YACS::HMI::GuiObserver_i Class Reference
#include <GuiObserver_i.hxx>
Inheritance diagram for YACS::HMI::GuiObserver_i:
Collaboration diagram for YACS::HMI::GuiObserver_i:
 GuiObserver_i (YACS::ENGINE::Proc *guiProc)
virtual ~GuiObserver_i ()
void notifyObserver (CORBA::Long numid, const char *event)
void setConversion ()
void SetImpl (GuiExecutor *impl)
void SetRemoteProc (YACS_ORB::ProcExec_ptr engineProc)
int getEngineId (int guiId)
YACS::ENGINE::Proc * _guiProc
YACS_ORB::ProcExec_var _engineProc
GuiExecutor * _impl
std::map< int, int > _guiToEngineMap
std::map< int, int > _engineToGuiMap
Friends
class GuiExecutor
Definition at line 51 of file GuiObserver_i.hxx.
◆ GuiObserver_i()
GuiObserver_i::GuiObserver_i ( YACS::ENGINE::Proc *  guiProc)
Definition at line 41 of file GuiObserver_i.cxx.
42{
43 DEBTRACE("GuiObserver_i::GuiObserver_i");
44 _guiProc = guiProc;
45 _engineProc = YACS_ORB::ProcExec::_nil();
46 _impl = 0;
47 _guiToEngineMap.clear();
48 _engineToGuiMap.clear();
49}
References _engineProc, _engineToGuiMap, _guiProc, _guiToEngineMap, _impl, and DEBTRACE.
◆ ~GuiObserver_i()
GuiObserver_i::~GuiObserver_i ( )
Definition at line 51 of file GuiObserver_i.cxx.
52{
53 DEBTRACE("GuiObserver_i::~GuiObserver_i");
54}
References DEBTRACE.
◆ getEngineId()
int YACS::HMI::GuiObserver_i::getEngineId ( int  guiId)
◆ notifyObserver()
void GuiObserver_i::notifyObserver ( CORBA::Long  numid,
const char *  event
Definition at line 56 of file GuiObserver_i.cxx.
57{
58 DEBTRACE("GuiObserver_i::notifyObserver " << numid << " " << event);
59 pair<int,string> myEvent(numid, event);
60 YACSEvent* evt = new YACSEvent(myEvent);
61 QApplication::postEvent(_impl, evt); // Qt will delete it when done
62}
References _impl, and DEBTRACE.
◆ setConversion()
void GuiObserver_i::setConversion ( )
Definition at line 64 of file GuiObserver_i.cxx.
65{
66 DEBTRACE("GuiObserver_i::setConversion");
67 YASSERT(!CORBA::is_nil(_engineProc));
68 YACS_ORB::stringArray_var engineNames;
69 YACS_ORB::longArray_var engineIds;
70 //DEBTRACE("---");
71 _engineProc->getIds(engineIds.out(), engineNames.out());
72 int iLength = engineIds->length();
73 int nLength = engineNames->length();
74 if (nLength < iLength) iLength = nLength;
75 for(int i=0; i<iLength; i++)
76 {
77 string aName = "";
78 aName = engineNames[i];
79 int iEng = engineIds[i];
80 DEBTRACE("--- " << aName << " " << iEng);
81 if (aName != "_root_")
82 {
83 int iGui = _guiProc->getChildByName(aName)->getNumId();
84 //DEBTRACE("---");
85 _guiToEngineMap[iGui] = iEng;
86 _engineToGuiMap[iEng] = iGui;
87 }
88 else
89 {
90 int iGui = _guiProc->getNumId();
91 _guiToEngineMap[iGui] = iEng;
92 _engineToGuiMap[iEng] = iGui;
93 }
94 }
95}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
int getNumId()
return node instance identifiant, unique for each node instance
Definition: Node.cxx:643
References _engineProc, _engineToGuiMap, _guiProc, _guiToEngineMap, DEBTRACE, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::Node::getNumId(), yacsorb.CORBAEngineTest::i, and YASSERT.
Referenced by YACS::HMI::GuiExecutor::registerStatusObservers().
◆ SetImpl()
void GuiObserver_i::SetImpl ( GuiExecutor *  impl)
Definition at line 97 of file GuiObserver_i.cxx.
98{
99 DEBTRACE("GuiObserver_i::SetImpl");
100 _impl = impl;
101}
◆ SetRemoteProc()
void GuiObserver_i::SetRemoteProc ( YACS_ORB::ProcExec_ptr  engineProc)
Definition at line 103 of file GuiObserver_i.cxx.
104{
105 DEBTRACE("GuiObserver_i::SetRemoteProc");
106 _engineProc = YACS_ORB::ProcExec::_duplicate(engineProc);
107}
References _engineProc, and DEBTRACE.
◆ GuiExecutor
friend class GuiExecutor
friend
Definition at line 54 of file GuiObserver_i.hxx.
◆ _engineProc
YACS_ORB::ProcExec_var YACS::HMI::GuiObserver_i::_engineProc
Definition at line 66 of file GuiObserver_i.hxx.
Referenced by GuiObserver_i(), setConversion(), and SetRemoteProc().
◆ _engineToGuiMap
std::map<int, int> YACS::HMI::GuiObserver_i::_engineToGuiMap
Definition at line 69 of file GuiObserver_i.hxx.
Referenced by YACS::HMI::GuiExecutor::event(), GuiObserver_i(), and setConversion().
◆ _guiProc
YACS::ENGINE::Proc* YACS::HMI::GuiObserver_i::_guiProc
Definition at line 65 of file GuiObserver_i.hxx.
Referenced by GuiObserver_i(), and setConversion().
◆ _guiToEngineMap
std::map<int, int> YACS::HMI::GuiObserver_i::_guiToEngineMap
Definition at line 68 of file GuiObserver_i.hxx.
Referenced by getEngineId(), GuiObserver_i(), and setConversion().
◆ _impl
GuiExecutor* YACS::HMI::GuiObserver_i::_impl
Definition at line 67 of file GuiObserver_i.hxx.
Referenced by GuiObserver_i(), notifyObserver(), and SetImpl().
