YACS::HMI::SchemaDirContainersItem Class Reference
#include <SchemaDirContainersItem.hxx>
Inheritance diagram for YACS::HMI::SchemaDirContainersItem:
Collaboration diagram for YACS::HMI::SchemaDirContainersItem:
 SchemaDirContainersItem (SchemaItem *parent, QString label, Subject *subject)
void addContainerItem (Subject *subject)
void addComponentItem (Subject *subject)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
std::map< std::string, SchemaContainerItem * > _schemaContItemMap
std::multimap< std::string, Subject * > _waitingCompItemMap
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
static void setEventMap ()
Definition at line 31 of file SchemaDirContainersItem.hxx.
◆ SchemaDirContainersItem()
SchemaDirContainersItem::SchemaDirContainersItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 38 of file SchemaDirContainersItem.cxx.
39 : SchemaItem(parent, label, subject)
40{
41 _itemDeco.replace(YLabel, QIcon("icons:folder_cyan.png"));
42 _schemaContItemMap.clear();
43 _waitingCompItemMap.clear();
44}
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
References YACS::HMI::SchemaItem::_itemDeco, _schemaContItemMap, _waitingCompItemMap, and YACS::HMI::YLabel.
◆ addComponentItem()
void SchemaDirContainersItem::addComponentItem ( Subject *  subject)
If a component is not associated to a container, it will be associated to a default container. If this default container does not exist, it is created. When loading a schema, container must be created before component:
See also
SubjectProc::loadProc
Definition at line 78 of file SchemaDirContainersItem.cxx.
79{
80 DEBTRACE("SchemaDirContainersItem::addComponentItem");
81 SubjectComponent *aSComp = dynamic_cast<SubjectComponent*>(subject);
82 YASSERT(aSComp);
83 ComponentInstance* component = aSComp->getComponent();
84 YASSERT(component);
85
86 string contName = "DefaultContainer";
87 Container *container = component->getContainer();
88 if (container)
89 contName = container->getName();
90 else
91 {
92 if (!_schemaContItemMap.count(contName)) // no container and default container not created
93 {
95 sProc->addContainer(contName);
96 }
97 }
98
99 YASSERT(_schemaContItemMap.count(contName));
101 aSComp->associateToContainer(static_cast<SubjectContainer*>(sci->getSubject()));
102}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual std::string getName() const
Definition: Container.hxx:81
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
YACS::ENGINE::ComponentInstance * getComponent() const
virtual bool associateToContainer(SubjectContainerBase *subcont)
virtual SubjectContainerBase * addContainer(std::string name, std::string ref="")
References _schemaContItemMap, YACS::HMI::SubjectProc::addContainer(), YACS::HMI::SubjectComponent::associateToContainer(), DEBTRACE, YACS::HMI::SubjectComponent::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::ENGINE::Container::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::GuiContext::getSubjectProc(), and YASSERT.
Referenced by YACS::HMI::SchemaComposedNodeItem::update().
◆ addContainerItem()
void SchemaDirContainersItem::addContainerItem ( Subject *  subject)
When loading a schema, a container may appear after a component using this container. After creating the SchemaContainerItem, check if there are SchemaComponentItems to to create as children of this SchemaContainerItem
Definition at line 58 of file SchemaDirContainersItem.cxx.
59{
60 DEBTRACE("SchemaDirContainersItem::addContainerItem");
62 int nbsons = childCount();
63 string contName = subject->getName();
64
65 model->beginInsertRows(modelIndex(), nbsons, nbsons);
67 contName.c_str(),
68 subject);
69 model->endInsertRows();
70
71 _schemaContItemMap[contName] = item;
72}
Definition: SchemaItem.cxx:253
virtual int childCount() const
Definition: SchemaItem.cxx:111
References _schemaContItemMap, YACS::HMI::SchemaItem::childCount(), DEBTRACE, YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), and YACS::HMI::SchemaItem::modelIndex().
◆ editionWhatsThis()
QVariant SchemaDirContainersItem::editionWhatsThis ( int  column) const
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 104 of file SchemaDirContainersItem.cxx.
105{
106 return "<p>Containers used in this schema appears in this folder.\n" \
107 "You can add containers by using the context menu (entry \"Create container\") " \
108 "and then edit its properties in the input panel. <a href=\"modification.html#property-page-for-container\">More...</a></p>";
109}
◆ popupMenu()
void SchemaDirContainersItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 46 of file SchemaDirContainersItem.cxx.
47{
49 m.popupMenu(caller, globalPos);
50}
References gui.GraphViewer::m.
◆ _schemaContItemMap
std::map<std::string, SchemaContainerItem*> YACS::HMI::SchemaDirContainersItem::_schemaContItemMap
◆ _waitingCompItemMap
std::multimap<std::string, Subject*> YACS::HMI::SchemaDirContainersItem::_waitingCompItemMap
Definition at line 41 of file SchemaDirContainersItem.hxx.
Referenced by SchemaDirContainersItem().
