YACS::HMI::EditionLoop Class Reference
#include <EditionLoop.hxx>
Inheritance diagram for YACS::HMI::EditionLoop:
Collaboration diagram for YACS::HMI::EditionLoop:
Public Slots
virtual void onNbStepsEdited ()
virtual void onApply ()
virtual void onCancel ()
 EditionLoop (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionLoop ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
FormLoop * _formLoop
QLineEdit * _le_index
int _nbsteps
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 31 of file EditionLoop.hxx.
◆ EditionLoop()
EditionLoop::EditionLoop ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 37 of file EditionLoop.cxx.
40 : EditionNode(subject, parent, name)
41{
42 _formLoop = new FormLoop(this);
43 _nbsteps = 0;
44 _wid->gridLayout1->addWidget(_formLoop);
45
46 QHBoxLayout* _hbl_index = new QHBoxLayout();
47 QLabel* _la_index = new QLabel(this);
48 _hbl_index->addWidget(_la_index);
49 _la_index->setText("index:");
50 _le_index = new QLineEdit(this);
51 _le_index->setText(QString::number(0));
52 _le_index->setReadOnly(true);
53 _hbl_index->addWidget(_le_index);
54 _formLoop->gridLayout->addLayout(_hbl_index, 1, 0);
55
56 _formLoop->sb_nsteps->setMinimum(0);
57 _formLoop->sb_nsteps->setMaximum(INT_MAX);
58 if (!QtGuiContext::getQtCurrent()->isEdition())
59 _formLoop->setEnabled (false);
60
61 connect(_formLoop->sb_nsteps, SIGNAL(editingFinished()),
62 this, SLOT(onNbStepsEdited()));
63}
WidEditItem * _wid
virtual void onNbStepsEdited()
Definition: EditionLoop.cxx:69
EditionNode(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionNode.cxx:35
References _formLoop, _le_index, _nbsteps, FormEditItem::_wid, YACS::HMI::QtGuiContext::getQtCurrent(), and onNbStepsEdited().
◆ ~EditionLoop()
EditionLoop::~EditionLoop ( )
Definition at line 65 of file EditionLoop.cxx.
66{
67}
◆ onNbStepsEdited
void EditionLoop::onNbStepsEdited ( )
virtualslot
Definition at line 69 of file EditionLoop.cxx.
70{
71 int newval = _formLoop->sb_nsteps->value();
72 DEBTRACE("EditionLoop::onNbStepsEdited " << _nbsteps << " --> " << newval);
73 if (newval != _nbsteps)
74 {
75 SubjectForLoop *sfl = dynamic_cast<SubjectForLoop*>(_subject);
76 YASSERT(sfl);
77 QString text = _formLoop->sb_nsteps->cleanText();
78 sfl->setNbSteps(text.toStdString());
79 }
80}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual bool setNbSteps(std::string nbSteps)
References _formLoop, _nbsteps, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::SubjectForLoop::setNbSteps(), and YASSERT.
Referenced by EditionLoop().
◆ synchronize()
void EditionLoop::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 82 of file EditionLoop.cxx.
83{
85}
References YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ update()
void EditionLoop::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Definition at line 87 of file EditionLoop.cxx.
88{
89 DEBTRACE("EditionLoop::update " <<eventName(event) << " " << type);
90 EditionNode::update(event, type, son);
91 switch (event)
92 {
93 case SETVALUE:
94 {
95 SubjectComposedNode * scn = dynamic_cast<SubjectComposedNode*>(_subject);
96 string val = scn->getValue();
97 istringstream ss(val);
98 DEBTRACE(val);
99 int i = 0;
100 ss >> i;
101 DEBTRACE(i);
102 _formLoop->sb_nsteps->setValue(i);
103 _nbsteps = i;
104
105 YACS::ENGINE::OutputPort* odp=scn->getNode()->getOutputPort("index");
107 _le_index->setText(QString::fromStdString(sodp->getExecValue()));
108 break;
109 }
110 case UPDATEPROGRESS:
111 {
112 SubjectComposedNode * scn = dynamic_cast<SubjectComposedNode*>(_subject);
113 YACS::ENGINE::OutputPort* odp=scn->getNode()->getOutputPort("index");
115 _le_index->setText(QString::fromStdString(sodp->getExecValue()));
116 break;
117 }
118 }
119}
virtual OutputPort * getOutputPort(const std::string &name) const =0
Definition: EditionNode.cxx:64
Definition: guiContext.hxx:71
virtual std::string getValue()
References _formLoop, _le_index, YACS::HMI::GuiContext::_mapOfSubjectDataPort, _nbsteps, YACS::HMI::ItemEditionBase::_subject, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::SubjectDataPort::getExecValue(), YACS::HMI::SubjectNode::getNode(), YACS::ENGINE::Node::getOutputPort(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::SubjectComposedNode::getValue(), yacsorb.CORBAEngineTest::i, YACS::HMI::SETVALUE, YACS::HMI::EditionNode::update(), and YACS::HMI::UPDATEPROGRESS.
Referenced by gui.graph.MyCanvas::customEvent().
◆ _formLoop
FormLoop* YACS::HMI::EditionLoop::_formLoop
Definition at line 47 of file EditionLoop.hxx.
Referenced by EditionLoop(), onNbStepsEdited(), and update().
◆ _le_index
QLineEdit* YACS::HMI::EditionLoop::_le_index
Definition at line 48 of file EditionLoop.hxx.
Referenced by EditionLoop(), and update().
◆ _nbsteps
int YACS::HMI::EditionLoop::_nbsteps
Definition at line 49 of file EditionLoop.hxx.
