YACS::HMI::CommandSetSwitchCase Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandSetSwitchCase:
Collaboration diagram for YACS::HMI::CommandSetSwitchCase:
 CommandSetSwitchCase (std::string aSwitch, std::string node, std::string value)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _switch
std::string _node
std::string _oldNode
std::string _value
int _oldValue
bool _normalReverse
Definition at line 425 of file commandsProc.hxx.
◆ CommandSetSwitchCase()
CommandSetSwitchCase::CommandSetSwitchCase ( std::string  aSwitch,
std::string  node,
std::string  value
Definition at line 2501 of file commandsProc.cxx.
2504 : Command(), _switch(aSwitch), _node(node), _value(value)
2505{
2506 DEBTRACE("CommandSetSwitchCase::CommandSetSwitchCase");
2507 _oldValue = 0;
2508 _oldNode = "";
2509}
References _oldNode, _oldValue, and DEBTRACE.
◆ dump()
std::string CommandSetSwitchCase::dump ( )
Definition at line 2511 of file commandsProc.cxx.
2512{
2513 string ret ="CommandSetSwitchCase " + _switch + " " + _node + " " + _value;
2514 return ret;
2515}
References _node, _switch, and _value.
◆ localExecute()
bool CommandSetSwitchCase::localExecute ( )
Definition at line 2517 of file commandsProc.cxx.
2518{
2519 DEBTRACE("CommandSetSwitchCase::localExecute");
2520 try
2521 {
2522 DEBTRACE("CommandSetSwitchCase::localExecute");
2523 Proc* proc = GuiContext::getCurrent()->getProc();
2524 Switch* aSwitch = dynamic_cast<Switch*>(proc->getChildByName(_switch));
2525 Node* node = proc->getChildByName(_node);
2526 int val = atoi(_value.c_str());
2527 if (aSwitch->edGetNode(val))
2528 {
2529 throw YACS::Exception("Set Switch Case impossible: value already used");
2530 }
2531 int oldVal = aSwitch->getRankOfNode(node);
2532 aSwitch->edChangeCase(oldVal,val);
2533 _oldValue = oldVal;
2534 _oldNode = proc->getChildName(node);
2535 DEBTRACE("CommandSetSwitchCase::localExecute OK " << val);
2536 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(aSwitch));
2539 ssw->update(SETCASE, val, snode);
2540 snode->recursiveUpdate(RENAME, 0, snode);
2541 return true;
2542 }
2543 catch (Exception& ex)
2544 {
2545 DEBTRACE("CommandSetSwitchCase::localExecute() : " << ex.what());
2546 setErrorMsg(ex);
2547 return false;
2548 }
2549}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: Switch.hxx:85
Node * edGetNode(int caseId)
Definition: Switch.cxx:527
void edChangeCase(int oldCase, int newCase)
Change the case of a node.
Definition: Switch.cxx:575
int getRankOfNode(Node *node) const
Definition: Switch.cxx:752
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
virtual void recursiveUpdate(GuiEvent event, int type, Subject *son)
References YACS::HMI::GuiContext::_mapOfSubjectNode, _node, _oldNode, _oldValue, _switch, _value, DEBTRACE, YACS::ENGINE::Switch::edChangeCase(), YACS::ENGINE::Switch::edGetNode(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::Switch::getRankOfNode(), YACS::HMI::SubjectNode::recursiveUpdate(), YACS::HMI::RENAME, YACS::HMI::SETCASE, setErrorMsg(), YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandSetSwitchCase::localReverse ( )
Definition at line 2551 of file commandsProc.cxx.
2552{
2553 DEBTRACE("CommandSetSwitchCase::localReverse");
2554 try
2555 {
2556 DEBTRACE("CommandSetSwitchCase::localReverse");
2557 Proc* proc = GuiContext::getCurrent()->getProc();
2558 Switch* aSwitch = dynamic_cast<Switch*>(proc->getChildByName(_switch));
2559 Node* node = proc->getChildByName(_oldNode);
2560 int val = _oldValue;
2561 if (aSwitch->edGetNode(val))
2562 {
2563 throw YACS::Exception("Set Switch Case impossible: value already used");
2564 }
2565 int oldVal = aSwitch->getRankOfNode(node);
2566 aSwitch->edChangeCase(oldVal,val);
2567 DEBTRACE("CommandSetSwitchCase::localReverse OK " << val);
2568 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(aSwitch));
2571 ssw->update(SETCASE, val, snode);
2572 snode->recursiveUpdate(RENAME, 0, snode);
2573 return true;
2574 }
2575 catch (Exception& ex)
2576 {
2577 DEBTRACE("CommandSetSwitchCase::localReverse() : " << ex.what());
2578 setErrorMsg(ex);
2579 return false;
2580 }
2581}
References YACS::HMI::GuiContext::_mapOfSubjectNode, _oldNode, _oldValue, _switch, DEBTRACE, YACS::ENGINE::Switch::edChangeCase(), YACS::ENGINE::Switch::edGetNode(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::Switch::getRankOfNode(), YACS::HMI::SubjectNode::recursiveUpdate(), YACS::HMI::RENAME, YACS::HMI::SETCASE, setErrorMsg(), YACS::HMI::SubjectNode::update(), and YASSERT.
◆ _node
std::string YACS::HMI::CommandSetSwitchCase::_node
Definition at line 436 of file commandsProc.hxx.
◆ _oldNode
std::string YACS::HMI::CommandSetSwitchCase::_oldNode
Definition at line 437 of file commandsProc.hxx.
Referenced by CommandSetSwitchCase(), localExecute(), and localReverse().
◆ _oldValue
int YACS::HMI::CommandSetSwitchCase::_oldValue
Definition at line 439 of file commandsProc.hxx.
◆ _switch
std::string YACS::HMI::CommandSetSwitchCase::_switch
Definition at line 435 of file commandsProc.hxx.
◆ _value
std::string YACS::HMI::CommandSetSwitchCase::_value
Definition at line 438 of file commandsProc.hxx.
