#include <commandsProc.hxx>
| CommandSetWhileCondition (std::string whileLoop, std::string value) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _whileLoop |
| std::string | _value |
| bool | _oldValue |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 456 of file commandsProc.hxx.
| CommandSetWhileCondition::CommandSetWhileCondition | ( | std::string | whileLoop, |
| std::string | value | ||
Definition at line 2650 of file commandsProc.cxx.
protectedvirtual |
Definition at line 2658 of file commandsProc.cxx.
References _value, and _whileLoop.
protectedvirtual |
Definition at line 2664 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _value, _whileLoop, DEBTRACE, YACS::ENGINE::WhileLoop::edGetConditionPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::SubjectNode::update(), and YASSERT.
protectedvirtual |
Definition at line 2688 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _whileLoop, DEBTRACE, YACS::ENGINE::WhileLoop::edGetConditionPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::SubjectNode::update(), and YASSERT.
protected |
Definition at line 467 of file commandsProc.hxx.
Referenced by CommandSetWhileCondition(), localExecute(), and localReverse().
protected |
Definition at line 466 of file commandsProc.hxx.
protected |
Definition at line 465 of file commandsProc.hxx.
