LinkInfo.cxx
20#include "LinkInfo.hxx"
21#include "Switch.hxx"
23#include <sstream>
24
25using namespace std;
26using namespace YACS::ENGINE;
27
28static const char GLOBAL_MESSAGE1[]="Global report : \n";
30static const char LINK_REPR[]="link";
31
32LinkInfo::LinkInfo(unsigned char level):_levelOfInfo(level),_level(0)
33{
34}
35
37{
38 _level=0;
39 _unsetInPort.clear();
40 _onlyBackDefined.clear();
41 _uselessLinks.clear();
42 _infos.clear();
43 _collapse.clear();
44 _errors.clear();
46}
47
49{
50 _level++;
51}
52
54{
55 if(--_level==0)
56 {
59 throw Exception(getGlobalRepr());
62 throw Exception(getErrRepr());
63 }
64}
65
67{
68 _pov=pov;
69}
70
71void LinkInfo::pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
72{
73 _infos[reason].push_back(pair<OutPort *, InPort *>(semStart,end));
74}
75
76void LinkInfo::pushWarnLink(OutPort *semStart, InPort *end, WarnReason reason)
77{
78 if(_collapse[reason].empty())
79 _collapse[reason].push_back(vector< pair<OutPort *,InPort *> >());
80 else
81 if(_collapse[reason].back()[0].second!=end)
82 _collapse[reason].push_back(vector< pair<OutPort *,InPort *> >());
83 _collapse[reason].back().push_back(pair<OutPort *,InPort *>(semStart,end));
84}
85
86void LinkInfo::pushErrLink(OutPort *semStart, InPort *end, ErrReason reason)
87{
88 if(reason==E_NEVER_SET_INPUTPORT)
89 _unsetInPort.push_back(end);
90 else if(reason==E_ONLY_BACKWARD_DEFINED)
91 _onlyBackDefined.push_back(end);
92 else
93 _errors[reason].push_back(pair<OutPort *, InPort *>(semStart,end));
94 if(_level==0)
96 throw Exception(getErrRepr());
97}
98
100{
101 _errorsOnSwitchCases.push_back(collector);
102 if(_level==0)
104 throw Exception(getErrRepr());
105}
106
108{
109 _uselessLinks.insert(pair<Node *,Node *>(start,end));
110}
111
113{
114 if(!_errors.empty())
115 throw Exception(getErrRepr());
116}
117
118std::string LinkInfo::getGlobalRepr() const
119{
120 ostringstream retS; retS << GLOBAL_MESSAGE1;
121 retS << printThereIsAre(getNumberOfErrLinks(E_ALL),"error") << ".\n";
122 retS << printThereIsAre(getNumberOfWarnLinksGrp(W_ALL),"warning") << ".\n";
123 retS << printThereIsAre(getNumberOfInfoLinks(I_ALL),"info") << ".\n";
125 {
126 retS << "****** ERRORS ******" << endl;
127 retS << getErrRepr() << endl;
128 }
130 {
131 retS << "****** WARNINGS ******" << endl;
132 retS << getWarnRepr() << endl;
133 }
135 {
136 retS << "****** INFO ******" << endl;
137 retS << getInfoRepr() << endl;
138 }
139 return retS.str();
140}
141
142std::string LinkInfo::getInfoRepr() const
143{
144 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter;
145 ostringstream stream;
146 for(iter=_infos.begin();iter!=_infos.end();iter++)
147 {
148 for(vector< pair<OutPort *,InPort *> >::const_iterator iter2=(*iter).second.begin();iter2!=(*iter).second.end();iter2++)
149 {
150 stream << getStringReprOfI((*iter).first) << " between \"" << _pov->getOutPortName((*iter2).first);
151 stream << "\" and \"" << _pov->getInPortName((*iter2).second) << "\"." << endl;
152 }
153 }
154 set< pair<Node *, Node *> >::const_iterator iter3;
155 for(iter3=_uselessLinks.begin();iter3!=_uselessLinks.end();iter3++)
156 {
157 stream << "Useless CF link between \"" << _pov->getChildName((*iter3).first);
158 stream << "\" and \"" << _pov->getChildName((*iter3).second) << "\"." << endl;
159 }
160 return stream.str();
161}
162
163std::string LinkInfo::getWarnRepr() const
164{
