchemaItem
class SchemaNodeItem
class SchemaComposedNodeItem
class SchemaDirTypesItem
class SchemaDirLinksItem
class SchemaDirContainersItem
class SchemaContainerItem
class SchemaComponentItem
static void setEventMap ()
Definition at line 49 of file SchemaModel.hxx.
◆ SchemaModel()
SchemaModel::SchemaModel ( YACS::HMI::Subject *  context,
QObject *  parent = 0
Definition at line 39 of file SchemaModel.cxx.
40 :
42{
43 DEBTRACE("SchemaModel::SchemaModel");
44 _context=context;
45 _root=0;
46 _rootItem=0;
47 _context->attach(this);
48 _stdBackBrush = QColor("white");
49 _editedBackBrush = QColor("yellow");
50 _emphasizeBackBrush = QColor("magenta");
51 _isEdition = true;
52}
virtual QModelIndex parent(const QModelIndex &index) const
Definition: SchemaModel.cxx:80
virtual void attach(GuiObserver *obs)
References _context, _editedBackBrush, _emphasizeBackBrush, _isEdition, _root, _rootItem, _stdBackBrush, YACS::HMI::Subject::attach(), and DEBTRACE.
◆ ~SchemaModel()
SchemaModel::~SchemaModel ( )
Definition at line 54 of file SchemaModel.cxx.
55{
56 DEBTRACE("SchemaModel::~SchemaModel");
57 _subjectSet.clear(); // --- avoid destruction loop on delete context
58}
std::set< Subject * > _subjectSet
References YACS::HMI::GuiObserver::_subjectSet, and DEBTRACE.
◆ columnCount()
int SchemaModel::columnCount ( const QModelIndex &  parent = QModelIndex()) const
Definition at line 107 of file SchemaModel.cxx.
108{
109 //DEBTRACE("SchemaModel::columnCount " << parent.isValid());
110 if (parent.isValid())
111 return static_cast<SchemaItem*>(parent.internalPointer())->columnCount();
112 if (_rootItem)
113 {
114 if (_isEdition) return 3;
115 else return 3; //_rootItem->columnCount();
116 }
117 else
118 return 0;
119}
virtual int columnCount(const QModelIndex &parent=QModelIndex()) const
References _isEdition, _rootItem, columnCount(), and parent().
Referenced by columnCount().
◆ data()
QVariant SchemaModel::data ( const QModelIndex &  index,
int  role = Qt::DisplayRole
Definition at line 121 of file SchemaModel.cxx.
122{
123 //DEBTRACE("SchemaModel::data");
124 if (!index.isValid())
125 return QVariant();
126 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
127 return item->data(index.column(), role);
128}
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
virtual QModelIndex index(int row, int column, const QModelIndex &parent=QModelIndex()) const
Definition: SchemaModel.cxx:60
References YACS::HMI::SchemaItem::data(), and index().
Referenced by dropMimeData().
◆ dropMimeData()
bool SchemaModel::dropMimeData ( const QMimeData *  data,
int  row,
int  column,
Definition at line 274 of file SchemaModel.cxx.
276{
277 DEBTRACE("SchemaModel::dropMimeData");
278 if (action == Qt::IgnoreAction)
279 return true;
280
281 string name = "empty";
282 SchemaItem *item = 0;
283 if (parent.isValid())
284 {
285 item = static_cast<SchemaItem*>(parent.internalPointer());
286 name = item->getSubject()->getName();
287 }
288 DEBTRACE(row << " " << column << " "<< name);
289
290 if ((row >= 0) && (column >=0))
291 {
292 QModelIndex ind = index(row, column, parent);
293 if (!ind.isValid())
294 return false;
295 DEBTRACE("---");
296 item = static_cast<SchemaItem*>(ind.internalPointer());
297 }
298 if (!item)
299 return false;
300 return item->dropMimeData(data, action);
301}
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
virtual bool dropMimeData(const QMimeData *data, Qt::DropAction action)
Definition: SchemaItem.cxx:284
virtual QVariant data(const QModelIndex &index, int role=Qt::DisplayRole) const
virtual std::string getName()
References data(), DEBTRACE, YACS::HMI::SchemaItem::dropMimeData(), YACS::HMI::Subject::getName(), YACS::HMI::SchemaItem::getSubject(), index(), and parent().
◆ editedBackBrush()
const QBrush & SchemaModel::editedBackBrush ( )
Definition at line 240 of file SchemaModel.cxx.
241{
242 return _editedBackBrush;
243}
References _editedBackBrush.
