YACS::HMI::SchemaDirLinksItem Class Reference
#include <SchemaDirLinksItem.hxx>
Inheritance diagram for YACS::HMI::SchemaDirLinksItem:
Collaboration diagram for YACS::HMI::SchemaDirLinksItem:
 SchemaDirLinksItem (SchemaItem *parent, QString label, Subject *subject)
void addLinkItem (Subject *subject)
virtual Qt::ItemFlags flags (const QModelIndex &index)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaDirLinksItem.hxx.
◆ SchemaDirLinksItem()
SchemaDirLinksItem::SchemaDirLinksItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 36 of file SchemaDirLinksItem.cxx.
37 : SchemaItem(parent, label, subject)
38{
39 _itemDeco.replace(YLabel, QIcon("icons:folder_cyan.png"));
40}
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
References YACS::HMI::SchemaItem::_itemDeco, and YACS::HMI::YLabel.
◆ addLinkItem()
void SchemaDirLinksItem::addLinkItem ( Subject *  subject)
Definition at line 42 of file SchemaDirLinksItem.cxx.
43{
44 DEBTRACE("SchemaDirLinksItem::addTypeItem");
46 int nbsons = childCount();
47 model->beginInsertRows(modelIndex(), nbsons, nbsons);
48 SchemaItem *item = new SchemaLinkItem(this,
49 subject->getName().c_str(),
50 subject);
51 model->endInsertRows();
52}
Definition: SchemaItem.cxx:253
virtual int childCount() const
Definition: SchemaItem.cxx:111
virtual std::string getName()
References YACS::HMI::SchemaItem::childCount(), DEBTRACE, YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), and YACS::HMI::SchemaItem::modelIndex().
Referenced by YACS::HMI::SchemaComposedNodeItem::update().
◆ editionWhatsThis()
QVariant SchemaDirLinksItem::editionWhatsThis ( int  column) const
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 60 of file SchemaDirLinksItem.cxx.
61{
62return "<p>Links between ports or nodes under that block level appears in this folder.\n" \
63 "You can add data links (between ports) and control links (between nodes) " \
64 "by drag from origin (out node or out port) to destination (in node or in port) " \
65 "either in 2D graphic view or tree view. <a href=\"modification.html#create-a-link\">More...</a></p>";
66}
◆ flags()
Qt::ItemFlags SchemaDirLinksItem::flags ( const QModelIndex &  index)
Definition at line 54 of file SchemaDirLinksItem.cxx.
55{
56 //DEBTRACE("SchemaDirLinksItem::flags");
57 return Qt::ItemIsEnabled | Qt::ItemIsSelectable;
58}
