YACS::HMI::EditionWhile Class Reference
#include <EditionWhile.hxx>
Inheritance diagram for YACS::HMI::EditionWhile:
Collaboration diagram for YACS::HMI::EditionWhile:
Public Slots
virtual void onConditionEdited ()
virtual void onApply ()
virtual void onCancel ()
 EditionWhile (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionWhile ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
FormLoop * _formWhile
bool _condition
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 31 of file EditionWhile.hxx.
◆ EditionWhile()
EditionWhile::EditionWhile ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 36 of file EditionWhile.cxx.
39 : EditionNode(subject, parent, name)
40{
41 _formWhile = new FormLoop(this);
42 _condition = 0;
43 _wid->gridLayout1->addWidget(_formWhile);
44 _formWhile->sb_nsteps->setMinimum(0);
45 _formWhile->sb_nsteps->setMaximum(1);
46 _formWhile->label->setText("Condition");
47 if (!QtGuiContext::getQtCurrent()->isEdition())
48 _formWhile->setEnabled (false);
49 connect(_formWhile->sb_nsteps, SIGNAL(editingFinished()),
50 this, SLOT(onConditionEdited()));
51}
WidEditItem * _wid
EditionNode(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionNode.cxx:35
virtual void onConditionEdited()
References _condition, _formWhile, FormEditItem::_wid, YACS::HMI::QtGuiContext::getQtCurrent(), and onConditionEdited().
◆ ~EditionWhile()
EditionWhile::~EditionWhile ( )
Definition at line 53 of file EditionWhile.cxx.
54{
55}
◆ onConditionEdited
void EditionWhile::onConditionEdited ( )
virtualslot
Definition at line 57 of file EditionWhile.cxx.
58{
59 int newval = _formWhile->sb_nsteps->value();
60 DEBTRACE("EditionWhile::onConditionEdited " << _condition << " --> " << newval);
61 if (newval != _condition)
62 {
63 SubjectWhileLoop *swl = dynamic_cast<SubjectWhileLoop*>(_subject);
64 YASSERT(swl);
65 QString text = _formWhile->sb_nsteps->cleanText();
66 swl->setCondition(text.toStdString());
67 }
68}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual bool setCondition(std::string condition)
References _condition, _formWhile, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::SubjectWhileLoop::setCondition(), and YASSERT.
Referenced by EditionWhile().
◆ synchronize()
void EditionWhile::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 70 of file EditionWhile.cxx.
71{
73}
References YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ update()
void EditionWhile::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Definition at line 75 of file EditionWhile.cxx.
76{
77 DEBTRACE("EditionWhile::update " << eventName(event) << " " << type);
78 EditionNode::update(event, type, son);
79 switch (event)
80 {
81 case SETVALUE:
82 SubjectComposedNode * scn = dynamic_cast<SubjectComposedNode*>(_subject);
83 string val = scn->getValue();
84 if (val == "True") val = "1";
85 else if (val == "False") val = "0";
86 DEBTRACE(val);
87 istringstream ss(val);
88 bool i = 0;
89 ss >> i;
90 DEBTRACE(i);
91 _formWhile->sb_nsteps->setValue(i);
92 _condition = i;
93 break;
94 }
95}
Definition: EditionNode.cxx:64
virtual std::string getValue()
References _condition, _formWhile, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::SubjectComposedNode::getValue(), yacsorb.CORBAEngineTest::i, YACS::HMI::SETVALUE, and YACS::HMI::EditionNode::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _condition
bool YACS::HMI::EditionWhile::_condition
Definition at line 48 of file EditionWhile.hxx.
Referenced by EditionWhile(), onConditionEdited(), and update().
◆ _formWhile
FormLoop* YACS::HMI::EditionWhile::_formWhile
Definition at line 47 of file EditionWhile.hxx.
