SchemaModel.cxx
20#include "SchemaModel.hxx"
21#include "SchemaItem.hxx"
22#include "SchemaNodeItem.hxx"
23#include "SchemaProcItem.hxx"
24#include "QtGuiContext.hxx"
25#include "GuiEditor.hxx"
26#include "ItemMimeData.hxx"
27#include "guiObservers.hxx"
28
29#include <QMetaType>
30#include <QVariant>
32
33//#define _DEVDEBUG_
34#include "YacsTrace.hxx"
35
36using namespace std;
37using namespace YACS::HMI;
38
39SchemaModel::SchemaModel(YACS::HMI::Subject *context,
40 QObject * parent):
41 QAbstractItemModel(parent)
42{
43 DEBTRACE("SchemaModel::SchemaModel");
44 _context=context;
45 _root=0;
46 _rootItem=0;
47 _context->attach(this);
48 _stdBackBrush = QColor("white");
49 _editedBackBrush = QColor("yellow");
50 _emphasizeBackBrush = QColor("magenta");
51 _isEdition = true;
52}
53
55{
56 DEBTRACE("SchemaModel::~SchemaModel");
57 _subjectSet.clear(); // --- avoid destruction loop on delete context
58}
59
60QModelIndex SchemaModel::index(int row, int column, const QModelIndex &parent) const
61{
62 // DEBTRACE("SchemaModel::index");
63 if (!hasIndex(row, column, parent))
64 return QModelIndex();
65
66 SchemaItem *parentItem = 0;
67
68 if (!parent.isValid())
69 parentItem = _rootItem;
70 else
71 parentItem = static_cast<SchemaItem*>(parent.internalPointer());
72
73 SchemaItem *childItem = parentItem->child(row);
74 if (childItem)
75 return createIndex(row, column, childItem);
76 else
77 return QModelIndex();
78}
79
80QModelIndex SchemaModel::parent(const QModelIndex &index) const
81{
82 // DEBTRACE("SchemaModel::parent");
83 if (!index.isValid())
84 return QModelIndex();
85 SchemaItem *childItem = static_cast<SchemaItem*>(index.internalPointer());
86 SchemaItem *parentItem = childItem->parent();
87 if (parentItem == _rootItem)
88 return QModelIndex();
89 return createIndex(parentItem->row(), 0, parentItem);
90}
91
92int SchemaModel::rowCount(const QModelIndex &parent) const
93{
94 //DEBTRACE("SchemaModel::rowCount");
95 SchemaItem *parentItem;
96 if (parent.column() > 0)
97 return 0;
98 if (!parent.isValid())
99 parentItem = _rootItem;
100 else
101 parentItem = static_cast<SchemaItem*>(parent.internalPointer());
102 if (parentItem)
103 return parentItem->childCount();
104 else return 0;
105}
106
107int SchemaModel::columnCount(const QModelIndex &parent) const
108{
109 //DEBTRACE("SchemaModel::columnCount " << parent.isValid());
110 if (parent.isValid())
111 return static_cast<SchemaItem*>(parent.internalPointer())->columnCount();
112 if (_rootItem)
113 {
114 if (_isEdition) return 3;
115 else return 3; //_rootItem->columnCount();
116 }
117 else
118 return 0;
119}
120
121QVariant SchemaModel::data(const QModelIndex &index, int role) const
122{
123 //DEBTRACE("SchemaModel::data");
124 if (!index.isValid())
125 return QVariant();
126 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
127 return item->data(index.column(), role);
128}
129
130QVariant SchemaModel::headerData(int section, Qt::Orientation orientation, int role) const
131{
132 //DEBTRACE("SchemaModel::headerData");
133 if (role != Qt::DisplayRole)
134 return QVariant();
135
136 if (orientation == Qt::Horizontal)
137 //return QString("Colonne %1").arg(section);
138 if (_isEdition)
139 switch (section)
140 {
141 case YLabel: return QString("Name");
142 case YType: return QString("Type");
143 case YValue: return QString("Value");
144 default: return QString("- %1 -").arg(section);
145 }
146 else
147 switch (section)
148 {
149 case YLabel: return QString("Name");
150 case YType: return QString("Type");
151 case YState: return QString("State");
152 default: return QString("- %1 -").arg(section);
153 }
154 else
155 return QVariant();
156}
157
162bool SchemaModel::setData(const QModelIndex &index, const QVariant &value, int role)
163{
164 DEBTRACE("SchemaModel::setData");
165 if (index.isValid() && role == Qt::EditRole)
166 {
167 DEBTRACE("Qt::EditRole, emit dataChanged");
168 emit dataChanged(index, index);
169 return true;
170 }
171 if (index.isValid() && role == Qt::CheckStateRole)
172 {
173 DEBTRACE("Qt::CheckStateRole, toggle state");
174 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
175 item->toggleState();
176 emit dataChanged(index, index);
177 return true;
178 }
179 return false;
180}
181
182Qt::ItemFlags SchemaModel::flags(const QModelIndex &index) const
183{
184 //DEBTRACE("SchemaModel::flags");
185 if (!index.isValid())
186 return 0;
187 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
188 return item->flags(index);
189}
190
191
192void SchemaModel::update(GuiEvent event, int type, Subject* son)
193{
194 DEBTRACE("SchemaModel::update "<<eventName(event)<<" "<<type<<" "<<son);
195 switch (event)
196 {
198 setNewRoot(son);
199 break;
200// default:
201// DEBTRACE("SchemaModel::update(), event not handled: "<< eventName(event));
202 }
203}
204
205void SchemaModel::updateSelection(const QItemSelection &selected,
