YACS::HMI::SchemaContainerItem Class Reference
#include <SchemaContainerItem.hxx>
Inheritance diagram for YACS::HMI::SchemaContainerItem:
Collaboration diagram for YACS::HMI::SchemaContainerItem:
 SchemaContainerItem (SchemaItem *parent, QString label, Subject *subject)
void addComponentInstance (Subject *subject)
void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
static void setEventMap ()
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaContainerItem.hxx.
◆ SchemaContainerItem()
SchemaContainerItem::SchemaContainerItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 35 of file SchemaContainerItem.cxx.
36 : SchemaItem(parent, label, subject)
37{
38 DEBTRACE("SchemaContainerItem::SchemaContainerItem " << subject->getName());
39 SubjectContainer *scont = dynamic_cast<SubjectContainer*>(subject);
40 DEBTRACE(scont);
41 _itemDeco.replace(YLabel, QIcon("icons:container.png"));
42}
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
virtual std::string getName()
References YACS::HMI::SchemaItem::_itemDeco, DEBTRACE, YACS::HMI::Subject::getName(), and YACS::HMI::YLabel.
◆ addComponentInstance()
void SchemaContainerItem::addComponentInstance ( Subject *  subject)
Definition at line 115 of file SchemaContainerItem.cxx.
116{
117 DEBTRACE("SchemaContainersItem::addComponentInstance");
119 int nbsons = childCount();
120 model->beginInsertRows(modelIndex(), nbsons, nbsons);
122 subject->getName().c_str(),
123 subject);
124 model->endInsertRows();
125}
Definition: SchemaItem.cxx:253
virtual int childCount() const
Definition: SchemaItem.cxx:111
References YACS::HMI::SchemaItem::childCount(), DEBTRACE, YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), and YACS::HMI::SchemaItem::modelIndex().
Referenced by update().
◆ editionWhatsThis()
QVariant SchemaContainerItem::editionWhatsThis ( int  column) const
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 133 of file SchemaContainerItem.cxx.
134{
135 return "<p>To edit the container properties, select the container and use the input panel. <a href=\"modification.html#property-page-for-container\">More...</a></p>";
136}
◆ popupMenu()
void SchemaContainerItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 127 of file SchemaContainerItem.cxx.
128{
130 m.popupMenu(caller, globalPos);
131}
References gui.GraphViewer::m.
◆ update()
void SchemaContainerItem::update ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 44 of file SchemaContainerItem.cxx.
45{
46 DEBTRACE("SchemaContainerItem::update " << eventName(event) << " " << son->getName());
47 //SchemaItem::update(event, type, son);
48 switch (event)
49 {
51 {
52 DEBTRACE("ADDCHILDREF ");
54 SubjectReference *ref = dynamic_cast<SubjectReference*>(son);
55 YASSERT(ref);
56 DEBTRACE("ADDCHILDREF " << ref->getReference()->getName());
57 addComponentInstance(ref->getReference());
58 }
59 break;
60
62 {
63 DEBTRACE("REMOVECHILDREF on " << getSubject()->getName());
65 SubjectReference *ref = dynamic_cast<SubjectReference*>(son);
66 YASSERT(ref);
67 DEBTRACE("REMOVECHILDREF " << ref->getReference()->getName());
68 SchemaItem *toRemove = QtGuiContext::getQtCurrent()->_mapOfSchemaItem[ref->getReference()];
69
70 int position = toRemove->row();
71 model->beginRemoveRows(modelIndex(), position, position);
72 removeChild(toRemove);
73 model->endRemoveRows();
74 }
75 break;
76
77 case YACS::HMI::CUT:
78 {
79 DEBTRACE("CUT on " << getSubject()->getName());
81 SubjectReference *ref = dynamic_cast<SubjectReference*>(son);
82 YASSERT(ref);
83 DEBTRACE("CUT " << ref->getReference()->getName());
84 SchemaItem *toMove = QtGuiContext::getQtCurrent()->_mapOfSchemaItem[ref->getReference()];
85
86 int position = toMove->row();
87 model->beginRemoveRows(modelIndex(), position, position);
88 removeChild(toMove);
89 model->endRemoveRows();
90 }
91 break;
92
94 {
95 DEBTRACE("PASTE on " << getSubject()->getName());
97 SubjectReference *ref = dynamic_cast<SubjectReference*>(son);
98 YASSERT(ref);
99 DEBTRACE("PASTE " << ref->getReference()->getName());
100 SchemaItem *toPaste = QtGuiContext::getQtCurrent()->_mapOfSchemaItem[ref->getReference()];
101
102 int nbsons = childCount();
103 model->beginInsertRows(modelIndex(), nbsons, nbsons);
104 toPaste->reparent(this);
105 model->endInsertRows();
106 }
107 break;
108
109 default:
110 SchemaItem::update(event, type, son);
111 ;
112 }
113}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
void addComponentInstance(Subject *subject)
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
virtual int row() const
Definition: SchemaItem.cxx:154
Definition: SchemaItem.cxx:174
virtual void reparent(SchemaItem *parent)
Definition: SchemaItem.cxx:289
virtual void removeChild(SchemaItem *child)
Definition: SchemaItem.cxx:93
Definition: CONNECTOR.py:120
References YACS::HMI::QtGuiContext::_mapOfSchemaItem, YACS::HMI::ADDCHILDREF, addComponentInstance(), YACS::HMI::SchemaItem::childCount(), YACS::HMI::CUT, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::PASTE, gui.CONNECTOR::ref(), YACS::HMI::SchemaItem::removeChild(), YACS::HMI::REMOVECHILDREF, YACS::HMI::SchemaItem::reparent(), YACS::HMI::SchemaItem::row(), YACS::HMI::SchemaItem::update(), and YASSERT.
Referenced by gui.graph.MyCanvas::customEvent().
