YACS::HMI::EditionBloc Class Reference
#include <EditionBloc.hxx>
Inheritance diagram for YACS::HMI::EditionBloc:
Collaboration diagram for YACS::HMI::EditionBloc:
 EditionBloc (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionBloc ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
PropertyEditor * _propeditor
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
virtual void onApply ()
virtual void onCancel ()
static void setEventMap ()
Definition at line 31 of file EditionBloc.hxx.
◆ EditionBloc()
EditionBloc::EditionBloc ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 31 of file EditionBloc.cxx.
34 : EditionNode(subject, parent, name)
35{
37 _wid->gridLayout1->addWidget(_propeditor);
38}
WidEditItem * _wid
Definition: EditionBloc.hxx:41
EditionNode(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionNode.cxx:35
A class to edit properties of a subject.
References _propeditor, YACS::HMI::ItemEditionBase::_subject, and FormEditItem::_wid.
◆ ~EditionBloc()
EditionBloc::~EditionBloc ( )
Definition at line 40 of file EditionBloc.cxx.
41{
42}
◆ update()
void EditionBloc::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Reimplemented in YACS::HMI::EditionProc, and YACS::HMI::EditionSwitch.
Definition at line 44 of file EditionBloc.cxx.
45{
46 DEBTRACE("EditionBloc::update " <<eventName(event) << " " << type);
47 if(event == SETVALUE)
49}
void update()
Update the property items with their values in the subject.
References _propeditor, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::SETVALUE, and YACS::HMI::PropertyEditor::update().
Referenced by gui.graph.MyCanvas::customEvent(), YACS::HMI::EditionProc::update(), and YACS::HMI::EditionSwitch::update().
◆ _propeditor
PropertyEditor* YACS::HMI::EditionBloc::_propeditor
Definition at line 41 of file EditionBloc.hxx.
Referenced by EditionBloc(), and update().
