YACS::HMI::CommandSetLinkProperties Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandSetLinkProperties:
Collaboration diagram for YACS::HMI::CommandSetLinkProperties:
 CommandSetLinkProperties (std::string startnode, std::string startport, std::string endnode, std::string endport, std::map< std::string, std::string > properties)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _startNodeName
std::string _startPortName
std::string _endNodeName
std::string _endPortName
std::map< std::string, std::string > _properties
std::map< std::string, std::string > _oldProp
bool _normalReverse
Definition at line 622 of file commandsProc.hxx.
◆ CommandSetLinkProperties()
CommandSetLinkProperties::CommandSetLinkProperties ( std::string  startnode,
Definition at line 3502 of file commandsProc.cxx.
3505 : Command(), _startNodeName(startnode), _startPortName(startport),
3506 _endNodeName(endnode), _endPortName(endport),
3507 _properties(properties)
3508{
3509 DEBTRACE("CommandSetLinkProperties::CommandSetLinkProperties " );
3510 _oldProp.clear();
3511}
References _oldProp, and DEBTRACE.
◆ dump()
std::string CommandSetLinkProperties::dump ( )
Definition at line 3513 of file commandsProc.cxx.
3514{
3515 string ret ="CommandSetLinkProperties " + _startNodeName + " " + _startPortName + " " + _endNodeName + " " + _endPortName;
3516 return ret;
3517}
References _endNodeName, _endPortName, _startNodeName, and _startPortName.
◆ localExecute()
bool CommandSetLinkProperties::localExecute ( )
Definition at line 3519 of file commandsProc.cxx.
3520{
3521 DEBTRACE("CommandSetLinkProperties::localExecute");
3522 try
3523 {
3524 Proc* proc = GuiContext::getCurrent()->getProc();
3525 Node* node;
3526 InputDataStreamPort* inDSPort = 0;
3527 OutputDataStreamPort* outDSPort = 0;
3528
3529 node = proc->getChildByName(_startNodeName);
3530 outDSPort = node->getOutputDataStreamPort(_startPortName);
3531 outDSPort->setProperties(_properties);
3532
3533 node = proc->getChildByName(_endNodeName);
3534 inDSPort = node->getInputDataStreamPort(_endPortName);
3535 _oldProp = inDSPort->getProperties();
3536 inDSPort->setProperties(_properties);
3537
3538 std::pair<OutPort*,InPort*> keymap = std::pair<OutPort*,InPort*>(outDSPort,inDSPort);
3540 subject->update(SETVALUE, 0, subject);
3541 return true;
3542 }
3543 catch (Exception& ex)
3544 {
3545 DEBTRACE("CommandSetDSPortProperties::localExecute() : " << ex.what());
3546 setErrorMsg(ex);
3547 return false;
3548 }
3549}
virtual void setProperties(std::map< std::string, std::string > properties)
Set the values of all properties of the port.
std::map< std::string, std::string > getProperties() const
Base class for all nodes.
Definition: Node.hxx:70
virtual OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const =0
virtual InputDataStreamPort * getInputDataStreamPort(const std::string &name) const =0
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
std::map< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * >, YACS::HMI::SubjectLink * > _mapOfSubjectLink
Definition: guiContext.hxx:72
Definition: guiContext.hxx:50
References _endNodeName, _endPortName, YACS::HMI::GuiContext::_mapOfSubjectLink, _oldProp, _properties, _startNodeName, _startPortName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::DataStreamPort::getProperties(), setErrorMsg(), YACS::ENGINE::DataStreamPort::setProperties(), YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ localReverse()
bool CommandSetLinkProperties::localReverse ( )
Definition at line 3551 of file commandsProc.cxx.
3552{
3553 DEBTRACE("CommandSetLinkProperties::localReverse");
3554 try
3555 {
3556 Proc* proc = GuiContext::getCurrent()->getProc();
3557 Node* node;
3558 InputDataStreamPort* inDSPort = 0;
3559 OutputDataStreamPort* outDSPort = 0;
3560
3561 node = proc->getChildByName(_startNodeName);
3562 outDSPort = node->getOutputDataStreamPort(_startPortName);
3563 outDSPort->setProperties(_properties);
3564
3565 node = proc->getChildByName(_endNodeName);
3566 inDSPort = node->getInputDataStreamPort(_endPortName);
3567 inDSPort->setProperties(_oldProp);
3568
3569 std::pair<OutPort*,InPort*> keymap = std::pair<OutPort*,InPort*>(outDSPort,inDSPort);
3571 subject->update(SETVALUE, 0, subject);
3572 return true;
3573 }
3574 catch (Exception& ex)
3575 {
3576 DEBTRACE("CommandSetDSPortProperties::localReverse() : " << ex.what());
3577 setErrorMsg(ex);
3578 return false;
3579 }
3580}
References _endNodeName, _endPortName, YACS::HMI::GuiContext::_mapOfSubjectLink, _oldProp, _properties, _startNodeName, _startPortName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::ENGINE::DataStreamPort::setProperties(), YACS::HMI::SETVALUE, and YACS::HMI::Subject::update().
◆ _endNodeName
std::string YACS::HMI::CommandSetLinkProperties::_endNodeName
Definition at line 634 of file commandsProc.hxx.
◆ _endPortName
std::string YACS::HMI::CommandSetLinkProperties::_endPortName
Definition at line 635 of file commandsProc.hxx.
◆ _oldProp
std::map<std::string,std::string> YACS::HMI::CommandSetLinkProperties::_oldProp
Definition at line 637 of file commandsProc.hxx.
Referenced by CommandSetLinkProperties(), localExecute(), and localReverse().
◆ _properties
std::map<std::string,std::string> YACS::HMI::CommandSetLinkProperties::_properties
Definition at line 636 of file commandsProc.hxx.
Referenced by localExecute(), and localReverse().
◆ _startNodeName
std::string YACS::HMI::CommandSetLinkProperties::_startNodeName
Definition at line 632 of file commandsProc.hxx.
◆ _startPortName
std::string YACS::HMI::CommandSetLinkProperties::_startPortName
Definition at line 633 of file commandsProc.hxx.
