YACS::HMI::SubjectHPContainer Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectHPContainer:
Collaboration diagram for YACS::HMI::SubjectHPContainer:
 SubjectHPContainer (YACS::ENGINE::HomogeneousPoolContainer *container, Subject *parent)
void registerUndoDestroy ()
YACS::ENGINE::Container * getContainer () const
std::string getLabelForHuman () const
- Public Member Functions inherited from YACS::HMI::SubjectContainerBase
 SubjectContainerBase (YACS::ENGINE::Container *container, Subject *parent)
virtual ~SubjectContainerBase ()
virtual std::string getLabelForHuman () const =0
virtual YACS::ENGINE::Container * getContainer () const
virtual SubjectReference * attachComponent (SubjectComponent *component)
virtual void detachComponent (SubjectComponent *component)
virtual void moveComponent (SubjectReference *reference)
virtual void removeSubComponentFromSet (SubjectComponent *component)
virtual void notifyComponentsChange (GuiEvent event, int type, Subject *son)
bool isUsed ()
TypeOfElem getType ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual TypeOfElem getType ()
virtual ~Observer ()
- Static Public Member Functions inherited from YACS::HMI::SubjectContainerBase
static SubjectContainerBase * New (YACS::ENGINE::Container *container, Subject *parent)
- Protected Attributes inherited from YACS::HMI::SubjectContainerBase
YACS::ENGINE::Container * _container
std::set< SubjectComponent * > _subComponentSet
std::map< SubjectComponent *, SubjectReference * > _subReferenceMap
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Definition at line 451 of file guiObservers.hxx.
◆ SubjectHPContainer()
SubjectHPContainer::SubjectHPContainer ( YACS::ENGINE::HomogeneousPoolContainer *  container,
Subject *  parent
Definition at line 4582 of file guiObservers.cxx.
4582 :SubjectContainerBase(container,parent)
4583{
4584}
SubjectContainerBase(YACS::ENGINE::Container *container, Subject *parent)
◆ getContainer()
YACS::ENGINE::Container * SubjectHPContainer::getContainer ( ) const
Reimplemented from YACS::HMI::SubjectContainerBase.
Definition at line 4586 of file guiObservers.cxx.
4587{
4588 if(!_container)
4589 return 0;
4590 else
4591 {
4593 if(!ret)
4594 throw Exception("Invalid container type in SubjectHPContainer !");
4595 return ret;
4596 }
4597}
References YACS::HMI::SubjectContainerBase::_container.
◆ getLabelForHuman()
std::string YACS::HMI::SubjectHPContainer::getLabelForHuman ( ) const
Implements YACS::HMI::SubjectContainerBase.
Definition at line 457 of file guiObservers.hxx.
457{ return std::string("Salome Homogeneous Pool Container"); }
◆ registerUndoDestroy()
void SubjectHPContainer::registerUndoDestroy ( )
Definition at line 4599 of file guiObservers.cxx.
4600{
4601 DEBTRACE("SubjectHPContainer::registerUndoDestroy");
4602 Command *command = new CommandAddHPContainer(getName(),"");
4603 GuiContext::getCurrent()->getInvoc()->add(command);
4604}
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
void add(Command *command)
Definition: commands.cxx:156
virtual std::string getName()
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), and YACS::HMI::SubjectContainerBase::getName().