165 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter;
166 ostringstream stream;
167 unsigned i=0;
168 for(iter=_collapse.begin();iter!=_collapse.end();iter++)
169 {
170 stream << getStringReprOfW((*iter).first) << " for group containing following group links: ";
171 vector< vector< pair<OutPort *,InPort *> > >::const_iterator iter2=(*iter).second.begin();
172 for(;iter2!=(*iter).second.end();iter2++)
173 {
174 stream << " Group # " << i++ << " : " << endl;
175 for(vector< pair<OutPort *,InPort *> >::const_iterator iter3=(*iter2).begin();iter3!=(*iter2).end();iter3++)
176 stream << " \"" << _pov->getOutPortName((*iter3).first) << "\" and \"" << _pov->getInPortName((*iter3).second) << endl;
177 }
178 }
179 return stream.str();
180}
181
182std::string LinkInfo::getErrRepr() const
183{
184 vector<InPort *>::const_iterator iter;
185 ostringstream stream;
186 for(iter=_unsetInPort.begin();iter!=_unsetInPort.end();iter++)
187 stream << getStringReprOfE(E_NEVER_SET_INPUTPORT) << "\"" << _pov->getInPortName(*iter) << "\"." << endl;
188 for(iter=_onlyBackDefined.begin();iter!=_onlyBackDefined.end();iter++)
189 stream << getStringReprOfE(E_ONLY_BACKWARD_DEFINED) << "\"" << _pov->getInPortName(*iter) << "\"." << endl;
190 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter2;
191 for(iter2=_errors.begin();iter2!=_errors.end();iter2++)
192 for(vector< pair<OutPort *,InPort *> >::const_iterator iter3=(*iter2).second.begin();iter3!=(*iter2).second.end();iter3++)
193 stream << getStringReprOfE((*iter2).first) << " between \"" <<_pov->getOutPortName((*iter3).first) << "\" and \"" << _pov->getInPortName((*iter3).second) << endl;
194 for(vector<CollectorSwOutPort *>::const_iterator iter3=_errorsOnSwitchCases.begin();iter3!=_errorsOnSwitchCases.end();iter3++)
195 (*iter3)->getHumanReprOfIncompleteCases(stream);
196 return stream.str();
197}
198
200{
201 return (getNumberOfWarnLinksGrp(W_ALL)!=0) || (getNumberOfErrLinks(E_ALL)!=0) || !_unsetInPort.empty() || !_onlyBackDefined.empty();
202}
203
208{
209 if(reason==I_ALL)
210 {
211 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.begin();
212 unsigned val=0;
213 for(;iter!=_infos.end();iter++)
214 val+=(*iter).second.size();
215 return val+_uselessLinks.size();
216 }
217 if(reason==I_CF_USELESS)
218 return _uselessLinks.size();
219 else
220 {
221 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.find(reason);
222 if(iter!=_infos.end())
223 return (*iter).second.size();
224 else
225 return 0;
226 }
227}
228
230{
231 unsigned ret=0;
232 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter;
233 if(reason==W_ALL)
234 {
235 for(iter=_collapse.begin();iter!=_collapse.end();iter++)
236 ret+=(*iter).second.size();
237 return ret;
238 }
239 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter2=_collapse.find(reason);
240 if(iter2!=_collapse.end())
241 return (*iter2).second.size();
242 else
243 return 0;
244}
245
247{
248 if(reason==E_ALL)
249 return _errors.size()+_onlyBackDefined.size()+_unsetInPort.size()+_errorsOnSwitchCases.size();
250 else if(reason==E_NEVER_SET_INPUTPORT)
251 return _unsetInPort.size();
252 else if(reason==E_ONLY_BACKWARD_DEFINED)
253 return _onlyBackDefined.size();
254 else if(reason==E_UNCOMPLETE_SW)
255 return _errorsOnSwitchCases.size();
256 else
257 {
258 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_errors.find(reason);
259 if(iter!=_errors.end())
260 return (*iter).second.size();
