YACS::HMI::SchemaInPortItem Class Reference
#include <SchemaInPortItem.hxx>
Inheritance diagram for YACS::HMI::SchemaInPortItem:
Collaboration diagram for YACS::HMI::SchemaInPortItem:
 SchemaInPortItem (SchemaItem *parent, QString label, Subject *subject)
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual QVariant editionWhatsThis (int column) const
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
bool _isDataStream
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
static void setEventMap ()
Definition at line 29 of file SchemaInPortItem.hxx.
◆ SchemaInPortItem()
SchemaInPortItem::SchemaInPortItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
column 1 = name, set in SchemaItem, column 2 = data type, never editable, column 3 = value
Definition at line 47 of file SchemaInPortItem.cxx.
48 : SchemaItem(parent, label, subject)
49{
50 SubjectDataPort *subPort = dynamic_cast<SubjectDataPort*>(subject);
51 _isDataStream = false;
52 if (subPort)
53 {
54 DataPort *dport = subPort->getPort();
57// _itemData.replace(YType, dport->edGetType()->getKindRepr());
58 _itemData.replace(YType, dport->edGetType()->name());
59 _itemForeground.replace(YType, QColor("black"));
60 InputPort *inport = 0;
61
62 if(typnode==YACS::HMI::STUDYOUTNODE)
63 {
64 //It's a study out node
65 if(typort==YACS::HMI::INPUTPORT)
66 {
67 _itemDeco.replace(YLabel, QIcon("icons:in_port.png"));
68 inport = dynamic_cast<InputPort*>(dport);
69 std::string val=inport->getAsString();
70 if(val != "")
71 {
72 _itemData.replace(YValue, val.c_str());
73 if (inport->edGetNumberOfLinks())
74 _itemForeground.replace(YValue, QColor("green"));
75 else
76 _itemForeground.replace(YValue, QColor("red"));
77 }
78 else
79 {
80 _itemData.replace(YValue, "not initialized");
81 _itemForeground.replace(YValue, QColor("red"));
82 }
83 }
84 return;
85 }
86
87 switch (typort)
88 {
90 _isDataStream = false;
91 _itemDeco.replace(YLabel, QIcon("icons:in_port.png"));
92 inport = dynamic_cast<InputPort*>(dport);
93 if (inport->edIsManuallyInitialized())
94 {
95 _itemData.replace(YValue, inport->getAsString().c_str());
96 _itemForeground.replace(YValue, QColor("green"));
97 }
98 else if (inport->edGetNumberOfLinks())
99 {
100 _itemData.replace(YValue, "linked");
101 _itemForeground.replace(YValue, QColor("blue"));
102 }
103 else
104 {
105 _itemData.replace(YValue, "not initialized");
106 _itemForeground.replace(YValue, QColor("red"));
107 }
108 break;
110 _isDataStream = true;
111 _itemDeco.replace(YLabel, QIcon("icons:in_port.png"));
112 _itemData.replace(YValue, "stream");
113 _itemForeground.replace(YValue, QColor("grey"));
114 break;
115 }
116 }
117}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.cxx:84
virtual int edGetNumberOfLinks() const
Returns number of physical backlinks NOT number of user backlinks.
Definition: InPort.cxx:45
Base class for Input Ports.
Definition: InputPort.hxx:44
virtual bool edIsManuallyInitialized() const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: InputPort.cxx:76
Node * getNode() const
Definition: Port.hxx:46
Definition: TypeCode.cxx:72
static TypeOfElem getTypeOfPort(YACS::ENGINE::DataPort *port)
static TypeOfElem getTypeOfNode(YACS::ENGINE::Node *node)
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
Definition: SchemaItem.hxx:79
Definition: SchemaItem.hxx:77
virtual YACS::ENGINE::DataPort * getPort()
@ INPUTDATASTREAMPORT
References _isDataStream, YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_itemDeco, YACS::HMI::SchemaItem::_itemForeground, YACS::ENGINE::InPort::edGetNumberOfLinks(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::InputPort::edIsManuallyInitialized(), YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::Port::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::ProcInvoc::getTypeOfNode(), YACS::HMI::ProcInvoc::getTypeOfPort(), YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, YACS::ENGINE::TypeCode::name(), YACS::HMI::STUDYOUTNODE, YACS::HMI::YLabel, YACS::HMI::YType, and YACS::HMI::YValue.
◆ dropMimeData()
bool SchemaInPortItem::dropMimeData ( const QMimeData *  data,
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 254 of file SchemaInPortItem.cxx.
