YACS::HMI::SchemaDirTypesItem Class Reference
#include <SchemaDirTypesItem.hxx>
Inheritance diagram for YACS::HMI::SchemaDirTypesItem:
Collaboration diagram for YACS::HMI::SchemaDirTypesItem:
 SchemaDirTypesItem (SchemaItem *parent, QString label, Subject *subject)
void addTypeItem (Subject *subject)
void removeTypeItem (Subject *subject)
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaDirTypesItem.hxx.
◆ SchemaDirTypesItem()
SchemaDirTypesItem::SchemaDirTypesItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 37 of file SchemaDirTypesItem.cxx.
38 : SchemaItem(parent, label, subject)
39{
40 _itemDeco.replace(YLabel, QIcon("icons:folder_cyan.png"));
41}
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
References YACS::HMI::SchemaItem::_itemDeco, and YACS::HMI::YLabel.
◆ addTypeItem()
void SchemaDirTypesItem::addTypeItem ( Subject *  subject)
Definition at line 43 of file SchemaDirTypesItem.cxx.
44{
45 DEBTRACE("SchemaDirTypesItem::addTypeItem");
47 int nbsons = childCount();
48 SubjectDataType *sdt = dynamic_cast<SubjectDataType*>(subject);
49 YASSERT(sdt);
50 DEBTRACE(nbsons);
51 model->beginInsertRows(modelIndex(), nbsons, nbsons);
52 SchemaItem *item = new SchemaDataTypeItem(this,
53 sdt->getAlias().c_str(),
54 sdt);
55 model->endInsertRows();
56}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: SchemaItem.cxx:253
virtual int childCount() const
Definition: SchemaItem.cxx:111
virtual std::string getAlias()
References YACS::HMI::SchemaItem::childCount(), DEBTRACE, YACS::HMI::SubjectDataType::getAlias(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::modelIndex(), and YASSERT.
Referenced by YACS::HMI::SchemaComposedNodeItem::update().
◆ dropMimeData()
bool SchemaDirTypesItem::dropMimeData ( const QMimeData *  data,
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 77 of file SchemaDirTypesItem.cxx.
78{
79 DEBTRACE("SchemaDirTypesItem::dropMimeData");
80 if (!data) return false;
81 const ItemMimeData* myData = dynamic_cast<const ItemMimeData*>(data);
82 if (!myData) return false;
83 bool ret =false;
84 if (myData->hasFormat("yacs/cataType"))
85 {
86 ret =true;
88 }
89 return ret;
90}
YACS::HMI::GuiEditor * _guiEditor
Definition: GenericGui.hxx:201
void AddTypeFromCatalog(const ItemMimeData *myData)
Definition: GuiEditor.cxx:203
YACS::HMI::GenericGui * getGMain()
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
References YACS::HMI::GenericGui::_guiEditor, YACS::HMI::GuiEditor::AddTypeFromCatalog(), YACS::HMI::SchemaItem::data(), DEBTRACE, YACS::HMI::QtGuiContext::getGMain(), and YACS::HMI::QtGuiContext::getQtCurrent().
◆ editionWhatsThis()
QVariant SchemaDirTypesItem::editionWhatsThis ( int  column) const
Definition at line 92 of file SchemaDirTypesItem.cxx.
93{
94return "All the Data types required in this schema must be in this folder.\n" \
95 "You can add data types here by import from catalogs " \
96 "(builtin catalog, session catalog, or a catalog built from another schema).\n" \
97 "To add a data type, drag a data type item from catalogs panel and drop it here.";
98}
◆ flags()
Qt::ItemFlags SchemaDirTypesItem::flags ( const QModelIndex &  index)
Definition at line 71 of file SchemaDirTypesItem.cxx.
72{
73 //DEBTRACE("SchemaDirTypesItem::flags");
74 return Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsDropEnabled;
75}
◆ removeTypeItem()
void SchemaDirTypesItem::removeTypeItem ( Subject *  subject)
Definition at line 58 of file SchemaDirTypesItem.cxx.
59{
60 DEBTRACE("SchemaDirTypesItem::removeTypeItem");
62 YASSERT(QtGuiContext::getQtCurrent()->_mapOfSchemaItem.count(subject));
64 int position = toRemove->row();
65 DEBTRACE(position);
66 model->beginRemoveRows(modelIndex(), position, position);
67 removeChild(toRemove);
68 model->endRemoveRows();
69}
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
virtual int row() const
Definition: SchemaItem.cxx:154
virtual void removeChild(SchemaItem *child)
Definition: SchemaItem.cxx:93
References YACS::HMI::QtGuiContext::_mapOfSchemaItem, DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::SchemaItem::removeChild(), YACS::HMI::SchemaItem::row(), and YASSERT.
