YACS::HMI::SubjectForLoop Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectForLoop:
Collaboration diagram for YACS::HMI::SubjectForLoop:
 SubjectForLoop (YACS::ENGINE::ForLoop *forLoop, Subject *parent)
virtual ~SubjectForLoop ()
virtual SubjectNode * addNode (YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst)
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual void completeChildrenSubjectList (SubjectNode *son)
virtual SubjectNode * getChild (YACS::ENGINE::Node *node=0) const
virtual bool setNbSteps (std::string nbSteps)
virtual bool hasValue ()
virtual std::string getValue ()
virtual void houseKeepingAfterCutPaste (bool isCut, SubjectNode *son)
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectComposedNode
 SubjectComposedNode (YACS::ENGINE::ComposedNode *composedNode, Subject *parent)
virtual ~SubjectComposedNode ()
virtual void loadChildren ()
virtual void loadLinks ()
SubjectNode * addSubjectNode (YACS::ENGINE::Node *node, std::string name="", YACS::ENGINE::Catalog *catalog=0, std::string compo="", std::string type="")
SubjectLink * addSubjectLink (SubjectNode *sno, SubjectDataPort *spo, SubjectNode *sni, SubjectDataPort *spi)
SubjectControlLink * addSubjectControlLink (SubjectNode *sno, SubjectNode *sni)
virtual void removeLink (SubjectLink *link)
virtual void removeControlLink (SubjectControlLink *link)
virtual void removeExternalControlLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void saveLinks ()
virtual void restoreLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::ForLoop * _forLoop
SubjectNode * _body
- Protected Attributes inherited from YACS::HMI::SubjectComposedNode
YACS::ENGINE::ComposedNode * _composedNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectComposedNode
static SubjectComposedNode * getLowestCommonAncestor (SubjectNode *snode1, SubjectNode *snode2)
 Retrieves the lowest common ancestor of 2 nodes. More...
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectComposedNode
virtual SubjectNode * createNode (YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst, int swCase=0)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 536 of file guiObservers.hxx.
◆ SubjectForLoop()
SubjectForLoop::SubjectForLoop ( YACS::ENGINE::ForLoop *  forLoop,
Subject *  parent
Definition at line 2907 of file guiObservers.cxx.
2908 : SubjectComposedNode(forLoop, parent), _forLoop(forLoop)
2909{
2910 _body = 0;
2911}
SubjectComposedNode(YACS::ENGINE::ComposedNode *composedNode, Subject *parent)
References _body.
◆ ~SubjectForLoop()
SubjectForLoop::~SubjectForLoop ( )
Definition at line 2913 of file guiObservers.cxx.
2914{
2915 DEBTRACE("SubjectForLoop::~SubjectForLoop " << getName());
2916}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectNode::getName().
◆ addNode()
SubjectNode * SubjectForLoop::addNode ( YACS::ENGINE::Catalog *  catalog,
std::string  compo,
std::string  type,
std::string  name,
bool  newCompoInst
Reimplemented from YACS::HMI::SubjectComposedNode.
Definition at line 2943 of file guiObservers.cxx.
2948{
2949 DEBTRACE("SubjectForLoop::addNode("<<catalog<<","<<compo<<","<<type<<","<<name<<")");
2950 SubjectNode* body = 0;
2951 if (_body)
2952 {
2953 GuiContext::getCurrent()->_lastErrorMessage = "If you need several nodes in a loop, put the nodes in a bloc";
2954 return body;
2955 }
2956 body = createNode(catalog, compo, type, name, newCompoInst);
2957 return body;
2958}
Definition: guiContext.hxx:67
std::string _lastErrorMessage
Definition: guiContext.hxx:79
virtual SubjectNode * createNode(YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst, int swCase=0)
References _body, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::SubjectComposedNode::createNode(), DEBTRACE, and YACS::HMI::GuiContext::getCurrent().
Referenced by gui.GraphViewer.GraphViewer::popup().