Referenced by YACS::HMI::SchemaItem::update().
◆ emphasizeBackBrush()
const QBrush & SchemaModel::emphasizeBackBrush ( )
Definition at line 245 of file SchemaModel.cxx.
246{
247 return _emphasizeBackBrush;
248}
References _emphasizeBackBrush.
◆ flags()
Qt::ItemFlags SchemaModel::flags ( const QModelIndex &  index) const
Definition at line 182 of file SchemaModel.cxx.
183{
184 //DEBTRACE("SchemaModel::flags");
185 if (!index.isValid())
186 return 0;
187 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
188 return item->flags(index);
189}
virtual Qt::ItemFlags flags(const QModelIndex &index)
Definition: SchemaItem.cxx:149
References YACS::HMI::SchemaItem::flags(), and index().
◆ getRootItem()
SchemaItem * YACS::HMI::SchemaModel::getRootItem ( )
Definition at line 78 of file SchemaModel.hxx.
78{return _rootItem; };
References _rootItem.
Referenced by YACS::HMI::SchemaItem::modelIndex().
◆ headerData()
QVariant SchemaModel::headerData ( int  section,
Definition at line 130 of file SchemaModel.cxx.
131{
132 //DEBTRACE("SchemaModel::headerData");
133 if (role != Qt::DisplayRole)
134 return QVariant();
135
136 if (orientation == Qt::Horizontal)
137 //return QString("Colonne %1").arg(section);
138 if (_isEdition)
139 switch (section)
140 {
141 case YLabel: return QString("Name");
142 case YType: return QString("Type");
143 case YValue: return QString("Value");
144 default: return QString("- %1 -").arg(section);
145 }
146 else
147 switch (section)
148 {
149 case YLabel: return QString("Name");
150 case YType: return QString("Type");
151 case YState: return QString("State");
152 default: return QString("- %1 -").arg(section);
153 }
154 else
155 return QVariant();
156}
References _isEdition, YACS::HMI::YLabel, YACS::HMI::YState, YACS::HMI::YType, and YACS::HMI::YValue.
◆ index()
QModelIndex SchemaModel::index ( int  row,
int  column,
Definition at line 60 of file SchemaModel.cxx.
61{
62 // DEBTRACE("SchemaModel::index");
63 if (!hasIndex(row, column, parent))
64 return QModelIndex();
65
66 SchemaItem *parentItem = 0;
67
68 if (!parent.isValid())
69 parentItem = _rootItem;
70 else
71 parentItem = static_cast<SchemaItem*>(parent.internalPointer());
72
73 SchemaItem *childItem = parentItem->child(row);
74 if (childItem)
75 return createIndex(row, column, childItem);
76 else
77 return QModelIndex();
78}
virtual SchemaItem * child(int row)
Definition: SchemaItem.cxx:105
References _rootItem, YACS::HMI::SchemaItem::child(), and parent().
Referenced by YACS::HMI::EditionElementaryNode::createTablePorts(), data(), dropMimeData(), flags(), mimeData(), YACS::HMI::SchemaItem::modelIndex(), parent(), setData(), YACS::HMI::EditionElementaryNode::synchronize(), YACS::HMI::EditionSwitch::synchronize(), and updateSelection().
◆ isEdition()
bool YACS::HMI::SchemaModel::isEdition ( )
◆ mimeData()
QMimeData * SchemaModel::mimeData ( const QModelIndexList &  indexes) const
Definition at line 258 of file SchemaModel.cxx.
259{
260 DEBTRACE("SchemaModel::mimeData");
261 ItemMimeData *mime = new ItemMimeData;
262 mime->setSubject(_root);
263
264 if (indexes.empty())
265 return mime;
266 QModelIndex index = indexes.first();
267 if (!index.isValid())
268 return mime;
269 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
270 DEBTRACE("mimeData valid index");
271 return item->mimeData(mime);
272}
virtual void setSubject(Subject *sub)
virtual ItemMimeData * mimeData(ItemMimeData *mime)
Definition: SchemaItem.cxx:276
References _root, DEBTRACE, index(), YACS::HMI::SchemaItem::mimeData(), and YACS::HMI::ItemMimeData::setSubject().
◆ mimeTypes()
QStringList SchemaModel::mimeTypes ( ) const
Definition at line 309 of file SchemaModel.cxx.
310{
311 //DEBTRACE("SchemaModel::mimeTypes");
312 QStringList types;
313 types << "yacs/subject" << "yacs/subjectNode" << "yacs/subjectOutPort"
314 << "yacs/cataService" << "yacs/cataType" << "yacs/cataNode"
315 << "yacs/subjectOutGate";
316 return types;
317}
◆ parent()
QModelIndex SchemaModel::parent ( const QModelIndex &  index) const
Definition at line 80 of file SchemaModel.cxx.
