FormContainerBase.cxx
20#include "FormContainerBase.hxx"
22#include "FormComponent.hxx"
23#include "QtGuiContext.hxx"
24#include "Container.hxx"
26#include <cassert>
27#include <cstdlib>
28#include <climits>
30//#define _DEVDEBUG_
31#include "YacsTrace.hxx"
32
33#include <QList>
34#include <sstream>
35
36using namespace std;
37using namespace YACS;
38using namespace YACS::HMI;
39using namespace YACS::ENGINE;
40
41FormContainerBase::FormContainerBase(QWidget *parent):QWidget(parent),_advancedParams(new FormAdvParamContainer(_properties,this))
42{
43 setupUi(this);
44 _advanced = false;
45 gridLayout_2->addWidget(_advancedParams);
47
48 FillPanel(0); // --- set widgets before signal connexion to avoid false modif detection
49 connect(le_name, SIGNAL(textChanged(const QString&)), this, SLOT(onModifyName(const QString&)));
50 connect(cb_resource, SIGNAL(activated(const QString&)), _advancedParams, SLOT(onModifyResource(const QString&)));
51}
52
54{
55 delete _advancedParams;
56}
57
59{
60 DEBTRACE("FormContainer::FillPanel");
61 _container = container;
62 if (_container)
63 {
65 le_name->setText(_container->getName().c_str());
66 }
67 else
68 {
69 _properties.clear();
70 le_name->setText("not defined");
71 }
72
73 //Resources
74 cb_resource->clear();
75 cb_resource->addItem("automatic"); // --- when no resource is selected
76
77 //add available resources
78 list<string> machines = QtGuiContext::getQtCurrent()->getGMain()->getMachineList();
79 list<string>::iterator itm = machines.begin();
80 for( ; itm != machines.end(); ++itm)
81 {
82 cb_resource->addItem(QString((*itm).c_str()));
83 }
84
85 std::string resource;
86 if(_properties.count("name") && _properties["name"] != "")
87 {
88 //a resource has been specified
89 int index = cb_resource->findText(_properties["name"].c_str());
90 if (index > 0)
91 {
92 //the resource is found: use it
93 cb_resource->setCurrentIndex(index);
94 resource=_properties["name"];
95 }
96 else
97 {
98 //the resource has not been found: add a false item
99 std::string item="Unknown resource ("+_properties["name"]+")";
100 cb_resource->addItem(item.c_str());
101 cb_resource->setCurrentIndex(cb_resource->count()-1);
102 }
103 }
104 else
105 cb_resource->setCurrentIndex(0);
106 _advancedParams->FillPanel(resource,container);
107
108 if (!QtGuiContext::getQtCurrent()->isEdition())
109 {
110 //if the schema is in execution do not allow editing
111 le_name->setReadOnly(true);
112 cb_resource->setEnabled(false);
113 }
114}
115
117{
118 DEBTRACE("FormContainerBase::onModified");
119 Subject *sub(QtGuiContext::getQtCurrent()->getSelectedSubject());
120 if (!sub)
121 return;
122 YASSERT(QtGuiContext::getQtCurrent()->_mapOfEditionItem.count(sub));
123 QWidget *widget(QtGuiContext::getQtCurrent()->_mapOfEditionItem[sub]);
124 ItemEdition *item(dynamic_cast<ItemEdition*>(widget));
125 YASSERT(item);
126 item->setEdited(true);
127}
128
130{
131 DEBTRACE("FormContainer::on_ch_advance_stateChanged " << state);
132 if (state)
133 _advancedParams->show();
134 else
135 _advancedParams->hide();
136}
137
138void FormContainerBase::onModifyName(const QString &text)
139{
140 DEBTRACE("onModifyName " << text.toStdString());
141 SubjectContainerBase *scont(QtGuiContext::getQtCurrent()->_mapOfSubjectContainer[_container]);
142 YASSERT(scont);
143 string name = scont->getName();
144 if (name != text.toStdString())
145 onModified();
146}
147
149{
150 SubjectContainerBase *scont(QtGuiContext::getQtCurrent()->_mapOfSubjectContainer[_container]);
151 YASSERT(scont);
152 bool ret(scont->setName(le_name->text().toStdString()));
153 DEBTRACE(ret);
154 if (ret)
155 ret = scont->setProperties(_properties);
156 return ret;
157}
158
160{
161 SubjectContainerBase *scont(QtGuiContext::getQtCurrent()->_mapOfSubjectContainer[_container]);
162 YASSERT(scont);
163 FillPanel(scont->getContainer());
164}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
void FillPanel(const std::string &resource, YACS::ENGINE::Container *container)
virtual bool onApply()
FormContainerBase(QWidget *parent=0)
virtual void onCancel()
virtual void onModified()
std::map< std::string, std::string > _properties
void onModifyName(const QString &text)
YACS::ENGINE::Container * _container
void on_ch_advance_stateChanged(int state)
virtual void FillPanel(YACS::ENGINE::Container *container)
FormAdvParamContainer * _advancedParams
virtual std::map< std::string, std::string > getProperties() const =0
virtual std::string getName() const
Definition: Container.hxx:81
virtual void setEdited(bool isEdited)
virtual bool setProperties(std::map< std::string, std::string > properties)
virtual YACS::ENGINE::Container * getContainer() const
virtual bool setName(std::string name)
std::vector< machine > machines
Definition: factory.hxx:111
