YACS::HMI::EditionDataLink Class Reference
#include <EditionDataLink.hxx>
Inheritance diagram for YACS::HMI::EditionDataLink:
Collaboration diagram for YACS::HMI::EditionDataLink:
 EditionDataLink (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionDataLink ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
PropertyEditor * _propeditor
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
virtual void onApply ()
virtual void onCancel ()
static void setEventMap ()
Definition at line 31 of file EditionDataLink.hxx.
◆ EditionDataLink()
EditionDataLink::EditionDataLink ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 31 of file EditionDataLink.cxx.
34 : ItemEdition(subject, parent, name)
35{
36 SubjectLink * sub = dynamic_cast<SubjectLink*>(_subject);
37 if(dynamic_cast<SubjectInputDataStreamPort*>(sub->getSubjectInPort()))
38 {
40 _wid->gridLayout1->addWidget(_propeditor);
41 }
42}
WidEditItem * _wid
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
A class to edit properties of a subject.
References _propeditor, YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, and YACS::HMI::SubjectLink::getSubjectInPort().
◆ ~EditionDataLink()
EditionDataLink::~EditionDataLink ( )
Definition at line 44 of file EditionDataLink.cxx.
45{
46}
◆ update()
void EditionDataLink::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 48 of file EditionDataLink.cxx.
49{
50 DEBTRACE("EditionDataLink::update " <<eventName(event) << " " << type);
51 if(event == SETVALUE && _propeditor)
53}
void update()
Update the property items with their values in the subject.
References _propeditor, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::SETVALUE, and YACS::HMI::PropertyEditor::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _propeditor
PropertyEditor* YACS::HMI::EditionDataLink::_propeditor
Definition at line 41 of file EditionDataLink.hxx.
Referenced by EditionDataLink(), and update().
