21#include "SALOME_LifeCycleCORBA.hxx"
23#include "SALOME_Launcher.hxx"
37#include "KernelBasis.hxx"
48 DEBTRACE(
"GuiExecutor::GuiExecutor");
54 _procRef = YACS_ORB::ProcExec::_nil();
69 KERNEL::getLauncherSA();
76 DEBTRACE(
"GuiExecutor::~GuiExecutor");
81 DEBTRACE(
"GuiExecutor::closeContext");
87 DEBTRACE(
"GuiExecutor::runDataflow " << initialize);
101 SALOME_LifeCycleCORBA lcc(&namingService);
102 ostringstream containerName;
103 containerName <<
"localhost/YACSContainer";
104 Engines::EngineComponent_var
comp = lcc.FindOrLoad_Component(containerName.str().c_str(),
"YACS" );
117 _procRef->resumeCurrentBreakPoint();
155 DEBTRACE(
"Runtime error: execution from the loaded state failed")
163 DEBTRACE(
"GuiExecutor::checkEndOfDataFlow");
168 DEBTRACE(
"Runtime error: connection lost on a running scheme");
174 DEBTRACE(
"Remote Execution Already running...");
188 DEBTRACE(
"GuiExecutor::killDataflow");
195 DEBTRACE(
"GuiExecutor::suspendDataflow");
202 DEBTRACE(
"GuiExecutor::resumeDataflow");
206 _procRef->resumeCurrentBreakPoint();
212 DEBTRACE(
"GuiExecutor::stopDataflow");
219 DEBTRACE(
"GuiExecutor::resetDataflow");
238 DEBTRACE(
"GuiExecutor::setStepByStepMode");
246 DEBTRACE(
"GuiExecutor::setContinueMode");
254 DEBTRACE(
"GuiExecutor::setBreakpointMode");
262 DEBTRACE(
"GuiExecutor::setStopOnError " << aMode);
266 _procRef->setStopOnError(aMode, (getenv(
"TEMP") +
string(
"\\dumpStateOnError_") + getenv(
"USER") +
string(
".xml")).c_str());
268 _procRef->setStopOnError(aMode, (
string(
"/tmp/dumpStateOnError_") + getenv(
"USER") +
string(
".xml")).c_str());
276 DEBTRACE(
"GuiExecutor::unsetStopOnError");
287 DEBTRACE(
"GuiExecutor::saveState " << xmlFile);
291 !(CORBA::is_nil(
_procRef)) && StartFinish ) {
292 if ( !
_procRef->saveState(xmlFile.c_str()) ) {
293 string what =
"Impossible to open file for writing: " + xmlFile;
301 DEBTRACE(
"GuiExecutor::setLoadStateFile " << xmlFile);
308 DEBTRACE(
"GuiExecutor::getCurrentExecMode");
320 DEBTRACE(
"GuiExecutor::getExecutorState");
322 return _procRef->getExecutorState();
332 DEBTRACE(
"GuiExecutor::setBreakpointList");
350 DEBTRACE(
"addBreakpoint " << breakpoint);
367 DEBTRACE(
"removeBreakpoint " << breakpoint);
374 DEBTRACE(
"GuiExecutor::setNextStepList");
378 listOfNextStep.length(nextStepList.size());
380 for (list<string>::iterator it = nextStepList.begin(); it != nextStepList.end(); ++it)
381 listOfNextStep[
i++] = (*it).c_str();
382 _procRef->setStepsToExecute(listOfNextStep);
388 DEBTRACE(
"GuiExecutor::registerStatusObservers");
391 DEBTRACE(
"Runtime error (yacsgui): Lost connection on YACS executor");
405 for ( std::list<Node*>::iterator it = aNodeSet.begin(); it != aNodeSet.end(); it++ )
417 DEBTRACE(
"GuiExecutor::setEngineRef");
423 DEBTRACE(
"GuiExecutor::getErrorDetails");
427 return _procRef->getErrorDetails(engineId);
434 DEBTRACE(
"GuiExecutor::getErrorReport");
438 return _procRef->getErrorReport(engineId);
445 DEBTRACE(
"GuiExecutor::getContainerLog");
449 Engines::Container_var cont=
_engineRef->GetContainerRef();
450 CORBA::String_var logname = cont->logfilename();
453 std::string::size_type pos = msg.find(
454 msg=msg.substr(pos+1);
461 DEBTRACE(
"GuiExecutor::getContainerLog(YACS::ENGINE::Node* node)");
466 CORBA::String_var logname =
_procRef->getContainerLog(engineId);
468 std::string::size_type pos = msg.find(
469 msg=msg.substr(pos+1);
484 DEBTRACE(
"GuiExecutor::setInPortValue");
489 std::string nodeName;
495 std::string msg =
_procRef->setInPortValue(nodeName.c_str(), port->
getName().c_str(), value.c_str());
502 if (!yev)
return false;
511 if (
event ==
"executor")
