YACS::HMI::SchemaNodeItem Class Reference
#include <SchemaNodeItem.hxx>
Inheritance diagram for YACS::HMI::SchemaNodeItem:
Collaboration diagram for YACS::HMI::SchemaNodeItem:
 SchemaNodeItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaNodeItem ()
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void toggleState ()
virtual void setCaseValue ()
 used in node derived classes More...
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual void reparent (SchemaItem *parent)
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QString getMimeFormat ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual void setExecState (int execState)
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaNodeItem.hxx.
◆ SchemaNodeItem()
SchemaNodeItem::SchemaNodeItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 45 of file SchemaNodeItem.cxx.
46 : SchemaItem(parent, label, subject)
47{
48 DEBTRACE("SchemaNodeItem::SchemaNodeItem");
49 _itemDeco.replace(YLabel, QIcon("icons:node.png"));
51 if (!model->isEdition())
52 {
53 _itemCheckState.replace(YLabel, Qt::Unchecked);
55 }
57}
virtual void setExecState(int execState)
Definition: SchemaItem.cxx:338
Definition: SchemaItem.hxx:81
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
virtual void setCaseValue()
@ UNDEFINED
Definition: define.hxx:35
References YACS::HMI::SchemaItem::_itemCheckState, YACS::HMI::SchemaItem::_itemDeco, DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaModel::isEdition(), setCaseValue(), YACS::HMI::SchemaItem::setExecState(), YACS::UNDEFINED, and YACS::HMI::YLabel.
◆ ~SchemaNodeItem()
SchemaNodeItem::~SchemaNodeItem ( )
Definition at line 59 of file SchemaNodeItem.cxx.
60{
61 DEBTRACE("SchemaNodeItem::~SchemaNodeItem");
62}
References DEBTRACE.
◆ dropMimeData()
bool SchemaNodeItem::dropMimeData ( const QMimeData *  data,
drop in nodes are used for control link
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 237 of file SchemaNodeItem.cxx.
238{
239 DEBTRACE("SchemaNodeItem::dropMimeData");
240 if (!data) return false;
241 const ItemMimeData* myData = dynamic_cast<const ItemMimeData*>(data);
242 if (!myData) return false;
243 if(!myData->hasFormat("yacs/subjectOutGate")) return false;
244
245 Subject *subFrom = myData->getSubject();
246 if (!subFrom) return false;
247 SubjectNode* from = dynamic_cast<SubjectNode*>(subFrom);
248
249 SubjectNode *to = dynamic_cast<SubjectNode*>(getSubject());
250 if (!to) return false;
251
252 bool ret =false;
253 if (from && to)
254 {
255 ret =true;
256 if (!SubjectNode::tryCreateLink(from, to))
257 Message mess;
258 }
259 return ret;
260}
virtual Subject * getSubject(int i=0) const
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
static bool tryCreateLink(SubjectNode *subOutNode, SubjectNode *subInNode)
References YACS::HMI::SchemaItem::data(), DEBTRACE, YACS::HMI::SchemaItem::getSubject(), YACS::HMI::ItemMimeData::getSubject(), and YACS::HMI::SubjectNode::tryCreateLink().
◆ editionWhatsThis()
QVariant SchemaNodeItem::editionWhatsThis ( int  column) const
Definition at line 282 of file SchemaNodeItem.cxx.
283{
284 return "<p>To edit the node properties, select the node and use the input panel. <a href=\"modification.html#property-page-for-node\">More...</a></p>";
285}
◆ flags()
Qt::ItemFlags SchemaNodeItem::flags ( const QModelIndex &  index)
Definition at line 185 of file SchemaNodeItem.cxx.
186{
187 Qt::ItemFlags pflag = Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsUserCheckable | Qt::ItemIsDropEnabled;
189 return pflag;
190
191 if (QtGuiContext::getQtCurrent()->isEdition())
192 pflag = pflag | Qt::ItemIsDragEnabled;
193 Qt::ItemFlags flagEdit = 0;
194 int column = index.column();
195 switch (column)
196 {
197 case YValue:
198 flagEdit = Qt::ItemIsEditable; // --- item value editable in model view (for node case in switch)
199 break;
200 }
201
202 return pflag | flagEdit;
203}
References YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::YValue.
◆ getMimeFormat()
QString SchemaNodeItem::getMimeFormat ( )
drag for nodes in tree are used for control link with Left Mouse Button and for reparent with Middle Mouse Button
Definition at line 209 of file SchemaNodeItem.cxx.
