#include <commandsProc.hxx>
| CommandSetNodeProperties (std::string position, std::map< std::string, std::string > properties) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _position |
| std::map< std::string, std::string > | _properties |
| std::map< std::string, std::string > | _oldProp |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 577 of file commandsProc.hxx.
| CommandSetNodeProperties::CommandSetNodeProperties | ( | std::string | position, |
| std::map< std::string, std::string > | properties | ||
Definition at line 3225 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3232 of file commandsProc.cxx.
References _position.
protectedvirtual |
Definition at line 3238 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldProp, _position, _properties, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::Node::getPropertyMap(), setErrorMsg(), YACS::ENGINE::Node::setProperties(), YACS::HMI::SETVALUE, and YACS::HMI::SubjectNode::update().
protectedvirtual |
Definition at line 3267 of file commandsProc.cxx.
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectNode, _oldProp, _position, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::ENGINE::Node::setProperties(), YACS::HMI::SETVALUE, and YACS::HMI::SubjectNode::update().
protected |
Definition at line 588 of file commandsProc.hxx.
Referenced by CommandSetNodeProperties(), localExecute(), and localReverse().
protected |
Definition at line 586 of file commandsProc.hxx.
protected |
Definition at line 587 of file commandsProc.hxx.
Referenced by localExecute().
