YACS::HMI::EditionInputPort Class Reference
#include <EditionInputPort.hxx>
Inheritance diagram for YACS::HMI::EditionInputPort:
Collaboration diagram for YACS::HMI::EditionInputPort:
 EditionInputPort (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionInputPort ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
virtual void onApply ()
virtual void onCancel ()
static void setEventMap ()
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
Definition at line 30 of file EditionInputPort.hxx.
◆ EditionInputPort()
EditionInputPort::EditionInputPort ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 36 of file EditionInputPort.cxx.
39 : ItemEdition(subject, parent, name)
40{
41 if (!QtGuiContext::getQtCurrent()->isEdition())
42 return;
43
44 SubjectDataPort *sdp = dynamic_cast<SubjectDataPort*>(_subject);
45 Node *parentNode = sdp->getPort()->getNode();
46 if (parentNode)
47 if (dynamic_cast<DataNode*>(parentNode) || dynamic_cast<InlineNode*>(parentNode))
48 _wid->le_name->setReadOnly(false);
49}
WidEditItem * _wid
Definition: DataNode.hxx:38
Definition: InlineNode.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
virtual YACS::ENGINE::DataPort * getPort()
References YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, YACS::ENGINE::Port::getNode(), YACS::HMI::SubjectDataPort::getPort(), and YACS::HMI::QtGuiContext::getQtCurrent().
◆ ~EditionInputPort()
EditionInputPort::~EditionInputPort ( )
Definition at line 51 of file EditionInputPort.cxx.
52{
53}
◆ select()
void EditionInputPort::select ( bool  isSelected)
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 55 of file EditionInputPort.cxx.
56{
57 DEBTRACE("EditionInputPort::select " << isSelected);
58 if (isSelected)
59 {
60 Subject *snode = _subject->getParent();
61 if (snode)
62 {
63 if(QtGuiContext::getQtCurrent()->_mapOfEditionItem.count(snode) == 0)
64 {
65 //panel is not created. Force its creation
66 update(YACS::HMI::ADD,snode->getType(),snode);
67 }
69 ItemEdition *item = dynamic_cast<ItemEdition*>(widget);
70 item->synchronize();
71 QtGuiContext::getQtCurrent()->getStackedWidget()->setCurrentWidget(widget);
72 }
73 else
74 {
76 QtGuiContext::getQtCurrent()->getStackedWidget()->setCurrentWidget(this);
77 }
78 }
79}
virtual void synchronize()
QStackedWidget * getStackedWidget()
std::map< YACS::HMI::Subject *, QWidget * > _mapOfEditionItem
virtual Subject * getParent()
virtual TypeOfElem getType()
References YACS::HMI::QtGuiContext::_mapOfEditionItem, YACS::HMI::ItemEditionBase::_subject, YACS::HMI::ADD, DEBTRACE, YACS::HMI::Subject::getParent(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getStackedWidget(), YACS::HMI::Subject::getType(), YACS::HMI::ItemEdition::synchronize(), and YACS::HMI::ItemEdition::update().
