EditionOutputPort.cxx
1
// Copyright (C) 2006-2026 CEA, EDF
2
3
// This library is free software; you can redistribute it and/or
4
// modify it under the terms of the GNU Lesser General Public
5
// License as published by the Free Software Foundation; either
6
// version 2.1 of the License, or (at your option) any later version.
7
8
// This library is distributed in the hope that it will be useful,
9
// but WITHOUT ANY WARRANTY; without even the implied warranty of
10
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11
// Lesser General Public License for more details.
12
13
// You should have received a copy of the GNU Lesser General Public
14
// License along with this library; if not, write to the Free Software
15
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16
17
// See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18
20
EditionOutputPort.hxx
21
QtGuiContext.hxx
DataPort.hxx
23
DataNode.hxx
24
InlineNode.hxx
26
//#define _DEVDEBUG_
27
YacsTrace.hxx
28
using namespace
std;
30
31
using namespace
YACS
32
using namespace
YACS::HMI
33
using namespace
YACS::ENGINE
34
35
EditionOutputPort::EditionOutputPort(
Subject
* subject,
36
QWidget
* parent,
37
const
char
* name)
38
ItemEdition
(subject, parent, name)
39
40
if
QtGuiContext::getQtCurrent
()->isEdition())
41
return
42
43
SubjectDataPort
*sdp =
dynamic_cast<
SubjectDataPort
_subject
44
Node
*parentNode = sdp->
getPort
getNode
45
if
(parentNode)
46
if
dynamic_cast<
DataNode
(parentNode) ||
dynamic_cast<
InlineNode
(parentNode))
47
_wid
->le_name->setReadOnly(
false
48
49
50
EditionOutputPort::~EditionOutputPort
51
52
53
54
void
EditionOutputPort::select
bool
isSelected)
55
56
DEBTRACE
"EditionOutputPort::select "
<< isSelected);
57
if
(isSelected)
58
59
Subject
*snode =
_subject
getParent
60
if
(snode)
61
62
if
()->_mapOfEditionItem.count(snode) == 0)
63
64
//panel is not created. Force its creation
65
update
YACS::HMI::ADD
,snode->
getType
(),snode);
66
67
QWidget
*widget =
_mapOfEditionItem
[snode];
68
ItemEdition
*item =
dynamic_cast<
ItemEdition
(widget);
69
item->
synchronize
70
getStackedWidget
()->setCurrentWidget(widget);
71
72
else
73
74
synchronize
75
getStackedWidget
this
76
77
78
DataNode.hxx
DataPort.hxx
InlineNode.hxx
QtGuiContext.hxx
YacsTrace.hxx
DEBTRACE
Definition:
YacsTrace.hxx:31
FormEditItem::_wid
WidEditItem * _wid
Definition:
FormEditItem.hxx:53
QWidget
YACS::ENGINE::DataNode
Definition:
DataNode.hxx:38
YACS::ENGINE::InlineNode
Definition:
InlineNode.hxx:44
YACS::ENGINE::Node
Base class for all nodes.
Definition:
Node.hxx:70
YACS::ENGINE::Port::getNode
Node * getNode() const
Definition:
Port.hxx:46
YACS::HMI::EditionOutputPort::~EditionOutputPort
virtual ~EditionOutputPort()
Definition:
EditionOutputPort.cxx:50
YACS::HMI::EditionOutputPort::select
virtual void select(bool isSelected)
Definition:
EditionOutputPort.cxx:54
YACS::HMI::ItemEditionBase::_subject
Subject * _subject
Definition:
ItemEdition.hxx:46
Definition:
ItemEdition.hxx:54
YACS::HMI::ItemEdition::update
Definition:
ItemEdition.cxx:298
YACS::HMI::ItemEdition::synchronize
virtual void synchronize()
Definition:
ItemEdition.cxx:194
YACS::HMI::QtGuiContext::getStackedWidget
QStackedWidget * getStackedWidget()
Definition:
QtGuiContext.hxx:64
YACS::HMI::QtGuiContext::getQtCurrent
Definition:
QtGuiContext.hxx:92
YACS::HMI::QtGuiContext::_mapOfEditionItem
std::map< YACS::HMI::Subject *, QWidget * > _mapOfEditionItem
Definition:
QtGuiContext.hxx:97
YACS::HMI::SubjectDataPort
Definition:
guiObservers.hxx:204
YACS::HMI::SubjectDataPort::getPort
virtual YACS::ENGINE::DataPort * getPort()
Definition:
guiObservers.cxx:3592
YACS::HMI::Subject
Definition:
guiObservers.hxx:118
YACS::HMI::Subject::getParent
virtual Subject * getParent()
Definition:
guiObservers.cxx:220
YACS::HMI::Subject::getType
virtual TypeOfElem getType()
Definition:
guiObservers.hxx:144
YACS::ENGINE
Definition:
AbstractPoint.hxx:37
YACS::HMI
Definition:
commands.hxx:37
YACS::HMI::ADD
@ ADD
Definition:
guiObservers.hxx:84
YACS
Definition:
AlternateThreadPT.hxx:27
genericgui