81{
82 // DEBTRACE("SchemaModel::parent");
83 if (!index.isValid())
84 return QModelIndex();
85 SchemaItem *childItem = static_cast<SchemaItem*>(index.internalPointer());
86 SchemaItem *parentItem = childItem->parent();
87 if (parentItem == _rootItem)
88 return QModelIndex();
89 return createIndex(parentItem->row(), 0, parentItem);
90}
virtual int row() const
Definition: SchemaItem.cxx:154
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
References _rootItem, index(), YACS::HMI::SchemaItem::parent(), and YACS::HMI::SchemaItem::row().
Referenced by columnCount(), dropMimeData(), index(), rowCount(), and gui.Appli.Runner::run().
◆ rowCount()
int SchemaModel::rowCount ( const QModelIndex &  parent = QModelIndex()) const
Definition at line 92 of file SchemaModel.cxx.
93{
94 //DEBTRACE("SchemaModel::rowCount");
95 SchemaItem *parentItem;
96 if (parent.column() > 0)
97 return 0;
98 if (!parent.isValid())
99 parentItem = _rootItem;
100 else
101 parentItem = static_cast<SchemaItem*>(parent.internalPointer());
102 if (parentItem)
103 return parentItem->childCount();
104 else return 0;
105}
virtual int childCount() const
Definition: SchemaItem.cxx:111
References _rootItem, YACS::HMI::SchemaItem::childCount(), and parent().
Referenced by YACS::HMI::EditionElementaryNode::synchronize(), and YACS::HMI::EditionSwitch::synchronize().
◆ setData()
bool SchemaModel::setData ( const QModelIndex &  index,
const QVariant &  value,
int  role = Qt::EditRole
For EditRole, setData only emit dataChanged signal, actual modification is done in SchemaItem.
Definition at line 162 of file SchemaModel.cxx.
163{
164 DEBTRACE("SchemaModel::setData");
165 if (index.isValid() && role == Qt::EditRole)
166 {
167 DEBTRACE("Qt::EditRole, emit dataChanged");
168 emit dataChanged(index, index);
169 return true;
170 }
171 if (index.isValid() && role == Qt::CheckStateRole)
172 {
173 DEBTRACE("Qt::CheckStateRole, toggle state");
174 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
175 item->toggleState();
176 emit dataChanged(index, index);
177 return true;
178 }
179 return false;
180}
virtual void toggleState()
Definition: SchemaItem.cxx:239
References DEBTRACE, index(), and YACS::HMI::SchemaItem::toggleState().
Referenced by YACS::HMI::SchemaComposedNodeItem::SchemaComposedNodeItem(), YACS::HMI::SchemaComposedNodeItem::setCaseValue(), YACS::HMI::SchemaNodeItem::setCaseValue(), YACS::HMI::ItemEdition::setEdited(), YACS::HMI::SchemaComposedNodeItem::update(), YACS::HMI::SchemaInPortItem::update(), YACS::HMI::SchemaItem::update(), YACS::HMI::SchemaNodeItem::update(), YACS::HMI::SchemaOutPortItem::update(), and YACS::HMI::SchemaReferenceItem::update().
◆ setEdition()
void SchemaModel::setEdition ( bool  isEdition = true)
Definition at line 230 of file SchemaModel.cxx.
231{
233}
References _isEdition, and isEdition().
Referenced by YACS::HMI::GenericGui::createContext().
◆ setNewRoot()
void SchemaModel::setNewRoot ( YACS::HMI::Subject *  root)
Definition at line 250 of file SchemaModel.cxx.
251{
252 _root = root;
253 QString name = _root->getName().c_str();
255 SchemaProcItem *procItem = new SchemaProcItem(_rootItem, name, _root);
256}
friend class SchemaItem
Definition: SchemaModel.hxx:53
References _root, _rootItem, YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), and SchemaItem.
Referenced by update().
◆ signalSelection
void YACS::HMI::SchemaModel::signalSelection ( const QModelIndex &  index)
signal
Referenced by updateSelection().
◆ stdBackBrush()
const QBrush & SchemaModel::stdBackBrush ( )
Definition at line 235 of file SchemaModel.cxx.
236{
237 return _stdBackBrush;
238}
References _stdBackBrush.
◆ supportedDropActions()
Qt::DropActions SchemaModel::supportedDropActions ( ) const
Definition at line 303 of file SchemaModel.cxx.