513 int execState =
514 list<string> nextSteps;
517 YACS_ORB::stringArray_var nstp =
_procRef->getTasksToLoad();
518 for (CORBA::ULong
i=0;
i<nstp->length();
i++)
519 nextSteps.push_back(nstp[
i].in());
536 if (
event ==
"progress") {
537 std::string progress =
_procRef->getNodeProgress(numid);
544 list<InputPort*>::iterator iti = inports.begin();
545 for ( ; iti != inports.end(); ++iti)
547 string val =
_procRef->getInPortValue(numid, (*iti)->getName().c_str());
548 DEBTRACE(
"node " << snode->
getName() <<
" inport " << (*iti)->getName()
549 <<
" value " << val);
556 list<OutputPort*>::iterator ito = outports.begin();
557 for ( ; ito != outports.end(); ++ito)
559 string val =
_procRef->getOutPortValue(numid, (*ito)->getName().c_str());
560 DEBTRACE(
"node " << snode->
getName() <<
" outport " << (*ito)->getName()
561 <<
" value " << val);
583 listOfBreakPoints[
584 _procRef->setListOfBreakPoints(listOfBreakPoints);
595 for ( std::list<Node*>::iterator it = aNodeSet.begin(); it != aNodeSet.end(); it++ ){
597 numid = (*it)->getNumId();
604 list<InputPort*>::iterator iti = inports.begin();
605 for ( ; iti != inports.end(); ++iti)
614 list<OutputPort*>::iterator ito = outports.begin();
615 for ( ; ito != outports.end(); ++ito)
629 if(jobState!=
"RUNNING")
void display(CORBA::Any *data)
#define YASSERT(val)
virtual std::list< Node * > getAllRecursiveConstituents()
Idem getAllRecursiveNodes, but this node is NOT included.
ComposedNode * getRootNode() const
std::string getName() const
Base class for all nodes.
virtual ComposedNode * getRootNode() const
virtual std::list< OutputPort * > getLocalOutputPorts() const =0
virtual std::list< InputPort * > getLocalInputPorts() const =0
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
int getNumId()
return node instance identifiant, unique for each node instance
std::string getInPortValue(int nodeNumId, std::string portName)
std::string getOutPortValue(int nodeNumId, std::string portName)
YACS::StatesForNode getNodeState(int numId)
CORBA::ORB_ptr getOrb() const
QAction * _breakpointsModeAct
std::map< int, YACS::HMI::SubjectNode * > _mapOfExecSubjectNode
YACS::HMI::SubjectProc * getSubjectProc()
void setEngineRef(YACS_ORB::YACS_Gen_ptr ref)
std::string getErrorReport(YACS::ENGINE::Node *node)
std::string getContainerLog()
void startResumeDataflow(bool initialize=false)
YACS::ExecutorState updateSchema(std::string jobState)
YACS_ORB::ProcExec_var _procRef
virtual bool event(QEvent *e)
void registerStatusObservers()
bool checkEndOfDataflow(bool display=true)
void removeBreakpoint(std::string breakpoint)
void setLoadStateFile(std::string xmlFile)
void saveState(const std::string &xmlFile)
void addBreakpoint(std::string breakpoint)
YACS_ORB::Observer_var _observerRef
YACS::ENGINE::Proc * _proc
YACS::ExecutionMode _execMode
void setStopOnError(bool aMode)
std::string _loadStateFile
void setInPortValue(YACS::ENGINE::DataPort *port, std::string value)
YACS_ORB::YACS_Gen_var _engineRef
void setBreakpointList(std::list< std::string > breakpointList)
std::string getErrorDetails(YACS::ENGINE::Node *node)
YACS_ORB::executionMode getCurrentExecMode()
void setNextStepList(std::list< std::string > nextStepList)
std::list< std::string > _breakpointList
void SetImpl(GuiExecutor *impl)
void SetRemoteProc(YACS_ORB::ProcExec_ptr engineProc)
int getEngineId(int guiId)
std::map< int, int > _engineToGuiMap
YACS::HMI::GenericGui * getGMain()
void setExecValue(std::string value)
virtual std::string getName()
virtual void setProgress(std::string newProgress)
std::pair< int, std::string > getYACSEvent() const
sequence< string > stringArray