255{
256 DEBTRACE("SchemaInPortItem::dropMimeData");
257 if (!data) return false;
258 const ItemMimeData* myData = dynamic_cast<const ItemMimeData*>(data);
259 if (!myData) return false;
260 if(!myData->hasFormat("yacs/subjectOutPort")) return false;
261 SubjectDataPort *to = dynamic_cast<SubjectDataPort*>(getSubject());
262 if (!to) return false;
263 InPort *toport = dynamic_cast<InPort*>(to->getPort());
264 if (!toport) return false;
265
266 bool ret =false;
267 TypeOfElem typort = ProcInvoc::getTypeOfPort(toport);
268 switch (typort)
269 {
272 {
273 ret =true;
274 Subject *sub = myData->getSubject();
275 if (!sub) break;
276 SubjectDataPort* from = dynamic_cast<SubjectDataPort*>(sub);
277 if (from && to)
278 if (!SubjectDataPort::tryCreateLink(from, to,myData->getControl()))
279 Message mess;
280 break;
281 }
282 default:
283 break;
284 }
285 return ret;
286}
virtual bool getControl() const
virtual Subject * getSubject(int i=0) const
virtual Subject * getSubject()
Definition: SchemaItem.cxx:169
virtual QVariant data(int column, int role) const
Definition: SchemaItem.cxx:123
static bool tryCreateLink(SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
References YACS::HMI::SchemaItem::data(), DEBTRACE, YACS::HMI::ItemMimeData::getControl(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::SchemaItem::getSubject(), YACS::HMI::ItemMimeData::getSubject(), YACS::HMI::ProcInvoc::getTypeOfPort(), YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, and YACS::HMI::SubjectDataPort::tryCreateLink().
◆ editionWhatsThis()
QVariant SchemaInPortItem::editionWhatsThis ( int  column) const
Definition at line 294 of file SchemaInPortItem.cxx.
295{
296 QString answer;
297 if (_isDataStream)
298 answer = "Edition, DataStream input port ";
299 else
300 answer = "Edition, DataFlow input port ";
301 switch (column)
302 {
303 case YLabel:
304 answer += "name=";
305 answer += _itemData.value(column).toString();
306 answer += "\nInput port is edited in the input panel of the node.\n" \
307 "Select the node to get access to it's input panel.";
308 break;
309 case YType:
310 answer += "type=";
311 answer += _itemData.value(column).toString();
312 answer += "\nInput port is edited in the input panel of the node.\n" \
313 "Select the node to get access to it's input panel.\n" \
314 "Type is not modifiable, you must delete and recreate the port. Existing links will be lost.";
315 break;
316 case YValue:
317 answer += "value=";
318 answer += _itemData.value(column).toString();
319 answer += "\nInput port is edited in the input panel of the node.\n" \
320 "Select the node to get access to it's input panel.\n";
321 if (_isDataStream)
322 answer += "DataStream ports have no editable value, they must be linked to an output DataStream port.";
323 else
324 {
325 answer += "DataFlow ports must be either manually initialized or linked to an output DataFlow port. ";
326 answer += "If the port is manually initialized and linked, the value from the link will prevail ";
327 answer += "if it is available when the node is executed.";
328 }
329 break;
330 }
331 return answer;
332}
References _isDataStream, YACS::HMI::SchemaItem::_itemData, YACS::HMI::YLabel, YACS::HMI::YType, and YACS::HMI::YValue.
◆ flags()
Qt::ItemFlags SchemaInPortItem::flags ( const QModelIndex &  index)
Definition at line 228 of file SchemaInPortItem.cxx.
229{
230 //DEBTRACE("SchemaInPortItem::flags");
231 Qt::ItemFlags pflag = Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsDropEnabled;
232
233 Qt::ItemFlags flagEdit = 0;
234 int column = index.column();
235 switch (column)
236 {
237 case 0:
238 {
239 SubjectDataPort *sdp = dynamic_cast<SubjectDataPort*>(_subject);
240 Node *parent = sdp->getPort()->getNode();
241 if (parent)
242 if ( (dynamic_cast<DataNode*>(parent) || dynamic_cast<InlineNode*>(parent)) &&
244 flagEdit = Qt::ItemIsEditable; // --- port name editable
245 }
246 break;
247 case 2:
248 if (!_isDataStream)
249 flagEdit = Qt::ItemIsEditable; // --- port value editable
250 }
251 return pflag | flagEdit;
252}
Definition: DataNode.hxx:38
Definition: InlineNode.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
References _isDataStream, YACS::HMI::SchemaItem::_subject, YACS::ENGINE::Port::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::isEdition(), and YACS::HMI::SchemaItem::parent().
◆ popupMenu()
void SchemaInPortItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Definition at line 288 of file SchemaInPortItem.cxx.
289{
291 m.popupMenu(caller, globalPos);
292}
References gui.GraphViewer::m.
◆ update()
void SchemaInPortItem::update ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 119 of file SchemaInPortItem.cxx.
