YACS::HMI::CommandSetForLoopSteps Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandSetForLoopSteps:
Collaboration diagram for YACS::HMI::CommandSetForLoopSteps:
 CommandSetForLoopSteps (std::string forLoop, std::string value)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _forLoop
std::string _value
int _oldValue
bool _normalReverse
Definition at line 442 of file commandsProc.hxx.
◆ CommandSetForLoopSteps()
CommandSetForLoopSteps::CommandSetForLoopSteps ( std::string  forLoop,
std::string  value
Definition at line 2585 of file commandsProc.cxx.
2587 : Command(), _forLoop(forLoop), _value(value)
2588{
2589 DEBTRACE("CommandSetForLoopSteps::CommandSetForLoopSteps");
2590 _oldValue = 0;
2591}
References _oldValue, and DEBTRACE.
◆ dump()
std::string CommandSetForLoopSteps::dump ( )
Definition at line 2594 of file commandsProc.cxx.
2595{
2596 string ret ="CommandSetForLoopSteps " + _forLoop + " " + _value;
2597 return ret;
2598}
References _forLoop, and _value.
◆ localExecute()
bool CommandSetForLoopSteps::localExecute ( )
Definition at line 2600 of file commandsProc.cxx.
2601{
2602 DEBTRACE("CommandSetForLoopSteps::localExecute");
2603 try
2604 {
2605 DEBTRACE("CommandSetForLoopSteps::localExecute");
2606 Proc* proc = GuiContext::getCurrent()->getProc();
2607 ForLoop* forLoop = dynamic_cast<ForLoop*>(proc->getChildByName(_forLoop));
2608 InputPort *nbSteps = forLoop->edGetNbOfTimesInputPort();
2609 _oldValue = atoi(forLoop->edGetNbOfTimesInputPort()->getAsString().c_str());
2610 int val = atoi(_value.c_str());
2611 nbSteps->edInit(val);
2612 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(forLoop));
2614 snode->update(SETVALUE, 0, snode);
2615 return true;
2616 }
2617 catch (Exception& ex)
2618 {
2619 DEBTRACE("CommandSetForLoopSteps::localExecute() : " << ex.what());
2620 setErrorMsg(ex);
2621 return false;
2622 }
2623}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: DataPort.cxx:84
Class for for loop node.
Definition: ForLoop.hxx:33
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
Base class for Input Ports.
Definition: InputPort.hxx:44
void edInit(T value)
Definition: InputPort.hxx:129
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
References _forLoop, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _value, DEBTRACE, YACS::ENGINE::ForLoop::edGetNbOfTimesInputPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandSetForLoopSteps::localReverse ( )
Definition at line 2625 of file commandsProc.cxx.
2626{
2627 DEBTRACE("CommandSetForLoopSteps::localReverse");
2628 try
2629 {
2630 DEBTRACE("CommandSetForLoopSteps::localReverse");
2631 Proc* proc = GuiContext::getCurrent()->getProc();
2632 ForLoop* forLoop = dynamic_cast<ForLoop*>(proc->getChildByName(_forLoop));
2633 InputPort *nbSteps = forLoop->edGetNbOfTimesInputPort();
2634 nbSteps->edInit(_oldValue);
2635 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(forLoop));
2637 snode->update(SETVALUE, 0, snode);
2638 return true;
2639 }
2640 catch (Exception& ex)
2641 {
2642 DEBTRACE("CommandSetForLoopSteps::localReverse() : " << ex.what());
2643 setErrorMsg(ex);
2644 return false;
2645 }
2646}
References _forLoop, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, DEBTRACE, YACS::ENGINE::ForLoop::edGetNbOfTimesInputPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ _forLoop
std::string YACS::HMI::CommandSetForLoopSteps::_forLoop
Definition at line 451 of file commandsProc.hxx.
◆ _oldValue
int YACS::HMI::CommandSetForLoopSteps::_oldValue
Definition at line 453 of file commandsProc.hxx.
Referenced by CommandSetForLoopSteps(), localExecute(), and localReverse().
◆ _value
std::string YACS::HMI::CommandSetForLoopSteps::_value
Definition at line 452 of file commandsProc.hxx.