261 else
262 return 0;
263 }
264}
265
266std::set< std::pair<Node *, Node *> > LinkInfo::getInfoUselessLinks() const
267{
268 return _uselessLinks;
269}
270
271std::pair<OutPort *, InPort *> LinkInfo::getInfoLink(unsigned id, InfoReason reason) const
272{
273 if(reason==I_CF_USELESS)
274 return pair<OutPort *, InPort *>();
275 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.find(reason);
276 if(iter!=_infos.end())
277 return (*iter).second[id];
278 else
279 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), reinterpret_cast<InPort *>(0) );
280}
281
282std::vector< std::pair<OutPort *, InPort *> > LinkInfo::getWarnLink(unsigned id, WarnReason reason) const
283{
284 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter=_collapse.find(reason);
285 if(iter!=_collapse.end())
286 return (*iter).second[id];
287 else
288 return vector< pair<OutPort *, InPort *> >();
289}
290
291std::pair<OutPort *, InPort *> LinkInfo::getErrLink(unsigned id, ErrReason reason) const
292{
293 if(reason==E_NEVER_SET_INPUTPORT)
294 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), _unsetInPort[id] );
295 else if(reason==E_ONLY_BACKWARD_DEFINED)
296 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), _onlyBackDefined[id] );
297 else
298 {
299 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_errors.find(reason);
300 if(iter!=_errors.end())
301 return (*iter).second[id];
302 else
303 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), reinterpret_cast<InPort *>(0) );
304 }
305}
306
308{
309 string ret;
310 switch(reason)
311 {
312 case I_USELESS:
313 ret="Useless DF";
314 break;
315 case I_BACK:
316 ret="Back";
317 break;
318 case I_BACK_USELESS:
319 ret="Back and useless";
320 break;
321 case I_BACK_CRAZY:
322 ret+="Crazy back";
323 break;
324 case I_DFDS:
325 ret+="DF/DS";
326 }
327 ret+=" "; ret+=LINK_REPR;
328 return ret;
329}
330
332{
333 string ret;
334 switch(reason)
335 {
336 case W_COLLAPSE:
337 ret="Collapse";
338 break;
340 ret="Collapse and useless";
341 break;
342 case W_COLLAPSE_EL:
343 ret="Collapse on ElementaryNode";
344 break;
346 ret+="Collapse on ElementaryNode and useless";
347 break;
348 case W_BACK_COLLAPSE:
349 ret+="Back collapse";
350 break;
352 ret+="Back collapse and useless";
353 break;
355 ret+="Back collapse on ElementaryNode";
356 break;
358 ret+="Back collapse and useless on ElementaryNode";
359 }
360 ret+=" "; ret+=LINK_REPR;
361 return ret;
362}
363
365{
366 string ret;
367 if(reason==E_NEVER_SET_INPUTPORT)
368 return "Never set InPort ";
369 if(reason==E_ONLY_BACKWARD_DEFINED)
370 return "Never set InPort only back defined ";
371 switch(reason)
372 {
374 ret="DS unestablishable";
375 break;
376 case E_COLLAPSE_DFDS:
377 ret="DF/DS collapse";
378 break;
379 case E_COLLAPSE_DS:
380 ret="Inter DS collapse";
381 break;
383 ret="Unpredictable fed";
384 }
385 ret+=" "; ret+=LINK_REPR;
386 return ret;
387}
388
389std::string LinkInfo::printThereIsAre(unsigned val, const std::string& other)
390{
391 ostringstream ret;
392 ret << "There ";
393 if(val==0)
394 ret << "are no";
395 else if(val==1)
396 ret << "is one";
397 else
398 ret << "are " << val;
399 ret << " " << other;
400 if(val==0 || val>1)
401 ret << "s";
402 return ret.str();
403}
Definition: LinkInfo.cxx:30
Definition: LinkInfo.cxx:28
std::string getOutPortName(const OutPort *) const
std::string getInPortName(const InPort *) const
Get the input port name.