120{
121 DEBTRACE("SchemaInPortItem::update");
122 SchemaItem::update(event, type, son);
123 QModelIndex index = QModelIndex();
125 switch (event)
126 {
127 case SETVALUE:
128 {
129 SubjectInputPort *sip = dynamic_cast<SubjectInputPort*>(son);
130 if (sip)
131 {
132 InputPort* port = dynamic_cast<InputPort*>(sip->getPort());
134 DEBTRACE(port->getAsString());
135 if(typnode==YACS::HMI::STUDYOUTNODE)
136 {
137 if(port->getAsString().empty())
138 {
139 _itemData.replace(YValue, "not initialized");
140 if (port->edGetNumberOfLinks())
141 _itemForeground.replace(YValue, QColor("blue"));
142 else
143 _itemForeground.replace(YValue, QColor("red"));
144 }
145 else
146 {
147 _itemData.replace(YValue, port->getAsString().c_str());
148 if (port->edGetNumberOfLinks())
149 _itemForeground.replace(YValue, QColor("green"));
150 else
151 _itemForeground.replace(YValue, QColor("red"));
152 }
153 }
154 else
155 {
156 _itemData.replace(YValue, port->getAsString().c_str());
157 _itemForeground.replace(YValue, QColor("green"));
158 }
159 model->setData(modelIndex(YValue), 0); // --- to emit dataChanged signal
160 }
161 }
162 break;
163 case UPDATE:
164 {
165 SubjectInputPort *sip = dynamic_cast<SubjectInputPort*>(_subject);
166 if (sip)
167 {
168 InputPort* port = dynamic_cast<InputPort*>(sip->getPort());
171 _itemData.replace(YType, port->edGetType()->name());
172 _itemForeground.replace(YType, QColor("black"));
173 if(typnode==YACS::HMI::STUDYOUTNODE)
174 {
175 if(port->getAsString().empty())
176 {
177 _itemData.replace(YValue, "not initialized");
178 if (port->edGetNumberOfLinks())
179 _itemForeground.replace(YValue, QColor("blue"));
180 else
181 _itemForeground.replace(YValue, QColor("red"));
182 }
183 else
184 {
185 _itemData.replace(YValue, port->getAsString().c_str());
186 if (port->edGetNumberOfLinks())
187 _itemForeground.replace(YValue, QColor("green"));
188 else
189 _itemForeground.replace(YValue, QColor("red"));
190 }
191 }
192 else
193 {
194 if (port->edGetNumberOfLinks())
195 {
196 _itemData.replace(YValue, "linked");
197 _itemForeground.replace(YValue, QColor("blue"));
198 }
199 else if (port->edIsManuallyInitialized())
200 {
201 _itemData.replace(YValue, port->getAsString().c_str());
202 _itemForeground.replace(YValue, QColor("green"));
203 }
204 else
205 {
206 _itemData.replace(YValue, "not initialized");
207 _itemForeground.replace(YValue, QColor("red"));
208 }
209 }
210 model->setData(modelIndex(YValue), 0); // --- to emit dataChanged signal
211 }
212 }
213 break;
214 case UPDATEPROGRESS:
215 {
216 SubjectInputPort *sip = dynamic_cast<SubjectInputPort*>(son);
217 if (sip)
218 {
219 _itemData.replace(YValue, sip->getExecValue().c_str());
220 _itemForeground.replace(YValue, QColor("darkCyan"));
221 model->setData(modelIndex(YValue), 0); // --- to emit dataChanged signal
222 }
223 }
224 break;
225 }
226}
Definition: SchemaItem.cxx:253
Definition: SchemaItem.cxx:174
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_itemForeground, YACS::HMI::SchemaItem::_subject, DEBTRACE, YACS::ENGINE::InPort::edGetNumberOfLinks(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::InputPort::edIsManuallyInitialized(), YACS::ENGINE::DataPort::getAsString(), YACS::HMI::SubjectDataPort::getExecValue(), YACS::ENGINE::Port::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::ProcInvoc::getTypeOfNode(), YACS::HMI::ProcInvoc::getTypeOfPort(), YACS::HMI::SchemaItem::modelIndex(), YACS::ENGINE::TypeCode::name(), YACS::HMI::SchemaModel::setData(), YACS::HMI::SETVALUE, YACS::HMI::STUDYOUTNODE, YACS::HMI::SchemaItem::update(), YACS::HMI::UPDATE, YACS::HMI::UPDATEPROGRESS, YACS::HMI::YType, and YACS::HMI::YValue.
Referenced by gui.graph.MyCanvas::customEvent().
◆ _isDataStream
bool YACS::HMI::SchemaInPortItem::_isDataStream
Definition at line 40 of file SchemaInPortItem.hxx.
Referenced by editionWhatsThis(), flags(), and SchemaInPortItem().
