YACS::HMI::CommandRenameOutDataPort Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandRenameOutDataPort:
Collaboration diagram for YACS::HMI::CommandRenameOutDataPort:
 CommandRenameOutDataPort (std::string position, std::string oldName, std::string newName, TypeOfElem portType)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _position
std::string _oldName
std::string _newName
TypeOfElem _portType
bool _normalReverse
Definition at line 231 of file commandsProc.hxx.
◆ CommandRenameOutDataPort()
CommandRenameOutDataPort::CommandRenameOutDataPort ( std::string  position,
TypeOfElem  portType
Definition at line 1039 of file commandsProc.cxx.
1042 : Command(), _position(position), _oldName(oldName), _newName(newName), _portType(portType)
1043{
1044 DEBTRACE("CommandRenameOutDataPort::CommandRenameOutDataPort "
1045 << _position << " " << _oldName<< " " << _newName);
1046}
References _newName, _oldName, _position, and DEBTRACE.
◆ dump()
std::string CommandRenameOutDataPort::dump ( )
Definition at line 1048 of file commandsProc.cxx.
1049{
1050 string ret ="CommandRenameOutDataPort " + _position + " " + _oldName + " " + _newName;
1051 return ret;
1052}
References _newName, _oldName, and _position.
◆ localExecute()
bool CommandRenameOutDataPort::localExecute ( )
Definition at line 1054 of file commandsProc.cxx.
1055{
1056 DEBTRACE("CommandRenameOutDataPort::localExecute");
1057 Proc* proc = GuiContext::getCurrent()->getProc();
1058 Node* node = proc;
1059 try
1060 {
1061 if (_position != proc->getName()) node = proc->getChildByName(_position);
1062 OutPort * port = 0;
1063 try
1064 {
1066 port = node->getOutputPort(_newName);
1067 else
1068 port = node->getOutputDataStreamPort(_newName);
1069 }
1070 catch (Exception& e) {} // --- raised when no existing port with _newName
1071 if (port)
1072 throw Exception("there is already a port with the new name");
1073
1075 port = node->getOutputPort(_oldName);
1076 else
1077 port = node->getOutputDataStreamPort(_oldName);
1078 port->setName(_newName);
1079 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(port));
1081 sport->update(RENAME, 0, sport);
1082 }
1083 catch (Exception& ex)
1084 {
1085 DEBTRACE("CommandRenameOutDataPort::localExecute() : " << ex.what());
1086 setErrorMsg(ex);
1087 node = 0;
1088 }
1089 return (node != 0);
1090}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::string getName() const
void setName(std::string theName)
Definition: DataPort.hxx:56
Base class for all nodes.
Definition: Node.hxx:70
virtual OutputPort * getOutputPort(const std::string &name) const =0
virtual OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const =0
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:71
Definition: guiContext.hxx:50
References YACS::HMI::GuiContext::_mapOfSubjectDataPort, _newName, _oldName, _portType, _position, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::ENGINE::Node::getOutputPort(), YACS::HMI::GuiContext::getProc(), YACS::HMI::OUTPUTPORT, YACS::HMI::RENAME, setErrorMsg(), YACS::ENGINE::DataPort::setName(), YACS::HMI::Subject::update(), and YASSERT.
◆ localReverse()
bool CommandRenameOutDataPort::localReverse ( )
Definition at line 1092 of file commandsProc.cxx.
1093{
1094 DEBTRACE("CommandRenameOutDataPort::localReverse");
1095 Proc* proc = GuiContext::getCurrent()->getProc();
1096 Node* node = proc;
1097 try
1098 {
1099 if (_position != proc->getName()) node = proc->getChildByName(_position);
1100 OutPort * port = 0;
1101 try
1102 {
1104 port = node->getOutputPort(_oldName);
1105 else
1106 port = node->getOutputDataStreamPort(_oldName);
1107 }
1108 catch (Exception& e) {} // --- raised when no existing port with _newName
1109 if (port)
1110 throw Exception("there is already a port with the old name");
1111
1113 port = node->getOutputPort(_newName);
1114 else
1115 port = node->getOutputDataStreamPort(_newName);
1116 port->setName(_oldName);
1117 YASSERT(GuiContext::getCurrent()->_mapOfSubjectDataPort.count(port));
1119 sport->update(RENAME, 0, sport);
1120 }
1121 catch (Exception& ex)
1122 {
1123 DEBTRACE("CommandRenameOutDataPort::localReverse() : " << ex.what());
1124 setErrorMsg(ex);
1125 node = 0;
1126 }
1127 return (node != 0);
1128}
◆ _newName
std::string YACS::HMI::CommandRenameOutDataPort::_newName
Definition at line 243 of file commandsProc.hxx.
Referenced by CommandRenameOutDataPort(), dump(), localExecute(), and localReverse().
◆ _oldName
std::string YACS::HMI::CommandRenameOutDataPort::_oldName
Definition at line 242 of file commandsProc.hxx.
◆ _portType
TypeOfElem YACS::HMI::CommandRenameOutDataPort::_portType
Definition at line 244 of file commandsProc.hxx.
Referenced by localExecute(), and localReverse().
◆ _position
std::string YACS::HMI::CommandRenameOutDataPort::_position
Definition at line 241 of file commandsProc.hxx.