◆ clean()
void SubjectForLoop::clean ( Command *  command = 0)
Definition at line 2918 of file guiObservers.cxx.
2919{
2920 if (_askRegisterUndo)
2921 {
2922 _askRegisterUndo = false;
2924 }
2925 localclean(command);
2927}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectComposedNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ completeChildrenSubjectList()
void SubjectForLoop::completeChildrenSubjectList ( SubjectNode *  son)
Definition at line 2968 of file guiObservers.cxx.
2969{
2970 _body = son;
2971}
References _body.
◆ getChild()
virtual SubjectNode * YACS::HMI::SubjectForLoop::getChild ( YACS::ENGINE::Node *  node = 0) const
Definition at line 548 of file guiObservers.hxx.
548{ return _body; }
References _body.
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectForLoop::getType ( )
Definition at line 555 of file guiObservers.hxx.
555{return FORLOOP;}
References YACS::HMI::FORLOOP.
◆ getValue()
std::string SubjectForLoop::getValue ( )
used in derived classes using a counter, a selector, or a condition: ForLoop, ForEachLoop, Switch, WhileLoop.
Definition at line 2992 of file guiObservers.cxx.
2993{
2995}
Definition: DataPort.cxx:84
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
References _forLoop, YACS::ENGINE::ForLoop::edGetNbOfTimesInputPort(), and YACS::ENGINE::DataPort::getAsString().
◆ hasValue()
bool SubjectForLoop::hasValue ( )
Definition at line 2987 of file guiObservers.cxx.
2988{
2989 return true;
2990}
◆ houseKeepingAfterCutPaste()
void SubjectForLoop::houseKeepingAfterCutPaste ( bool  isCut,
SubjectNode *  son
Definition at line 2960 of file guiObservers.cxx.
2961{
2962 if (isCut)
2963 _body = 0;
2964 else
2965 _body = son;
2966}
References _body.
◆ localclean()
void SubjectForLoop::localclean ( Command *  command = 0)
Definition at line 2929 of file guiObservers.cxx.
2930{
2931 DEBTRACE("SubjectForLoop::localClean ");
2932 if (_body)
2933 erase(_body);
2934}
static void erase(Subject *sub, Command *command=0, bool post=false)
References _body, DEBTRACE, and YACS::HMI::Subject::erase().
Referenced by clean().
◆ recursiveUpdate()
void SubjectForLoop::recursiveUpdate ( GuiEvent  event,
int  type,
Subject *  son
Reimplemented from YACS::HMI::SubjectNode.
Definition at line 2936 of file guiObservers.cxx.
2937{
2938 update(event, type, son);
2939 if (_body)
2940 _body->recursiveUpdate(event, type, son);
2941}
virtual void recursiveUpdate(GuiEvent event, int type, Subject *son)
References _body, YACS::HMI::SubjectNode::recursiveUpdate(), and YACS::HMI::SubjectNode::update().
◆ setNbSteps()
bool SubjectForLoop::setNbSteps ( std::string  nbSteps)
Definition at line 2973 of file guiObservers.cxx.
2974{
2975 DEBTRACE("SubjectForLoop::setNbSteps " << nbSteps);
2976 Proc *proc = GuiContext::getCurrent()->getProc();
2977 CommandSetForLoopSteps *command =
2978 new CommandSetForLoopSteps(proc->getChildName(getNode()), nbSteps);
2979 if (command->execute())
2980 {
2981 GuiContext::getCurrent()->getInvoc()->add(command);
2982 return true;
2983 }
2984 else delete command;
2985 return false;
2986}
Definition: Proc.hxx:44
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectNode::getNode(), and YACS::HMI::GuiContext::getProc().
Referenced by YACS::HMI::EditionLoop::onNbStepsEdited().
◆ _body
SubjectNode* YACS::HMI::SubjectForLoop::_body
◆ _forLoop
YACS::ENGINE::ForLoop* YACS::HMI::SubjectForLoop::_forLoop
Definition at line 557 of file guiObservers.hxx.
Referenced by getValue().