206 const QItemSelection &deselected)
207{
208 DEBTRACE("SchemaModel::updateSelection");
209 QModelIndex index;
210 QModelIndexList items = selected.indexes();
211
212 foreach (index, items)
213 {
214 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
215 DEBTRACE("updateSelection select "<< item->getSubject()->getName());
216 item->getSubject()->select(true);
217 emit signalSelection(index);
218 }
219
220 items = deselected.indexes();
221
222 foreach (index, items)
223 {
224 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
225 DEBTRACE("updateSelection deselect "<< item->getSubject()->getName());
226 item->getSubject()->select(false);
227 }
228}
229
230void SchemaModel::setEdition(bool isEdition)
231{
233}
234
236{
237 return _stdBackBrush;
238}
239
241{
242 return _editedBackBrush;
243}
244
246{
247 return _emphasizeBackBrush;
248}
249
251{
252 _root = root;
253 QString name = _root->getName().c_str();
255 SchemaProcItem *procItem = new SchemaProcItem(_rootItem, name, _root);
256}
257
258QMimeData* SchemaModel::mimeData(const QModelIndexList &indexes) const
259{
260 DEBTRACE("SchemaModel::mimeData");
261 ItemMimeData *mime = new ItemMimeData;
262 mime->setSubject(_root);
263
264 if (indexes.empty())
265 return mime;
266 QModelIndex index = indexes.first();
267 if (!index.isValid())
268 return mime;
269 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
270 DEBTRACE("mimeData valid index");
271 return item->mimeData(mime);
272}
273
274bool SchemaModel::dropMimeData(const QMimeData* data, Qt::DropAction action,
275 int row, int column, const QModelIndex& parent)
276{
277 DEBTRACE("SchemaModel::dropMimeData");
278 if (action == Qt::IgnoreAction)
279 return true;
280
281 string name = "empty";
282 SchemaItem *item = 0;
283 if (parent.isValid())
284 {
285 item = static_cast<SchemaItem*>(parent.internalPointer());
286 name = item->getSubject()->getName();
287 }
288 DEBTRACE(row << " " << column << " "<< name);
289
290 if ((row >= 0) && (column >=0))
291 {
292 QModelIndex ind = index(row, column, parent);
293 if (!ind.isValid())
294 return false;
295 DEBTRACE("---");
296 item = static_cast<SchemaItem*>(ind.internalPointer());
297 }
298 if (!item)
299 return false;
300 return item->dropMimeData(data, action);
301}
302
304{
305 //DEBTRACE("SchemaModel::supportedDropActions");
306 return Qt::CopyAction | Qt::MoveAction | Qt::LinkAction;
307}
308
309QStringList SchemaModel::mimeTypes() const
310{
311 //DEBTRACE("SchemaModel::mimeTypes");
312 QStringList types;
313 types << "yacs/subject" << "yacs/subjectNode" << "yacs/subjectOutPort"
314 << "yacs/cataService" << "yacs/cataType" << "yacs/cataNode"
315 << "yacs/subjectOutGate";
316 return types;
317}
Q_DECLARE_METATYPE(YACS::HMI::Subject)
std::set< Subject * > _subjectSet
virtual void setSubject(Subject *sub)
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
virtual Qt::ItemFlags flags(const QModelIndex &index)
Definition: SchemaItem.cxx:149
virtual bool dropMimeData(const QMimeData *data, Qt::DropAction action)
Definition: SchemaItem.cxx:284
virtual ItemMimeData * mimeData(ItemMimeData *mime)
Definition: SchemaItem.cxx:276
virtual int row() const
Definition: SchemaItem.cxx:154
virtual void toggleState()
Definition: SchemaItem.cxx:239
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
virtual SchemaItem * child(int row)
Definition: SchemaItem.cxx:105
virtual int childCount() const
Definition: SchemaItem.cxx:111
void setEdition(bool isEdition=true)
virtual bool dropMimeData(const QMimeData *data, Qt::DropAction action, int row, int column, const QModelIndex &parent)
virtual Qt::DropActions supportedDropActions() const
virtual QVariant data(const QModelIndex &index, int role=Qt::DisplayRole) const
friend class SchemaItem
Definition: SchemaModel.hxx:53
const QBrush & emphasizeBackBrush()
virtual QMimeData * mimeData(const QModelIndexList &indexes) const
virtual QModelIndex index(int row, int column, const QModelIndex &parent=QModelIndex()) const
Definition: SchemaModel.cxx:60
virtual QModelIndex parent(const QModelIndex &index) const
Definition: SchemaModel.cxx:80
void signalSelection(const QModelIndex &index)
virtual int columnCount(const QModelIndex &parent=QModelIndex()) const
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
const QBrush & editedBackBrush()
virtual Qt::ItemFlags flags(const QModelIndex &index) const
virtual QVariant headerData(int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const
void setNewRoot(YACS::HMI::Subject *root)
const QBrush & stdBackBrush()
void updateSelection(const QItemSelection &selected, const QItemSelection &deselected)
virtual int rowCount(const QModelIndex &parent=QModelIndex()) const
Definition: SchemaModel.cxx:92
virtual QStringList mimeTypes() const
virtual std::string getName()
virtual void attach(GuiObserver *obs)
virtual void select(bool isSelected)
