YACS::HMI::CommandSetSwitchSelect Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandSetSwitchSelect:
Collaboration diagram for YACS::HMI::CommandSetSwitchSelect:
 CommandSetSwitchSelect (std::string aSwitch, std::string value)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _switch
std::string _value
std::string _oldValue
bool _normalReverse
Definition at line 411 of file commandsProc.hxx.
◆ CommandSetSwitchSelect()
CommandSetSwitchSelect::CommandSetSwitchSelect ( std::string  aSwitch,
std::string  value
Definition at line 2437 of file commandsProc.cxx.
2439 : Command(), _switch(aSwitch), _value(value)
2440{
2441 DEBTRACE("CommandSetSwitchSelect::CommandSetSwitchSelect");
2442 _oldValue = "0";
2443}
References _oldValue, and DEBTRACE.
◆ dump()
std::string CommandSetSwitchSelect::dump ( )
Definition at line 2445 of file commandsProc.cxx.
2446{
2447 string ret ="CommandSetSwitchSelect " + _switch + " " + _value;
2448 return ret;
2449}
References _switch, and _value.
◆ localExecute()
bool CommandSetSwitchSelect::localExecute ( )
Definition at line 2451 of file commandsProc.cxx.
2452{
2453 DEBTRACE("CommandSetSwitchSelect::localExecute");
2454 try
2455 {
2456 Proc* proc = GuiContext::getCurrent()->getProc();
2457 Switch* aSwitch = dynamic_cast<Switch*>(proc->getChildByName(_switch));
2458 InputPort *condPort = aSwitch->edGetConditionPort();
2459 _oldValue = condPort->getAsString();
2460 if (_oldValue == "None") _oldValue = "0";
2461 int val = atoi(_value.c_str());
2462 condPort->edInit(val);
2463 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(aSwitch));
2465 snode->update(SETSELECT, 0, snode);
2466 }
2467 catch (Exception& ex)
2468 {
2469 DEBTRACE("CommandSetSwitchSelect::localExecute() : " << ex.what());
2470 setErrorMsg(ex);
2471 return false;
2472 }
2473 return true;
2474}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: DataPort.cxx:84
Base class for Input Ports.
Definition: InputPort.hxx:44
void edInit(T value)
Definition: InputPort.hxx:129
Definition: Proc.hxx:44
Definition: Switch.hxx:85
InputPort * edGetConditionPort()
Definition: Switch.hxx:115
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
References YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _switch, _value, DEBTRACE, YACS::ENGINE::Switch::edGetConditionPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETSELECT, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ localReverse()
bool CommandSetSwitchSelect::localReverse ( )
Definition at line 2476 of file commandsProc.cxx.
2477{
2478 DEBTRACE("CommandSetSwitchSelect::localReverse");
2479 try
2480 {
2481 Proc* proc = GuiContext::getCurrent()->getProc();
2482 Switch* aSwitch = dynamic_cast<Switch*>(proc->getChildByName(_switch));
2483 InputPort *condPort = aSwitch->edGetConditionPort();
2484 int val = atoi(_oldValue.c_str());
2485 condPort->edInit(val);
2486 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(aSwitch));
2488 snode->update(SETSELECT, 0, snode);
2489 }
2490 catch (Exception& ex)
2491 {
2492 DEBTRACE("CommandSetSwitchSelect::localReverse() : " << ex.what());
2493 setErrorMsg(ex);
2494 return false;
2495 }
2496 return true;
2497}
References YACS::HMI::GuiContext::_mapOfSubjectNode, _oldValue, _switch, DEBTRACE, YACS::ENGINE::Switch::edGetConditionPort(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), YACS::HMI::SETSELECT, YACS::HMI::SubjectNode::update(), and YASSERT.
◆ _oldValue
std::string YACS::HMI::CommandSetSwitchSelect::_oldValue
Definition at line 422 of file commandsProc.hxx.
Referenced by CommandSetSwitchSelect(), localExecute(), and localReverse().
◆ _switch
std::string YACS::HMI::CommandSetSwitchSelect::_switch
Definition at line 420 of file commandsProc.hxx.
◆ _value
std::string YACS::HMI::CommandSetSwitchSelect::_value
Definition at line 421 of file commandsProc.hxx.
