YACS::HMI::SchemaProcItem Class Reference
#include <SchemaProcItem.hxx>
Inheritance diagram for YACS::HMI::SchemaProcItem:
Collaboration diagram for YACS::HMI::SchemaProcItem:
 SchemaProcItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaProcItem ()
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaComposedNodeItem
 SchemaComposedNodeItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaComposedNodeItem ()
std::list< YACS::ENGINE::Node * > getDirectDescendants () const
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void setCaseValue ()
 used in node derived classes More...
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual void reparent (SchemaItem *parent)
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
virtual void setExecState (int execState)
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaComposedNodeItem
virtual QString getMimeFormat ()
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant runWhatsThis (int column) const
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaComposedNodeItem
SchemaDirTypesItem * _dirTypesItem
SchemaDirContainersItem * _dirContainersItem
SchemaDirLinksItem * _dirLinksItem
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaProcItem.hxx.
◆ SchemaProcItem()
SchemaProcItem::SchemaProcItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 33 of file SchemaProcItem.cxx.
34 : SchemaComposedNodeItem(parent, label, subject)
35{
36 DEBTRACE("SchemaProcItem::SchemaProcItem");
37}
SchemaComposedNodeItem(SchemaItem *parent, QString label, Subject *subject)
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
References DEBTRACE.
◆ ~SchemaProcItem()
SchemaProcItem::~SchemaProcItem ( )
Definition at line 39 of file SchemaProcItem.cxx.
40{
41 DEBTRACE("SchemaProcItem::~SchemaProcItem");
42}
◆ editionToolTip()
QVariant SchemaProcItem::editionToolTip ( int  column) const
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 72 of file SchemaProcItem.cxx.
73{
74 QString val = QString("Edition: ") + _itemData.value(0).toString();
75 QString val1 = _itemData.value(2).toString();
76 QString val2 = QtGuiContext::getQtCurrent()->getFileName();
77 if (!val1.isEmpty()) val += QString(" | ") + val1;
78 if (!val2.isEmpty()) val += QString(" | ") + val2;
79 return val;
80}
Definition: SchemaItem.hxx:77
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::QtGuiContext::getFileName(), and YACS::HMI::QtGuiContext::getQtCurrent().
◆ editionWhatsThis()
QVariant SchemaProcItem::editionWhatsThis ( int  column) const
Reimplemented from YACS::HMI::SchemaComposedNodeItem.
Definition at line 92 of file SchemaProcItem.cxx.
93{
94 return "<p>To edit the schema properties, select the schema and use the input panel. <a href=\"modification.html#property-page-for-schema\">More...</a></p>";
95}
◆ popupMenu()
void SchemaProcItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 44 of file SchemaProcItem.cxx.
45{
46 ProcMenu m;
47 m.popupMenu(caller, globalPos);
48}
References gui.GraphViewer::m.
◆ runToolTip()
QVariant SchemaProcItem::runToolTip ( int  column) const
Definition at line 82 of file SchemaProcItem.cxx.
83{
84 QString val = QString("Execution: ") + _itemData.value(0).toString();
85 QString val1 = _itemData.value(2).toString();
86 QString val2 = QtGuiContext::getQtCurrent()->getFileName();
87 if (!val1.isEmpty()) val += QString(" | ") + val1;
88 if (!val2.isEmpty()) val += QString(" | ") + val2;
89 return val;
90}
◆ setExecState()
void SchemaProcItem::setExecState ( int  execState)
Definition at line 50 of file SchemaProcItem.cxx.
51{
52 DEBTRACE("SchemaProcItem::setExecState " << execState);
53 _execState = execState;
54 QString stateDef;
55 QColor sc;
56 switch (_execState)
57 {
58 case YACS::NOTYETINITIALIZED: sc = YACS::HMI::Resource::NOTYETINITIALIZED; stateDef = "Not Yet Initialized"; break;
59 case YACS::INITIALISED: sc = YACS::HMI::Resource::INITIALISED ; stateDef = "Initialized"; break;
60 case YACS::RUNNING: sc = YACS::HMI::Resource::RUNNING ; stateDef = "Running"; break;
61 case YACS::WAITINGTASKS: sc = YACS::HMI::Resource::WAITINGTASKS ; stateDef = "Waiting Tasks"; break;
62 case YACS::PAUSED: sc = YACS::HMI::Resource::PAUSED ; stateDef = "Paused"; break;
63 case YACS::FINISHED: sc = YACS::HMI::Resource::FINISHED ; stateDef = "Finished"; break;
64 case YACS::STOPPED: sc = YACS::HMI::Resource::STOPPED ; stateDef = "Stopped"; break;
65 default: sc = YACS::HMI::Resource::UNKNOWN ; stateDef = "Unknown Status";
66 }
67 _itemData.replace(YState, stateDef);
68 _itemForeground.replace(YState, QColor(Qt::darkBlue));
69 _itemBackground.replace(YState, sc);
70}
static QColor PAUSED
Definition: Resource.hxx:231
static QColor WAITINGTASKS
Definition: Resource.hxx:230
static QColor NOTYETINITIALIZED
Definition: Resource.hxx:227
static QColor FINISHED
Definition: Resource.hxx:232
static QColor RUNNING
Definition: Resource.hxx:229
static QColor STOPPED
Definition: Resource.hxx:233
static QColor UNKNOWN
Definition: Resource.hxx:234
static QColor INITIALISED
Definition: Resource.hxx:228
Definition: SchemaItem.hxx:80
Definition: SchemaItem.hxx:79
@ RUNNING
Definition: define.hxx:67
@ PAUSED
Definition: define.hxx:69
@ WAITINGTASKS
Definition: define.hxx:68
@ INITIALISED
Definition: define.hxx:66
@ NOTYETINITIALIZED
Definition: define.hxx:65
@ FINISHED
Definition: define.hxx:70
@ STOPPED
Definition: define.hxx:71
References YACS::HMI::SchemaItem::_execState, YACS::HMI::SchemaItem::_itemBackground, YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_itemForeground, DEBTRACE, YACS::FINISHED, YACS::HMI::Resource::FINISHED, YACS::INITIALISED, YACS::HMI::Resource::INITIALISED, YACS::NOTYETINITIALIZED, YACS::HMI::Resource::NOTYETINITIALIZED, YACS::PAUSED, YACS::HMI::Resource::PAUSED, YACS::RUNNING, YACS::HMI::Resource::RUNNING, YACS::STOPPED, YACS::HMI::Resource::STOPPED, YACS::HMI::Resource::UNKNOWN, YACS::WAITINGTASKS, YACS::HMI::Resource::WAITINGTASKS, and YACS::HMI::YState.