static const unsigned char WARN_ONLY_DONT_STOP
Definition: LinkInfo.hxx:128
void pushErrLink(OutPort *semStart, InPort *end, ErrReason reason)
Definition: LinkInfo.cxx:86
std::vector< InPort * > _onlyBackDefined
Definition: LinkInfo.hxx:89
std::set< std::pair< Node *, Node * > > _uselessLinks
Definition: LinkInfo.hxx:90
unsigned int _level
Definition: LinkInfo.hxx:86
unsigned getNumberOfErrLinks(ErrReason reason) const
Definition: LinkInfo.cxx:246
static const unsigned char ALL_STOP_ASAP
Definition: LinkInfo.hxx:126
void pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
Definition: LinkInfo.cxx:71
std::map< ErrReason, std::vector< std::pair< OutPort *, InPort * > > > _errors
Definition: LinkInfo.hxx:93
void pushUselessCFLink(Node *start, Node *end)
Definition: LinkInfo.cxx:107
std::set< std::pair< Node *, Node * > > getInfoUselessLinks() const
Definition: LinkInfo.cxx:266
static std::string printThereIsAre(unsigned val, const std::string &other)
Definition: LinkInfo.cxx:389
static std::string getStringReprOfI(InfoReason reason)
Definition: LinkInfo.cxx:307
std::string getGlobalRepr() const
Definition: LinkInfo.cxx:118
std::map< InfoReason, std::vector< std::pair< OutPort *, InPort * > > > _infos
Definition: LinkInfo.hxx:91
std::map< WarnReason, std::vector< std::vector< std::pair< OutPort *, InPort * > > > > _collapse
Definition: LinkInfo.hxx:92
ComposedNode * _pov
Definition: LinkInfo.hxx:85
unsigned getNumberOfInfoLinks(InfoReason reason) const
Definition: LinkInfo.cxx:207
void pushWarnLink(OutPort *semStart, InPort *end, WarnReason reason)
Definition: LinkInfo.cxx:76
void takeDecision() const
Definition: LinkInfo.cxx:112
void pushErrSwitch(CollectorSwOutPort *collector)
Definition: LinkInfo.cxx:99
std::vector< InPort * > _unsetInPort
Definition: LinkInfo.hxx:88
std::string getInfoRepr() const
Definition: LinkInfo.cxx:142
std::pair< OutPort *, InPort * > getInfoLink(unsigned id, InfoReason reason) const
Definition: LinkInfo.cxx:271
std::vector< std::pair< OutPort *, InPort * > > getWarnLink(unsigned id, WarnReason reason) const
Definition: LinkInfo.cxx:282
std::string getWarnRepr() const
Definition: LinkInfo.cxx:163
std::vector< CollectorSwOutPort * > _errorsOnSwitchCases
Definition: LinkInfo.hxx:94
bool areWarningsOrErrors() const
Definition: LinkInfo.cxx:199
unsigned char _levelOfInfo
Definition: LinkInfo.hxx:87
std::pair< OutPort *, InPort * > getErrLink(unsigned id, ErrReason reason) const
Definition: LinkInfo.cxx:291
void setPointOfView(ComposedNode *pov)
Definition: LinkInfo.cxx:66
static std::string getStringReprOfW(WarnReason reason)
Definition: LinkInfo.cxx:331
unsigned getNumberOfWarnLinksGrp(WarnReason reason) const
Definition: LinkInfo.cxx:229
std::string getErrRepr() const
Definition: LinkInfo.cxx:182
static std::string getStringReprOfE(ErrReason reason)
Definition: LinkInfo.cxx:364
Base class for all nodes.
Definition: Node.hxx:70
@ E_UNPREDICTABLE_FED
Definition: LinkInfo.hxx:74
@ E_NEVER_SET_INPUTPORT
Definition: LinkInfo.hxx:69
@ E_ONLY_BACKWARD_DEFINED
Definition: LinkInfo.hxx:70
@ E_DS_LINK_UNESTABLISHABLE
Definition: LinkInfo.hxx:71
@ W_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:59
@ W_BACK_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:61
@ W_BACK_COLLAPSE_EL
Definition: LinkInfo.hxx:62
@ W_BACK_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:63
@ W_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:57
