YACS::HMI::SubjectWhileLoop Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectWhileLoop:
Collaboration diagram for YACS::HMI::SubjectWhileLoop:
 SubjectWhileLoop (YACS::ENGINE::WhileLoop *whileLoop, Subject *parent)
virtual ~SubjectWhileLoop ()
virtual SubjectNode * addNode (YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst)
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual void completeChildrenSubjectList (SubjectNode *son)
virtual SubjectNode * getChild (YACS::ENGINE::Node *node=0) const
virtual bool setCondition (std::string condition)
virtual bool hasValue ()
virtual std::string getValue ()
virtual void houseKeepingAfterCutPaste (bool isCut, SubjectNode *son)
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectComposedNode
 SubjectComposedNode (YACS::ENGINE::ComposedNode *composedNode, Subject *parent)
virtual ~SubjectComposedNode ()
virtual void loadChildren ()
virtual void loadLinks ()
SubjectNode * addSubjectNode (YACS::ENGINE::Node *node, std::string name="", YACS::ENGINE::Catalog *catalog=0, std::string compo="", std::string type="")
SubjectLink * addSubjectLink (SubjectNode *sno, SubjectDataPort *spo, SubjectNode *sni, SubjectDataPort *spi)
SubjectControlLink * addSubjectControlLink (SubjectNode *sno, SubjectNode *sni)
virtual void removeLink (SubjectLink *link)
virtual void removeControlLink (SubjectControlLink *link)
virtual void removeExternalControlLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void saveLinks ()
virtual void restoreLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::WhileLoop * _whileLoop
SubjectNode * _body
- Protected Attributes inherited from YACS::HMI::SubjectComposedNode
YACS::ENGINE::ComposedNode * _composedNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectComposedNode
static SubjectComposedNode * getLowestCommonAncestor (SubjectNode *snode1, SubjectNode *snode2)
 Retrieves the lowest common ancestor of 2 nodes. More...
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectComposedNode
virtual SubjectNode * createNode (YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst, int swCase=0)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 561 of file guiObservers.hxx.
◆ SubjectWhileLoop()
SubjectWhileLoop::SubjectWhileLoop ( YACS::ENGINE::WhileLoop *  whileLoop,
Subject *  parent
Definition at line 2999 of file guiObservers.cxx.
3000 : SubjectComposedNode(whileLoop, parent), _whileLoop(whileLoop)
3001{
3002 _body = 0;
3003}
SubjectComposedNode(YACS::ENGINE::ComposedNode *composedNode, Subject *parent)
References _body.
◆ ~SubjectWhileLoop()
SubjectWhileLoop::~SubjectWhileLoop ( )
Definition at line 3005 of file guiObservers.cxx.
3006{
3007 DEBTRACE("SubjectWhileLoop::~SubjectWhileLoop " << getName());
3008}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectNode::getName().
◆ addNode()
SubjectNode * SubjectWhileLoop::addNode ( YACS::ENGINE::Catalog *  catalog,
std::string  compo,
std::string  type,
std::string  name,
bool  newCompoInst
Reimplemented from YACS::HMI::SubjectComposedNode.
Definition at line 3035 of file guiObservers.cxx.
3040{
3041 DEBTRACE("SubjectWhileLoop::addNode(catalog, compo, type, name)");
3042 SubjectNode* body = 0;
3043 if (_body)
3044 {
3045 GuiContext::getCurrent()->_lastErrorMessage = "If you need several nodes in a loop, put the nodes in a bloc";
3046 return body;
3047 }
3048 body = createNode(catalog, compo, type, name, newCompoInst);
3049 return body;
3050}
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
virtual SubjectNode * createNode(YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst, int swCase=0)
References _body, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::SubjectComposedNode::createNode(), DEBTRACE, and YACS::HMI::GuiContext::getCurrent().
Referenced by gui.GraphViewer.GraphViewer::popup().
◆ clean()
void SubjectWhileLoop::clean ( Command *  command = 0)
Definition at line 3010 of file guiObservers.cxx.