210{
211 if (QApplication::mouseButtons() == Qt::MidButton)
212 return "yacs/subjectNode";
213 else
214 return "yacs/subjectOutGate";
215}
◆ popupMenu()
void SchemaNodeItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 179 of file SchemaNodeItem.cxx.
180{
182 m.popupMenu(caller, globalPos);
183}
References gui.GraphViewer::m.
◆ setCaseValue()
void SchemaNodeItem::setCaseValue ( )
Definition at line 262 of file SchemaNodeItem.cxx.
263{
264 DEBTRACE("SchemaNodeItem::setCaseValue");
266 SubjectSwitch *sSwitch = dynamic_cast<SubjectSwitch*>(sub);
267 if (!sSwitch) return;
268
270 Switch *aSwitch = dynamic_cast<Switch*>(sSwitch->getNode());
271 YASSERT(aSwitch);
272 SubjectNode *sNode = dynamic_cast<SubjectNode*>(_subject);
273 YASSERT(sNode);
274 int rank = aSwitch->getRankOfNode(sNode->getNode());
275 if (rank == Switch::ID_FOR_DEFAULT_NODE)
276 _itemData.replace(YValue, "default");
277 else
278 _itemData.replace(YValue, rank);
279 model->setData(modelIndex(YValue), 0);
280}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: Switch.hxx:85
int getRankOfNode(Node *node) const
Definition: Switch.cxx:752
Definition: SchemaItem.cxx:253
Definition: SchemaItem.hxx:85
Definition: SchemaItem.hxx:77
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_parentItem, YACS::HMI::SchemaItem::_subject, DEBTRACE, YACS::HMI::SubjectNode::getNode(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::ENGINE::Switch::getRankOfNode(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::SchemaModel::setData(), YASSERT, and YACS::HMI::YValue.
Referenced by SchemaNodeItem().
◆ toggleState()
void SchemaNodeItem::toggleState ( )
Definition at line 217 of file SchemaNodeItem.cxx.
218{
219 DEBTRACE("SchemaNodeItem::toggleState");
222 YASSERT(guiExec);
223 SubjectNode *subjectNode = dynamic_cast<SubjectNode*>(getSubject());
224 YASSERT(subjectNode);
225 string nodeName = QtGuiContext::getQtCurrent()->getProc()->getChildName(subjectNode->getNode());
226 DEBTRACE("nodeName=" << nodeName);
227
228 if (_itemCheckState.value(YLabel) == Qt::Checked) // already toggled
229 guiExec->addBreakpoint(nodeName);
230 else
231 guiExec->removeBreakpoint(nodeName);
232}
Definition: guiContext.hxx:50
void removeBreakpoint(std::string breakpoint)
void addBreakpoint(std::string breakpoint)
YACS::HMI::GuiExecutor * getGuiExecutor()
virtual void toggleState()
Definition: SchemaItem.cxx:239
References YACS::HMI::SchemaItem::_itemCheckState, YACS::HMI::GuiExecutor::addBreakpoint(), DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::QtGuiContext::getGuiExecutor(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::GuiContext::getProc(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::GuiExecutor::removeBreakpoint(), YACS::HMI::SchemaItem::toggleState(), YASSERT, and YACS::HMI::YLabel.
◆ update()
void SchemaNodeItem::update ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 64 of file SchemaNodeItem.cxx.