304{
305 //DEBTRACE("SchemaModel::supportedDropActions");
306 return Qt::CopyAction | Qt::MoveAction | Qt::LinkAction;
307}
◆ update()
void SchemaModel::update ( GuiEvent  event,
int  type,
Subject *  son
Reimplemented from YACS::HMI::GuiObserver.
Definition at line 192 of file SchemaModel.cxx.
193{
194 DEBTRACE("SchemaModel::update "<<eventName(event)<<" "<<type<<" "<<son);
195 switch (event)
196 {
198 setNewRoot(son);
199 break;
200// default:
201// DEBTRACE("SchemaModel::update(), event not handled: "<< eventName(event));
202 }
203}
void setNewRoot(YACS::HMI::Subject *root)
References DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::NEWROOT, and setNewRoot().
Referenced by gui.graph.MyCanvas::customEvent().
◆ updateSelection
void SchemaModel::updateSelection ( const QItemSelection &  selected,
const QItemSelection &  deselected
slot
Definition at line 205 of file SchemaModel.cxx.
207{
208 DEBTRACE("SchemaModel::updateSelection");
209 QModelIndex index;
210 QModelIndexList items = selected.indexes();
211
212 foreach (index, items)
213 {
214 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
215 DEBTRACE("updateSelection select "<< item->getSubject()->getName());
216 item->getSubject()->select(true);
217 emit signalSelection(index);
218 }
219
220 items = deselected.indexes();
221
222 foreach (index, items)
223 {
224 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
225 DEBTRACE("updateSelection deselect "<< item->getSubject()->getName());
226 item->getSubject()->select(false);
227 }
228}
void signalSelection(const QModelIndex &index)
virtual void select(bool isSelected)
References DEBTRACE, YACS::HMI::Subject::getName(), YACS::HMI::SchemaItem::getSubject(), index(), YACS::HMI::Subject::select(), and signalSelection().
◆ SchemaComponentItem
friend class SchemaComponentItem
friend
Definition at line 60 of file SchemaModel.hxx.
◆ SchemaComposedNodeItem
friend class SchemaComposedNodeItem
friend
Definition at line 55 of file SchemaModel.hxx.
◆ SchemaContainerItem
friend class SchemaContainerItem
friend
Definition at line 59 of file SchemaModel.hxx.
◆ SchemaDirContainersItem
friend class SchemaDirContainersItem
friend
Definition at line 58 of file SchemaModel.hxx.
◆ SchemaDirLinksItem
friend class SchemaDirLinksItem
friend
Definition at line 57 of file SchemaModel.hxx.
◆ SchemaDirTypesItem
friend class SchemaDirTypesItem
friend
Definition at line 56 of file SchemaModel.hxx.
◆ SchemaItem
friend
Definition at line 53 of file SchemaModel.hxx.
Referenced by setNewRoot().
◆ SchemaNodeItem
friend class SchemaNodeItem
friend
Definition at line 54 of file SchemaModel.hxx.
◆ _context
Subject* YACS::HMI::SchemaModel::_context
Definition at line 101 of file SchemaModel.hxx.
Referenced by SchemaModel().
◆ _editedBackBrush
QBrush YACS::HMI::SchemaModel::_editedBackBrush
Definition at line 106 of file SchemaModel.hxx.
Referenced by editedBackBrush(), and SchemaModel().
◆ _emphasizeBackBrush
QBrush YACS::HMI::SchemaModel::_emphasizeBackBrush
Definition at line 107 of file SchemaModel.hxx.
Referenced by emphasizeBackBrush(), and SchemaModel().
◆ _isEdition
bool YACS::HMI::SchemaModel::_isEdition
Definition at line 108 of file SchemaModel.hxx.
Referenced by columnCount(), headerData(), isEdition(), SchemaModel(), and setEdition().
◆ _root
Subject* YACS::HMI::SchemaModel::_root
Definition at line 102 of file SchemaModel.hxx.
Referenced by mimeData(), SchemaModel(), and setNewRoot().
◆ _rootItem
SchemaItem* YACS::HMI::SchemaModel::_rootItem
Definition at line 103 of file SchemaModel.hxx.
Referenced by columnCount(), getRootItem(), index(), parent(), rowCount(), SchemaModel(), and setNewRoot().
◆ _stdBackBrush
QBrush YACS::HMI::SchemaModel::_stdBackBrush
Definition at line 105 of file SchemaModel.hxx.
Referenced by SchemaModel(), and stdBackBrush().
