YACS::HMI::EditionContainer Class Reference
#include <EditionContainer.hxx>
Inheritance diagram for YACS::HMI::EditionContainer:
Collaboration diagram for YACS::HMI::EditionContainer:
Public Slots
virtual void fillContainerPanel ()
virtual void onApply ()
virtual void onCancel ()
 EditionContainer (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionContainer ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
FormContainerDecorator * _wContainer
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
YACS::ENGINE::Container * getContainer ()
static void setEventMap ()
Definition at line 32 of file EditionContainer.hxx.
◆ EditionContainer()
EditionContainer::EditionContainer ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 39 of file EditionContainer.cxx.
39 :ItemEdition(subject, parent, name)
40{
42 _wid->gridLayout1->addWidget(_wContainer);
43 connect(_wContainer, SIGNAL(resourceMousePressed()), this, SLOT(fillContainerPanel()));
44 connect(_wContainer->tb_container, SIGNAL(toggled(bool)), this, SLOT(fillContainerPanel())); // --- to update display of current selection
45 _wContainer->tb_container->toggle();
46}
WidEditItem * _wid
YACS::ENGINE::Container * getContainer()
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
References _wContainer, FormEditItem::_wid, fillContainerPanel(), and getContainer().
◆ ~EditionContainer()
EditionContainer::~EditionContainer ( )
Definition at line 48 of file EditionContainer.cxx.
49{
50}
◆ fillContainerPanel
void EditionContainer::fillContainerPanel ( )
virtualslot
Definition at line 68 of file EditionContainer.cxx.
69{
70 DEBTRACE("EditionContainer::fillContainerPanel");
72}
void FillPanel(YACS::ENGINE::Container *container)
References _wContainer, DEBTRACE, FormContainerDecorator::FillPanel(), and getContainer().
Referenced by EditionContainer(), and update().
◆ getContainer()
YACS::ENGINE::Container * EditionContainer::getContainer ( )
Definition at line 96 of file EditionContainer.cxx.
97{
99 YASSERT(scont);
100 return scont->getContainer();
101}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
References YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SubjectContainerBase::getContainer(), and YASSERT.
Referenced by EditionContainer(), and fillContainerPanel().
◆ onApply
void EditionContainer::onApply ( )
virtualslot
Definition at line 74 of file EditionContainer.cxx.
75{
76 DEBTRACE("EditionContainer::onApply");
77 bool edited = true;
78 if (!_wContainer->onApply())
79 {
80 _isEdited = true;
81 Message mess(GuiContext::getCurrent()->_lastErrorMessage);
82 return;
83 }
84 edited = false;
85 _isEdited = _isEdited || edited;
87}
Definition: guiContext.hxx:67
virtual void onApply()
References YACS::HMI::ItemEdition::_isEdited, _wContainer, DEBTRACE, YACS::HMI::GuiContext::getCurrent(), FormContainerDecorator::onApply(), and YACS::HMI::ItemEdition::onApply().
◆ onCancel
void EditionContainer::onCancel ( )
virtualslot
◆ update()
void EditionContainer::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 52 of file EditionContainer.cxx.
53{
54 DEBTRACE("EditionContainer::update");
55 ItemEdition::update(event, type, son);
56 switch (event)
57 {
58 case RENAME:
59 case UPDATE:
62 break;
63 default:
64 ;
65 }
66}
virtual std::string getName()
References _wContainer, DEBTRACE, fillContainerPanel(), YACS::HMI::Subject::getName(), YACS::HMI::RENAME, FormContainerDecorator::setName(), YACS::HMI::ItemEdition::update(), and YACS::HMI::UPDATE.
Referenced by gui.graph.MyCanvas::customEvent().
◆ _wContainer
FormContainerDecorator* YACS::HMI::EditionContainer::_wContainer
Definition at line 53 of file EditionContainer.hxx.
Referenced by EditionContainer(), fillContainerPanel(), onApply(), onCancel(), and update().
