GuiObserver_i.cxx
20#include "GuiObserver_i.hxx"
21#include "GuiExecutor.hxx"
22#include "Proc.hxx"
23
24#include <QApplication>
25#include <cassert>
26
27//#define _DEVDEBUG_
28#include "YacsTrace.hxx"
30using namespace std;
31using namespace YACS::HMI;
32using namespace YACS::ENGINE;
33
34YACSEvent::YACSEvent(std::pair<int,std::string> aYACSEvent)
35 : QEvent(QEvent::User)
36{
37 _event = aYACSEvent;
38}
39
40
42{
43 DEBTRACE("GuiObserver_i::GuiObserver_i");
44 _guiProc = guiProc;
45 _engineProc = YACS_ORB::ProcExec::_nil();
46 _impl = 0;
47 _guiToEngineMap.clear();
48 _engineToGuiMap.clear();
49}
50
52{
53 DEBTRACE("GuiObserver_i::~GuiObserver_i");
54}
55
56void GuiObserver_i::notifyObserver(CORBA::Long numid, const char* event)
57{
58 DEBTRACE("GuiObserver_i::notifyObserver " << numid << " " << event);
59 pair<int,string> myEvent(numid, event);
60 YACSEvent* evt = new YACSEvent(myEvent);
61 QApplication::postEvent(_impl, evt); // Qt will delete it when done
62}
63
65{
66 DEBTRACE("GuiObserver_i::setConversion");
67 YASSERT(!CORBA::is_nil(_engineProc));
68 YACS_ORB::stringArray_var engineNames;
69 YACS_ORB::longArray_var engineIds;
70 //DEBTRACE("---");
71 _engineProc->getIds(engineIds.out(), engineNames.out());
72 int iLength = engineIds->length();
73 int nLength = engineNames->length();
74 if (nLength < iLength) iLength = nLength;
75 for(int i=0; i<iLength; i++)
76 {
77 string aName = "";
78 aName = engineNames[i];
79 int iEng = engineIds[i];
80 DEBTRACE("--- " << aName << " " << iEng);
81 if (aName != "_root_")
82 {
83 int iGui = _guiProc->getChildByName(aName)->getNumId();
84 //DEBTRACE("---");
85 _guiToEngineMap[iGui] = iEng;
86 _engineToGuiMap[iEng] = iGui;
87 }
88 else
89 {
90 int iGui = _guiProc->getNumId();
91 _guiToEngineMap[iGui] = iEng;
92 _engineToGuiMap[iEng] = iGui;
93 }
94 }
95}
96
98{
99 DEBTRACE("GuiObserver_i::SetImpl");
100 _impl = impl;
101}
102
103void GuiObserver_i::SetRemoteProc(YACS_ORB::ProcExec_ptr engineProc)
104{
105 DEBTRACE("GuiObserver_i::SetRemoteProc");
106 _engineProc = YACS_ORB::ProcExec::_duplicate(engineProc);
107}
108
#define YASSERT(val)
Definition: YacsTrace.hxx:59
int getNumId()
return node instance identifiant, unique for each node instance
Definition: Node.cxx:643
Definition: Proc.hxx:44
YACS_ORB::ProcExec_var _engineProc
void SetImpl(GuiExecutor *impl)
void SetRemoteProc(YACS_ORB::ProcExec_ptr engineProc)
GuiObserver_i(YACS::ENGINE::Proc *guiProc)
void notifyObserver(CORBA::Long numid, const char *event)
std::map< int, int > _guiToEngineMap
std::map< int, int > _engineToGuiMap
YACS::ENGINE::Proc * _guiProc
std::pair< int, std::string > _event
