SchemaDirLinksItem.cxx
1
// Copyright (C) 2006-2026 CEA, EDF
2
3
// This library is free software; you can redistribute it and/or
4
// modify it under the terms of the GNU Lesser General Public
5
// License as published by the Free Software Foundation; either
6
// version 2.1 of the License, or (at your option) any later version.
7
8
// This library is distributed in the hope that it will be useful,
9
// but WITHOUT ANY WARRANTY; without even the implied warranty of
10
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11
// Lesser General Public License for more details.
12
13
// You should have received a copy of the GNU Lesser General Public
14
// License along with this library; if not, write to the Free Software
15
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16
17
// See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18
20
SchemaDirLinksItem.hxx
21
SchemaLinkItem.hxx
SchemaModel.hxx
23
QtGuiContext.hxx
24
GuiEditor.hxx
26
#include <QIcon>
27
#include <cassert>
28
//#define _DEVDEBUG_
30
YacsTrace.hxx
31
32
using namespace
std;
33
using namespace
YACS::ENGINE
34
using namespace
YACS::HMI
35
36
SchemaDirLinksItem::SchemaDirLinksItem(
SchemaItem
*parent, QString label,
Subject
* subject)
37
SchemaItem
(parent, label, subject)
38
39
_itemDeco
.replace(
YLabel
, QIcon(
"icons:folder_cyan.png"
40
41
42
void
SchemaDirLinksItem::addLinkItem
Subject
* subject)
43
44
DEBTRACE
"SchemaDirLinksItem::addTypeItem"
45
SchemaModel
*model =
QtGuiContext::getQtCurrent
getSchemaModel
46
int
nbsons =
childCount
47
model->beginInsertRows(
modelIndex
(), nbsons, nbsons);
48
SchemaItem
*item =
new
SchemaLinkItem
this
49
subject->
getName
().c_str(),
50
subject);
51
model->endInsertRows();
52
53
54
Qt::ItemFlags
SchemaDirLinksItem::flags
const
QModelIndex &index)
55
56
//DEBTRACE("SchemaDirLinksItem::flags");
57
return
Qt::ItemIsEnabled | Qt::ItemIsSelectable;
58
59
60
QVariant
SchemaDirLinksItem::editionWhatsThis
int
column)
const
61
62
return
"<p>Links between ports or nodes under that block level appears in this folder.\n"
63
"You can add data links (between ports) and control links (between nodes) "
64
"by drag from origin (out node or out port) to destination (in node or in port) "
65
"either in 2D graphic view or tree view. <a href=\"modification.html#create-a-link\">More...</a></p>"
66
67
GuiEditor.hxx
QtGuiContext.hxx
SchemaLinkItem.hxx
SchemaModel.hxx
YacsTrace.hxx
DEBTRACE
Definition:
YacsTrace.hxx:31
YACS::HMI::QtGuiContext::getSchemaModel
Definition:
QtGuiContext.hxx:57
YACS::HMI::QtGuiContext::getQtCurrent
Definition:
QtGuiContext.hxx:92
YACS::HMI::SchemaDirLinksItem::addLinkItem
void addLinkItem(Subject *subject)
Definition:
SchemaDirLinksItem.cxx:42
YACS::HMI::SchemaDirLinksItem::flags
virtual Qt::ItemFlags flags(const QModelIndex &index)
Definition:
SchemaDirLinksItem.cxx:54
YACS::HMI::SchemaDirLinksItem::editionWhatsThis
virtual QVariant editionWhatsThis(int column) const
Definition:
SchemaDirLinksItem.cxx:60
YACS::HMI::SchemaItem
Definition:
SchemaItem.hxx:37
YACS::HMI::SchemaItem::modelIndex
Definition:
SchemaItem.cxx:253
YACS::HMI::SchemaItem::_itemDeco
QList< QVariant > _itemDeco
Definition:
SchemaItem.hxx:78
YACS::HMI::SchemaItem::childCount
virtual int childCount() const
Definition:
SchemaItem.cxx:111
YACS::HMI::SchemaLinkItem
Definition:
SchemaLinkItem.hxx:30
Definition:
SchemaModel.hxx:50
YACS::HMI::Subject
Definition:
guiObservers.hxx:118
YACS::HMI::Subject::getName
virtual std::string getName()
Definition:
guiObservers.cxx:160
YACS::ENGINE
Definition:
AbstractPoint.hxx:37
YACS::HMI
Definition:
commands.hxx:37
YACS::HMI::YLabel
@ YLabel
Definition:
SchemaModel.hxx:35
genericgui