3011{
3012 if (_askRegisterUndo)
3013 {
3014 _askRegisterUndo = false;
3016 }
3017 localclean(command);
3019}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectComposedNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ completeChildrenSubjectList()
void SubjectWhileLoop::completeChildrenSubjectList ( SubjectNode *  son)
Definition at line 3060 of file guiObservers.cxx.
3061{
3062 _body = son;
3063}
References _body.
◆ getChild()
virtual SubjectNode * YACS::HMI::SubjectWhileLoop::getChild ( YACS::ENGINE::Node *  node = 0) const
Definition at line 573 of file guiObservers.hxx.
573{ return _body; }
References _body.
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectWhileLoop::getType ( )
Definition at line 580 of file guiObservers.hxx.
580{return WHILELOOP;}
References YACS::HMI::WHILELOOP.
◆ getValue()
std::string SubjectWhileLoop::getValue ( )
used in derived classes using a counter, a selector, or a condition: ForLoop, ForEachLoop, Switch, WhileLoop.
Definition at line 3085 of file guiObservers.cxx.
3086{
3088}
Definition: DataPort.cxx:84
InputPort * edGetConditionPort()
Definition: WhileLoop.hxx:48
References _whileLoop, YACS::ENGINE::WhileLoop::edGetConditionPort(), and YACS::ENGINE::DataPort::getAsString().
◆ hasValue()
bool SubjectWhileLoop::hasValue ( )
Definition at line 3080 of file guiObservers.cxx.
3081{
3082 return true;
3083}
◆ houseKeepingAfterCutPaste()
void SubjectWhileLoop::houseKeepingAfterCutPaste ( bool  isCut,
SubjectNode *  son
Definition at line 3052 of file guiObservers.cxx.
3053{
3054 if (isCut)
3055 _body = 0;
3056 else
3057 _body = son;
3058}
References _body.
◆ localclean()
void SubjectWhileLoop::localclean ( Command *  command = 0)
Definition at line 3021 of file guiObservers.cxx.
3022{
3023 DEBTRACE("SubjectWhileLoop::localClean ");
3024 if (_body)
3025 erase(_body);
3026}
static void erase(Subject *sub, Command *command=0, bool post=false)
References _body, DEBTRACE, and YACS::HMI::Subject::erase().
Referenced by clean().
◆ recursiveUpdate()
void SubjectWhileLoop::recursiveUpdate ( GuiEvent  event,
int  type,
Subject *  son
Reimplemented from YACS::HMI::SubjectNode.
Definition at line 3028 of file guiObservers.cxx.
3029{
3030 update(event, type, son);
3031 if (_body)
3032 _body->recursiveUpdate(event, type, son);
3033}
virtual void recursiveUpdate(GuiEvent event, int type, Subject *son)
References _body, YACS::HMI::SubjectNode::recursiveUpdate(), and YACS::HMI::SubjectNode::update().
◆ setCondition()
bool SubjectWhileLoop::setCondition ( std::string  condition)
Definition at line 3065 of file guiObservers.cxx.
3066{
3067 DEBTRACE("SubjectWhileLoop::setCondition " << condition);
3068 Proc *proc = GuiContext::getCurrent()->getProc();
3069 CommandSetWhileCondition *command =
3070 new CommandSetWhileCondition(proc->getChildName(getNode()), condition);
3071 if (command->execute())
3072 {
3073 GuiContext::getCurrent()->getInvoc()->add(command);
3074 return true;
3075 }
3076 else delete command;
3077 return false;
3078}
Definition: Proc.hxx:44
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectNode::getNode(), and YACS::HMI::GuiContext::getProc().
Referenced by YACS::HMI::EditionWhile::onConditionEdited().
◆ _body
SubjectNode* YACS::HMI::SubjectWhileLoop::_body
◆ _whileLoop
YACS::ENGINE::WhileLoop* YACS::HMI::SubjectWhileLoop::_whileLoop
Definition at line 582 of file guiObservers.hxx.
Referenced by getValue().
