YACS::HMI::SchemaOutPortItem Class Reference
#include <SchemaOutPortItem.hxx>
Inheritance diagram for YACS::HMI::SchemaOutPortItem:
Collaboration diagram for YACS::HMI::SchemaOutPortItem:
 SchemaOutPortItem (SchemaItem *parent, QString label, Subject *subject)
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QString getMimeFormat ()
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant editionWhatsThis (int column) const
virtual QVariant runWhatsThis (int column) const
virtual void setExecState (int execState)
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaOutPortItem.hxx.
◆ SchemaOutPortItem()
SchemaOutPortItem::SchemaOutPortItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
column 1: YLabel = name, set in SchemaItem, column 2: YType = data type, never editable, column 3: YValue = value
Definition at line 47 of file SchemaOutPortItem.cxx.
48 : SchemaItem(parent, label, subject)
49{
50 SubjectDataPort *subPort = dynamic_cast<SubjectDataPort*>(subject);
51 if (subPort)
52 {
53 DataPort *dport = subPort->getPort();
55// _itemData.replace(YType, dport->edGetType()->getKindRepr());
56 _itemData.replace(YType, dport->edGetType()->name());
57 _itemForeground.replace(YType, QColor("black"));
58 OutputPort * outport = 0;
59
60 switch (typort)
61 {
63 _itemDeco.replace(YLabel, QIcon("icons:out_port.png"));
64 outport = dynamic_cast<OutputPort*>(dport);
65 _itemData.replace(YValue, outport->getAsString().c_str());
66 break;
68 _itemDeco.replace(YLabel, QIcon("icons:out_port.png"));
69 _itemData.replace(YValue, "stream");
70 _itemForeground.replace(YValue, QColor("grey"));
71 //_itemDeco.replace(YValue, QColor("grey"));
72 break;
73 }
74 }
75}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.cxx:84
Definition: TypeCode.cxx:72
static TypeOfElem getTypeOfPort(YACS::ENGINE::DataPort *port)
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
Definition: SchemaItem.hxx:79
Definition: SchemaItem.hxx:77
virtual YACS::ENGINE::DataPort * getPort()
@ OUTPUTDATASTREAMPORT
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_itemDeco, YACS::HMI::SchemaItem::_itemForeground, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getAsString(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::ProcInvoc::getTypeOfPort(), YACS::ENGINE::TypeCode::name(), YACS::HMI::OUTPUTDATASTREAMPORT, YACS::HMI::OUTPUTPORT, YACS::HMI::YLabel, YACS::HMI::YType, and YACS::HMI::YValue.
◆ flags()
Qt::ItemFlags SchemaOutPortItem::flags ( const QModelIndex &  index)
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 123 of file SchemaOutPortItem.cxx.
124{
125 //DEBTRACE("SchemaOutPortItem::flags");
126 Qt::ItemFlags pflag = Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsDropEnabled;
127 if (QtGuiContext::getQtCurrent()->isEdition())
128 pflag = pflag | Qt::ItemIsDragEnabled;
129 else
130 return pflag;
131
132 Qt::ItemFlags flagEdit = 0;
133 int column = index.column();
134 switch (column)
135 {
136 case 0:
137 {
138 SubjectDataPort *sdp = dynamic_cast<SubjectDataPort*>(_subject);
139 Node *parent = sdp->getPort()->getNode();
140 if (parent)
141 if (dynamic_cast<DataNode*>(parent) || dynamic_cast<InlineNode*>(parent))
142 flagEdit = Qt::ItemIsEditable; // --- port name editable
143 }
144 break;
145 case 2:
146 SubjectDataPort *sdp = dynamic_cast<SubjectDataPort*>(_subject);
147 Node *node = sdp->getPort()->getNode();
148 //PresetNode *pnode = dynamic_cast<PresetNode*>(node);
149 DataNode *pnode = dynamic_cast<DataNode*>(node);
150 if (! pnode) break;
151 flagEdit = Qt::ItemIsEditable; // --- port value editable for preset node
152 break;
153 }
154 return pflag | flagEdit;
155}
Definition: DataNode.hxx:38
Definition: InlineNode.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
References YACS::HMI::SchemaItem::_subject, YACS::ENGINE::Port::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::SchemaItem::parent().
◆ getMimeFormat()
QString SchemaOutPortItem::getMimeFormat ( )
Definition at line 163 of file SchemaOutPortItem.cxx.
164{
165 return "yacs/subjectOutPort";
166}
◆ popupMenu()
void SchemaOutPortItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 157 of file SchemaOutPortItem.cxx.
158{
160 m.popupMenu(caller, globalPos);
161}
References gui.GraphViewer::m.
◆ update()
void SchemaOutPortItem::update ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 77 of file SchemaOutPortItem.cxx.
78{
79 DEBTRACE("SchemaOutPortItem::update");
80 SchemaItem::update(event, type, son);
81 QModelIndex index = QModelIndex();
83 switch (event)
84 {
85 case SETVALUE:
86 {
87 SubjectOutputPort *sop = dynamic_cast<SubjectOutputPort*>(son);
88 if (sop)
89 {
90 DataFlowPort *port = dynamic_cast<DataFlowPort*>(sop->getPort());
91 DEBTRACE(port->getAsString());
92 _itemData.replace(YValue, port->getAsString().c_str());
93 _itemForeground.replace(YValue, QColor("green"));
94 model->setData(modelIndex(YValue), 0); // --- to emit dataChanged signal
95 }
96 }
97 break;
98 case UPDATE:
99 {
100 SubjectOutputPort *sop = dynamic_cast<SubjectOutputPort*>(son);
101 if (sop)
102 {
103 DataFlowPort *port = dynamic_cast<DataFlowPort*>(sop->getPort());
104 _itemData.replace(YType, port->edGetType()->name());
105 _itemForeground.replace(YType, QColor("black"));
106 }
107 }
108 break;
109 case UPDATEPROGRESS:
110 {
111 SubjectOutputPort *sip = dynamic_cast<SubjectOutputPort*>(son);
112 if (sip)
113 {
114 _itemData.replace(YValue, sip->getExecValue().c_str());
115 _itemForeground.replace(YValue, QColor("darkMagenta"));
116 model->setData(modelIndex(YValue), 0); // --- to emit dataChanged signal
117 }
118 }
119 break;
120 }
121}
Definition: SchemaItem.cxx:253
Definition: SchemaItem.cxx:174
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_itemForeground, DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getAsString(), YACS::HMI::SubjectDataPort::getExecValue(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::modelIndex(), YACS::ENGINE::TypeCode::name(), YACS::HMI::SchemaModel::setData(), YACS::HMI::SETVALUE, YACS::HMI::SchemaItem::update(), YACS::HMI::UPDATE, YACS::HMI::UPDATEPROGRESS, YACS::HMI::YType, and YACS::HMI::YValue.
Referenced by gui.graph.MyCanvas::customEvent().