65{
66 DEBTRACE("SchemaNodeItem::update "<<eventName(event)<<" "<<type<<" "<<son);
68 SchemaItem *item = 0;
69 SubjectNode *snode = 0;
70 Node* node = 0;
71 switch (event)
72 {
73 case YACS::HMI::ADD:
74 switch (type)
75 {
78 {
79 int nbsons = childCount();
80 model->beginInsertRows(modelIndex(), nbsons, nbsons);
81 item = new SchemaInPortItem(this,
82 son->getName().c_str(),
83 son);
84 model->endInsertRows();
85 }
86 break;
89 {
90 int nbsons = childCount();
91 model->beginInsertRows(modelIndex(), nbsons, nbsons);
92 item = new SchemaOutPortItem(this,
93 son->getName().c_str(),
94 son);
95 model->endInsertRows();
96 }
97 break;
98// default:
99// DEBTRACE("SchemaNodeItem::update(), ADD, type not handled: " << type);
100 }
101 break;
102 case YACS::HMI::ORDER:
103 {
104 YASSERT(QtGuiContext::getQtCurrent()->_mapOfSchemaItem.count(son));
105 //bool isInput = dynamic_cast<SubjectInputPort*>(son);
106
107 snode = dynamic_cast<SubjectNode*>(_subject);
108 YASSERT(snode);
109 Node* node = snode->getNode();
110 ElementaryNode* father = dynamic_cast<ElementaryNode*>(node);
111 YASSERT(father);
112 int nbChildren = childCount();
113
114 model->beginRemoveRows(modelIndex(), 0, nbChildren-1);
115 for (int i = nbChildren; i >= 0; i--)
117 model->endRemoveRows();
118
119 list<InputPort*> plisti = father->getSetOfInputPort();
120 int nbIn = plisti.size();
121 if (nbIn)
122 {
123 model->beginInsertRows(modelIndex(), 0, nbIn-1);
124 list<InputPort*>::iterator iti = plisti.begin();
125 for(; iti != plisti.end(); iti++)
126 {
129 appendChild(item);
130 }
131 model->endInsertRows();
132 }
133
134 list<OutputPort*> plisto = father->getSetOfOutputPort();
135 int nbOut = plisto.size();
136 if (nbOut)
137 {
138 model->beginInsertRows(modelIndex(), nbIn, nbIn + nbOut -1);
139 list<OutputPort*>::iterator ito = plisto.begin();
140 for(; ito != plisto.end(); ito++)
141 {
144 appendChild(item);
145 }
146 model->endInsertRows();
147 }
148 }
149 break;
151 snode = dynamic_cast<SubjectNode*>(_subject);
152 YASSERT(snode);
153 node = snode->getNode();
154 YASSERT(node);
155 switch (node->getState())
156 {
157 case YACS::INVALID:
158 _itemForeground.replace(YLabel, QColor("red"));
159 model->setData(modelIndex(YLabel), 0); // --- to emit dataChanged signal
160 break;
161 case YACS::READY:
162 _itemForeground.replace(YLabel, QColor("blue"));
163 model->setData(modelIndex(YLabel), 0);
164 break;
165 default:
166 break;
167 }
168 break;
170 setExecState(type);
171 model->setData(modelIndex(YState), 0);
172 break;
173 default:
174 //DEBTRACE("SchemaNodeItem::update(), event not handled: " << eventName(event));
175 SchemaItem::update(event, type, son);
176 }
177}
std::list< OutputPort * > getSetOfOutputPort() const
Base class for all nodes.
Definition: Node.hxx:70
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
Definition: guiContext.hxx:71
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
virtual void appendChild(SchemaItem *child)
Definition: SchemaItem.cxx:87
Definition: SchemaItem.cxx:174
virtual SchemaItem * child(int row)
Definition: SchemaItem.cxx:105
Definition: SchemaItem.hxx:79
virtual void removeChild(SchemaItem *child)
Definition: SchemaItem.cxx:93
virtual int childCount() const
Definition: SchemaItem.cxx:111
virtual std::string getName()
@ OUTPUTDATASTREAMPORT
@ INPUTDATASTREAMPORT
@ INVALID
Definition: define.hxx:36
@ READY
Definition: define.hxx:37
References YACS::HMI::SchemaItem::_itemForeground, YACS::HMI::QtGuiContext::_mapOfSchemaItem, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::SchemaItem::_subject, YACS::HMI::ADD, YACS::HMI::SchemaItem::appendChild(), YACS::HMI::SchemaItem::child(), YACS::HMI::SchemaItem::childCount(), DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::Subject::getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::ENGINE::ElementaryNode::getSetOfInputPort(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::ENGINE::Node::getState(), yacsorb.CORBAEngineTest::i, YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, YACS::INVALID, YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::ORDER, YACS::HMI::OUTPUTDATASTREAMPORT, YACS::HMI::OUTPUTPORT, YACS::READY, YACS::HMI::SchemaItem::removeChild(), YACS::HMI::SchemaModel::setData(), YACS::HMI::SchemaItem::setExecState(), YACS::HMI::SchemaItem::update(), YACS::HMI::UPDATE, YACS::HMI::UPDATEPROGRESS, YASSERT, YACS::HMI::YLabel, and YACS::HMI::YState.
Referenced by gui.graph.MyCanvas::customEvent().
