YACS::HMI::EditionForEachLoop Class Reference
#include <EditionForEachLoop.hxx>
Inheritance diagram for YACS::HMI::EditionForEachLoop:
Collaboration diagram for YACS::HMI::EditionForEachLoop:
Public Slots
virtual void onModifyCollection ()
virtual void onNbBranchesEdited ()
virtual void onApply ()
virtual void onCancel ()
 EditionForEachLoop (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionForEachLoop ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
FormEachLoop * _formEachLoop
int _nbBranches
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 31 of file EditionForEachLoop.hxx.
◆ EditionForEachLoop()
EditionForEachLoop::EditionForEachLoop ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 39 of file EditionForEachLoop.cxx.
42 : EditionNode(subject, parent, name)
43{
44 _formEachLoop = new FormEachLoop(this);
45 _nbBranches = 1;
46 _wid->gridLayout1->addWidget(_formEachLoop);
47 _formEachLoop->sb_nbranch->setMinimum(1);
48 _formEachLoop->sb_nbranch->setMaximum(INT_MAX);
49 if (!QtGuiContext::getQtCurrent()->isEdition())
50 _formEachLoop->setEnabled (false);
51 Node* node=_subjectNode->getNode();
52 ForEachLoopGen *fe = dynamic_cast<ForEachLoopGen*>(node);
53 if(fe)
54 _formEachLoop->lineEdit->setText(fe->edGetSamplePort()->edGetType()->name());
55 connect(_formEachLoop->sb_nbranch, SIGNAL(editingFinished()),
56 this, SLOT(onNbBranchesEdited()));
57
58 connect(_formEachLoop->lineEdit_2, SIGNAL(editingFinished()),this,SLOT(onModifyCollection()));
59
60}
WidEditItem * _wid
TypeCode * edGetType() const
Definition: DataPort.hxx:53
OutputPort * edGetSamplePort()
Definition: DynParaLoop.hxx:90
Base class for all nodes.
Definition: Node.hxx:70
Definition: TypeCode.cxx:72
EditionNode(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionNode.cxx:35
Definition: EditionNode.hxx:48
References _formEachLoop, _nbBranches, YACS::HMI::EditionNode::_subjectNode, FormEditItem::_wid, YACS::ENGINE::DynParaLoop::edGetSamplePort(), YACS::ENGINE::DataPort::edGetType(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::ENGINE::TypeCode::name(), onModifyCollection(), and onNbBranchesEdited().
◆ ~EditionForEachLoop()
EditionForEachLoop::~EditionForEachLoop ( )
Definition at line 62 of file EditionForEachLoop.cxx.
63{
64}
◆ onModifyCollection
void EditionForEachLoop::onModifyCollection ( )
virtualslot
Definition at line 66 of file EditionForEachLoop.cxx.
67{
68 bool isOk = false;
69 Node* node=_subjectNode->getNode();
70 ForEachLoopGen *fe = dynamic_cast<ForEachLoopGen*>(node);
73 isOk=sdp->setValue(_formEachLoop->lineEdit_2->text().toStdString());
74 DEBTRACE(isOk);
75}
InputPort * edGetSeqOfSamplesPort()
Base class for Input Ports.
Definition: InputPort.hxx:44
Definition: guiContext.hxx:71
virtual bool setValue(std::string value)
References _formEachLoop, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::ENGINE::ForEachLoopGen::edGetSeqOfSamplesPort(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::SubjectDataPort::setValue().
Referenced by EditionForEachLoop().
◆ onNbBranchesEdited
void EditionForEachLoop::onNbBranchesEdited ( )
virtualslot
Definition at line 77 of file EditionForEachLoop.cxx.
78{
79 int newval = _formEachLoop->sb_nbranch->value();
80 DEBTRACE("EditionForEachLoop::onNbBranchesEdited " << _nbBranches << " --> " << newval);
81 if (newval != _nbBranches)
82 {
83 SubjectForEachLoop *sfe = dynamic_cast<SubjectForEachLoop*>(_subject);
84 YASSERT(sfe);
85 QString text = _formEachLoop->sb_nbranch->cleanText();
86 sfe->setNbBranches(text.toStdString());
87 }
88}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual bool setNbBranches(std::string nbBranches)
References _formEachLoop, _nbBranches, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::SubjectDynParaLoop::setNbBranches(), and YASSERT.
◆ synchronize()
void EditionForEachLoop::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 90 of file EditionForEachLoop.cxx.
91{
93}
References YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ update()
void EditionForEachLoop::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Definition at line 95 of file EditionForEachLoop.cxx.
96{
97 DEBTRACE("EditionForEachLoop::update " << eventName(event) << " " << type);
98 EditionNode::update(event, type, son);
99 switch (event)
100 {
101 case SETVALUE:
102 SubjectComposedNode * scn = dynamic_cast<SubjectComposedNode*>(_subject);
103 string val = scn->getValue();
104 istringstream ss(val);
105 DEBTRACE( val);
106 int i = 0;
107 ss >> i;
108 DEBTRACE(i);
109 _formEachLoop->sb_nbranch->setValue(i);
110 _nbBranches = i;
111
112 //smplscollection
113 InputPort* dp=_subjectNode->getNode()->getInputPort("SmplsCollection");
114 _formEachLoop->lineEdit_2->setText(dp->getAsString().c_str());
115 break;
116 }
117}
Definition: DataPort.cxx:84
virtual InputPort * getInputPort(const std::string &name) const
Definition: Node.cxx:260
Definition: EditionNode.cxx:64
virtual std::string getValue()
References _formEachLoop, _nbBranches, YACS::HMI::ItemEditionBase::_subject, YACS::HMI::EditionNode::_subjectNode, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::Node::getInputPort(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::SubjectComposedNode::getValue(), yacsorb.CORBAEngineTest::i, YACS::HMI::SETVALUE, and YACS::HMI::EditionNode::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _formEachLoop
FormEachLoop* YACS::HMI::EditionForEachLoop::_formEachLoop
◆ _nbBranches
int YACS::HMI::EditionForEachLoop::_nbBranches
Definition at line 49 of file EditionForEachLoop.hxx.
Referenced by EditionForEachLoop(), onNbBranchesEdited(), and update().
